Question about Husqvarna 28cc Gas Line Trimmer
How do you adjust the carburator - Husqvarna 28cc Gas Line Trimmer
  • Husqvarna Master
  • 1,807 Answers
Your adjust the carb using the tuning screws on the side of the carb.
Posted on Aug 03, 2013
Carburator adjustments
Should be two holes on the side of the case towards the back. One is for high adjustment and the other for low adjustment. Hope this helps.
Apr 24, 2014 | Homelite Garden
Carburator and idle problem
Believe it or not you just said the solution to your own problem manufacturers specs requires for any adjustments to engine idle or other carburator adjustments to be preformed while the engine is idling and at normal operating temp in plain english let the car warm up then make your idle and mixture adjustments if this doesnt solve it i would check the auto choke and make sure it is opening at normal operating temp hope this helps good luck
Sep 01, 2008 | 1984 Toyota Tercel
Honda 25 cc 4 cycle mini tiller how to adjust carburator
With one screw you can adjust the idle speed, and with the second, located under the carburetor you can adjust the running or load speed.
Mar 22, 2013 | Honda 25cc 4-cycle Mini Tiller
What does "h" or "l" stand for on a carburator adjustment screw ?
H is the high speed adjustment ( screw in to lean the mixture and increase the revs, screw out to richen and decrease revs ) I is the idle screw, this will adjust the tick over speed of the engine, you can also have a srew marked L this is to adjust the low speed running by leaning or richening the fuel mixture
Jul 21, 2012 | Garden
How adjust a carburator after replace a new kit
This is a very hard carburator to adjust best to take it to a carburator shop and let them deal with it.
Jul 10, 2011 | 1988 Dodge Ram 50
How can you adjust the carburetor on a 1987 GMC safari van V-6
If the carburator has never been rebuilt, or the plugs that were installed at the factory have never been removed, you need to remove those plugs, there is one for each idle mixture screw, at the front of the base plate on the bottom of the carburator, 1 for the TPS adjustment on the driver side front of the carburator, and one for the mixture control solenoid on top of the carburator, in the middle, towards the front.
May 22, 2010 | 1987 GMC Safari
Adjusting the carburator on a craftsman 25cc line trimmer
Replace all of the lines before any adjustments, too small to see air leaks are a common cause the issue you have.
Feb 27, 2010 | Craftsman 25cc Gas Line Trimmer
1989 accord lx, idles high at start-up, now it won't stay running
Carburated engines of that year may have an idle screw adjuster. You can see the screw from the outside of the carb. If so, try adjusting the carburator with a screwdriver. Unlike fuel injected Engines they can be manually adjusted.
Apr 08, 2009 | 1991 Honda Accord
New carburator doesn't passed fuel
Are you sure that that the replacement is the correct one. Also, why did you have to replace the carburetor . Did you verify that the carburetor was the problem? Did the weedeater run by priming? Did you check the pump and lines? If these methods were tried and did not reveal the problem, then I suggest that you get professional help.
Oct 23, 2008 | Ryobi 15" Electric Factory Reconditioned...
Husqvarna 28cc Gas Line Trimmer Logo
106 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
