Question about Quinny Buzz Three Wheel Stroller
Bought quinny buzz 3 second hand, the frame has dropped on one side, how do i fix it?
  • Quinny Master
  • 1,629 Answers
Good Evening
Unfortunately there is no quick fix for this; It sounds as though one of the knuckles has broken, causing a one sided chassis collapse.
What country are you in?
Posted on May 23, 2011
I bought a second hand Quinny Buzz, and the clip for the frame lock is broken
Hi
The transport lock is available as a spare part item - who did you speak with that advised you it wasn't?
RRP for the transport clip is 10GBP and you can order via your local Quinny retailer or direct from the customer care team on 01284 413 141 Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays)
Sep 11, 2012 | Quinny Buzz Baby Gear
I have a quinny buzz and the catch that keeps the frame shut is not working, so when driing it can pop up! I brought this second hand so no idea what to do.
If this is a first generation Buzz, you should be able to get the nylon clip style catch that attaches onto the frame and keeps it closed. I would suggest that you contact http://www.quinny.com/quinny/forms/contact.aspx?mode=contact&language=gb-en as they will be able to assist with this.
I hope this helps.
Sep 11, 2009 | Quinny Buzz Jogger
Main frame and worn wheels of the quinny buzz
This happened to my wife the other day, I found that the main pivot bolt had pulled through the plastic pivot/collapse assembly. This part is rivoted to the frame so without drilling it out and replacing with an ugly nut and bolt you will have to source a new frame. I got mine from Ebay, I found someone selling lots of quinny buzz bits and asked if he still has the frame he said yes but the handle bar no longer extends (Hence im on here looking how to swap the two), Problem solved!
I also found out from Quinny that the Buzz has a 2 year manufacturers warranty, where Motercare insisted it was 1 year, so dont let them fob you off.
Hope this helps
Chris.
May 18, 2009 | Quinny Buzz Jogger
Does the quinny buzz seat 2006 and carrycot fit the 2008/9 frame
Hi new frame should be ok, the only frame that is different is the older 2005 frame, if you remove your seat unit and check the posts on your seat unit (the bits that slot onto the buzz chassis) if they are both the same and have rounded ends then this is the older model and wont fit the newer frames, but if one of the posts is rounded and the other is shaped like a turret then all the frames 2006 onwards will be ok. :)
May 16, 2009 | Quinny Buzz Jogger
Folding - Quinny buzz 3
HI, if it's the same model as I have: start with the frame facing you with the break on, you will see 2 long grey 'buttons' situated where the seat clips in to the frame. One of these buttons has arrows on it like this ^, this one you push in the direction of the arrows. The other you, simultaneously push in. You then push the whole frame down - this takes a bit of pressure. The whole thing should fold flat, you then secure it with the cable located near the wheel.
This sounds very complicated, it isn't once you've done it the first time - I hope it makes sense to you!
Feb 06, 2009 | Quinny Buzz Jogger
Quinny Buzz Frame Problem
Try contacting them directly!
This may be a manufacturing problem that they are not aware of !
Click on the link below.Copy and Paste your problem into the email if you like.
http://www.quinny.com/quinny/forms/contact.aspx?mode=contact&language=nl-nl
Hope this is helpful.
Good Luck!
Jan 22, 2009 | Quinny Zapp - Olive Green Umbrella...
Quinny buzz 3 2008
if you phone dorel they will talk you through what to do, i sent them my frame Quite cheap to post, i used make shift box and removed the wheels etc, and they fixed it and posted it back to me..problem solved phone number is 01842763281
Aug 19, 2008 | Quinny Buzz Jogger
Hi I got a nearly new frame off ebay for a bargain! There are loads of spare parts to be had on there.
Aug 03, 2008 | Quinny Buzz 3 Sulphur Jogger
Quinny buzz
Tyres-press the light grey button on the chassis next to the wheel slot as you push on the wheel (this is also the button you press to release each wheel).
Opening it is easy - With Buzzwheels on the ground, remove safety hook (plastic loop on left side of handle fixed to peg inner left rear wheel) ten simple lift handle and Buzz frame should automatically pop up.
Closing takes more practice-put on brakes (press red foot pedal) stand to side of chassis and at bottom end of handle there are two large grey buttons. With left hand on left button push button forwards (ie direction of chevrons on button) then press in. At the same time push in right button with right hand. Whilst doing this you also need to push down and forad on frame and it should fold down. If you don't push buttons enough it can click. When folded remember to put on safety hook before transit, otherwise it might pop up on its own. Hope this helps. You can download the manual with instructions from Quinny website too if pictures are helpful!
Apr 25, 2008 | Quinny Buzz Jogger
Quinny Buzz Three Wheel Stroller Logo
189 people viewed this question
Top Quinny Baby Gear Experts
Jennifer Rock
Jennifer Rock
Oloyede Monsuru
ray gallant
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
