Question about Ducane 30400040 Stainless Steel Grill
I have a ducane 3040040 lp grill. I cant get the burners to light. the ignitors are working and the give off about a 3 inch flame. gas is coming out of the orifices' but dose not seem to have alot of pressure behind it. I tried the reset procedure(turn all burners to high for one minute,then rehook up gas). I have also tried new burners but no dice.??
  • 43,501 Answers
Your problem could be or probably is with the regulator...not enough gaspressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Posted on May 18, 2011
When I try to start the propane grill (Ducane)by pushing the knob and turn to hi, it creates a spark and from the "pilot" there is a big flame straight up, I hear and can smell the gas , but that...
It sounds like something got disconnected between your gas line and your venturi (which deliver gas to your burners. Take out the grills and whatever holds your rocks or ceramic briquettes and look at the connection where the flame is coming from. It may be obvious what has come apart, and the fix may be as simple as pushing it back together.
Jul 15, 2017 | Ducane 30400042 (LP)
Does conversion from LP gs to Natural gas on Ducane 30400040 (essentially makes it a model 30400041) require changing the inlet orofice on the IR burner ? I purchased conversion kit that included all new...
Did the conversion kit give you an LP orifice for every new gas valve? LP gas orifices have smaller holes than Nat gas orifices. Can you smell gas when you turn on the IR burner by itself? Some burners styles have an air adjustment on the end that fits over the orifice. Make sure it's getting enough air. Also make sure your ignitor sparker is positioned where the spark can ark against the top of the burner. Ducane grills have rotary ignitors, so turn it (with gas off) and see if you can actually see where it's sparking. If it's not sparking in the right place, it will be difficult to light.
May 14, 2010 | Ducane 30400040 Stainless Steel Grill
Side burner on my Ducane 30400040 LP gas grill has a tall yellow/orange flame. How do I adjust?
Try blowing the burner out with compressed air. They're not adjustable but can get clogged up and change the air to gas mix.
Apr 25, 2010 | Ducane 30400040 Stainless Steel Grill
Ducane lp gas grill flame pulsates
Have you replaced the battery ? They do rust and lose contact over time outside.
Apr 14, 2010 | Char-Broil Commercial Stainless Steel...
How to change burners for a ducane meridian 32 inch 5 burner gas grill
Go to Ducane web site http://www.ducane.com/manuals/ and download the manual for your model.
Has Mederian 3 & 5 burners and LP & NG
Also has Stainless 3 & 5 and LP & NG
Need Adobe Acrobate reader that can also be downloaded.
Manual shows step by step in Annual Cleaning section
azrsanford@comcast.net
Apr 04, 2010 | Ducane Meridian 32 Inch 5 Burner Gas Grill...
I was given a ducane 20002301 2 burner with rotisserie and when I ignite and have on high there is not much flame. I know very little about gas grills
Could be two things, the first is a bad regulator, easy to replace and not very expensive. The other is a blockage in the burner orifices. For this you have to take the burners out and check inside the burner venturis and then see if you can unscrew the orifices on the valves and clean out any blockage.
Nov 16, 2009 | Ducane 455 inch 2 - 3 Burner with...
I get an ignite but my burners wont light. I have
did you try replacing the battery? it is inside the ignitor button.
Aug 04, 2009 | Ducane 30400042 (LP)
Meridian 5 burner trouble
Yes you can fix it. Carefully remove the screws that hold the panel where the burner knobs are, There are 3 screws on each panel under the side shelf. There is another screw up underneath the face plate as well. Once the screws are out pull the face plate up and out so that all the tubes are disengaged. It should rest about 2 inches tilted back. Now remove the grates and burner covers and inspect the burner tubes. You will most likely find that spider webs or hornets have blocked off the gas flow to the burner. carefully clean every burner tube out and put everything back. You also may want to use a bit of sandpaper on the ignitor tip. Put everything back together and you should be good to go. It seems all Ducanes attract spiders on the burners...
Apr 06, 2009 | Ducane Meridian 32 Inch 5 Burner Gas Grill...
Lighting Problem/2 year-Old Ducane Grill
Do you have enough gas pressure coming out of the regulator and gas valve? You'll need a pressure guage for this.
If yes, try taking out the burners and cleaning them with a wire brush, especially the flame spreading sections.
Sep 15, 2008 | Ducane 30400040 Stainless Steel Grill
Ducane 30400040 Stainless Steel Grill Logo
247 people viewed this question
Top Ducane Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Are you a Ducane Grilling Expert? Answer questions, earn points and help others
