Question about HP Photosmart C6280 Printer
I have problem with my printer HP C6280, the keyboard not work I tried reset firmware plug the key ok and cancel but seems not work because the keyboard not work and dont switch the printer off, and ask if the problem could be the low levels of ink cartridges. Regards. My Thanks.
  • 67 Answers
Maybe one Button gose down and stuck
Posted on May 19, 2011
Printer hp c6280: error message "oxc18a0401" what
Please perform the following steps SWITCH ON THe PRINTER.ONCE THEERROR COMES in the display screen DO THE FOLLOWING Press and hold the * key.
Press the # key and release both keys.
Display should say Enter Special KeyCombo
Press and release the button one by one in sequence the 1, 2 and 3 buttons.
display screen says "support" R0631M.
Press and release the right arrow button until the display says System Configuration Menu.
then Press and release the OK button.
Display should say Hardware failurestatus. If not there already, ArrowKey over to Hardware failure status
Press and release the OK button..Display should say Hardware failure status: Clear. Press OK to clear.
Press and release the OK Button. Message changes to Hardware failure statusCleared. Press Cancel to continue.
Press and release the CANCEL button as many times as necessary, so that, eitherthe Welcome to Photosmart Express screen appears, or, the Ink System Failurescreen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable fromback of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cableinto the wall outlet first and then into the back of the printerTurn the unit on. The printer may display message USEPOWER BUTTON TO SHUTDOWN THE PRINTER followed by PRESS OK TO CONTINUE. PressOK. The Printer will start the ONE TIME INK INITIALIZATION PROCESS. Allow thisprocess to complete and do not interrupt. Once the initialization process iscomplete, the printer will print out a Diagnostic Page.
Aug 01, 2011 | HP Photosmart C6280 Printer
Tried to fix a paper jam and now I get this code C2FE0100 and the printer won't print. Unplugged it and still nothing
Found this link to reset an HP Printer:
http://www.out-of-warranty.com/how-to-reset-hewlett-packard-hp-all-in-one-printers/
Good Luck!
Mar 01, 2011 | Office Equipment & Supplies
Error:oxc18a0401??
Hi There,
These are reset instructions designed to clear most of hp errors starting with 0xc...It works on different hp models.. it could work on you too.
Semi reset
1. While your printer is on.. unplug to power cable from the printer.
2. Press and hold the "OK" and "HELP" buttons while you plug the power cable at the back of the printer. Try these steps to reset your printer to default setting.
Full reset
1. Press & hold " * " key...(asterisk sign)
2. While holding the " * ", press "#" key and then release both keys..."Enter Special Key Combo" will be displayed...
3. Press "1", "2" and "3" to display Support...
4 Press ">" right arrow button and release when System Config Menu appear....then click OK
5. Press arrow key to display Hardware Failure Status...click OK....
6. When Hardware Failure Status:Clear appeared, press "OK" to clear...
7. Press "OK" again to display "Hardware Failure Status Cleared. Press Cancel To Continue".....
8. Press "CANCEL" as many times to display "Welcome To Photosmart Express" or "Ink System Failure".....
9. The last part is to turn off the printer and unplug at the back...wait for 30 sec, then plug and turn on the printer...if asked, press "OK" to continue and allow the "One Time Ink Initialization" to proceed..After this try to print...
If you find the reset solutions helpful...Please rate this solution and vote YES ..thanks..
Nov 04, 2010 | HP Photosmart 3210 Printer
How do I fix Error:Oxc18s0301 Ink system failed.
Try using these two reset instruction...these clears most of hp errors starting with 0xc...It works on different hp models.. it could work on you too.
Semi reset
Full reset
If you find the reset solutions helpful to you...Please rate this solution and vote on this on the YES below..thanks..
Aug 20, 2010 | HP Photosmart C6280 Printer
Error: Oxc18a0401
here.. check this out. a solution to your problem.
Semi reset
Full reset
Aug 16, 2010 | HP Photosmart 3210 All-In-One InkJet...
0xc18a0001
Semi reset
Full reset
9. The last part is to turn off the printer and unplug at the back...wait for 30 sec, then plug and turn on the printer...if asked, press "OK" to continue and allow the "One Time Ink Initialization" to procede..After this try to print...
Jun 02, 2010 | HP Photosmart 3210 Printer
Hp photosmart C6280 ink system has failed. what do I do?
Please follow the below steps.
STEP 1.
1. Un plug the power chord from the back of the printer.
2. Press and hold the power button of the printer.Wait for 30 seconds.
3. While holding the power button, re-plug the power cable.
4. Turn on the printer, if it is not on.
STEP 2.
Reset the All-in-One to the factory default settings by using these instructions:
1) Press Red Eye Removal & Print Photos button simultaneously
2)Enter Special Key Combo is displayed on the screen.
Press and release in sequence "Red Eye Removal", "Print Photos", "Red Eye Removal"
Display should say "Support" and display the FW rev XXXXX.
3) Press Right Arrow button untill "Reset Menu" is displayed. Press OK.
4) Press Right arrow untill "Semifull Reset" is displayed.
5) Press OK.
Apr 28, 2010 | HP Photosmart C6280 Printer
HP photosmart c6280 ink systems failure
The ink system failure message has a chance to be fixed or it may be a permanent issue. It can be pointing toward a firmware failure in the printer and if that is the case the following steps should fix it. Press and hold the ?*? key. Press the ?#? key and release both keys. Display should say ?Enter Special Key Combo? Press and release in sequence the "1?, ?2? and ?3? buttons. Display should say ?Support? and display the FW rev (something like R0631R) Mine reads R0631M . Press and release the right arrow button until the display says ?System Configuration Menu?. Press and release the ?OK? button. Display should say ?Hardware failure status?. If not there already, Arrow Key over to ?Hardware failure status?, Press and release the ?OK? button. Display should say ?Hardware failure status: Clear. Press OK to clear?. Press and release the ?OK? Button. Message changes to ?Hardware failure status Cleared. Press Cancel to continue?. Press and release the ?CANCEL? button as many times as necessary, so that, either the ?Welcome to Photosmart Express? screen appears, or, the ?Ink System Failure? screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer. Turn the unit on. The printer may display message ?USE POWER BUTTON TO SHUTDOWN THE PRINTER? followed by ?PRESS OK TO CONTINUE?. Press OK. The Printer will start the ?ONE TIME INK INITIALIZATION PROCESS?. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. Good Luck!
Jun 06, 2009 | HP Photosmart 3210 Printer
Error Oxc18a0001 on an HP C6280
Press and hold the "*" key. Press the "#" key and release both keys.
Display should say "Enter Special Key Combo"
Press and release in sequence the "1", "2" and "3" buttons.
Display should say "Support" and display the FW rev (something like R0631R)
Mine reads R0631M
. Press and release the right arrow button until the display says "System Configuration Menu".
Press and release the "OK" button.
Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
Display should say "Hardware failure status: Clear. Press OK to clear".
Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. Good Luck!
Jul 08, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6280 Printer Logo
147 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
