Question about Kitchen Ranges
Cannon pearl duo cooker. when oven on ignition clicks constantly
4 Suggested Answers
  • 3087 Answers
SOURCE: my indesit gas cookers igniters keep clicking, i
yes its possable for that to happen try replacing the switch
Posted on Jan 21, 2010
SOURCE: need to set clock on my cannon chichester oven
Go to www.cannonservice.co.uk/hs/pages/manual/manualSearch.do you should find your model there. Terry.
Posted on Jan 31, 2009
SOURCE: Oven Ignition Keeps Clicking
Lift the cooker using a helecopter and drop it on cannon HQ as this is the only pleasure you will recieve from purchasing a cannon chesterfield cooker Looks like a RollsRoyce shame about the engine The first one we bought was plauged with problems Having only owned the cooker a few days and 3 visits from there very well mannerd technitians cannon replaced the cooker but alas the technitians had to visit again It has been over a year now and would you believe it top oven wont ignite niether will the rings and no its not the fuse in the plug Clock eluminated not bad for around 500 quid
Posted on Nov 25, 2009
My cannon duo cooker was working one day then next day the clock doesn't work, the ignition wont work theres no gas coming through to lite oven manually whats the problem the rings work perfectly
Gas ovens invariably have a safety thermocouple to cut the gas off automatically if the flame goes out, due to an interruption in the supply for instance. The thermocouple must be temporarily over-ridden for the purpose of lighting the burner and pilot and often the override is mechanical but considering the clock and ignition has stopped working it would be reasonable to assume your oven has an electrical or electronic thermocouple override.
It would seem either the mains supply to your cooker has failed or the internal power supply has a problem. With such a sophisticated oven, even if you had been able to light it manually, it is possible the temperature control wouldn't have worked.
Mar 26, 2016 | Cannon Kitchen Ranges
My indesit gas cooker's igniters keep clicking
Hi yes it could be that if it only just done this leave it off you can still use the top the heat while cooking should dry it out.
Oct 10, 2009 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Bottom oven on Cooker Cannon c60gcw will not ignite, continuouos sparking and no gas when knob turned on
Fault caused by trapped and therefore cut wiring to main oven valve at bottom rear of cooker causing wiring overheat melting and open circuiting electrical supply.
Sep 15, 2009 | Ovens
The bottom oven on my stoves cooker ignites but then constantly clicks and will not stop until the gas dial is switched off. Can any one give me a clue as to why? Thanks
As an ex stoves enginneer, the problem may be one of three faults;
1. cracked electrode, what creats the spark in the oven
2.electrode lead has melted.
3. faulty ignition generator.
Try takin the lead off the electrode and placing it in the oven flame, if this stops the clicking, then replace the electrode.
L.B
Jun 10, 2009 | Stoves Ovens
it is the spark generator at back of cooker they are about £65
Mar 16, 2009 | Cannon Chesterfield C60G Kitchen Range
The clock & oven on my cannon chichester cooker dosent work
Hi anyone , my chichester ignition button has stopped working - is there a battery located somewhere
Dec 05, 2007 | Ovens
Kitchen Ranges Logo
393 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
