I have a apex 32-inch tv model (AT3208S), This tv was connect to a converter box, the other day electric power went out in our area for about 8 mins or less, once the power was back on the tv screen was blue and have remain this way. I have disconnect, scan, unhook, chg to 3/4. I went to Best Buy, came home a connect, with the same problem. I called Best Buy Tec support, they tried different things, reset, unplug, disconnect ect, same problem the tv screen still blue. The tv is working and the converter box is working. What else can I do?.
  • 4 Answers
OK, I have one of these TVs, and here's a thought: There's nothing wrong with the TV nor with the cable converter box. Please bear with me. Since I don't know how much you may know about TVs in general and this one in particular, I'm going to assume you know nothing and go from there.
This TV has several different "inputs", which are ways a signal can be transferred from its source to the TV, where it "outputs" the video image. I believe this particular TV has 5 different inputs: In descending order of the quality of the video signal, there're one S-video input (a 4-pin video connector plus red & white audio), three composite video inputs (3 connectors each: yellow video and red/white audio--audio connectors are the same for both s-video and composite), and one coax connector (a single large screw-on connector with a little wire sticking up through the center of it) for a total of five different inputs.
The problem with these Apex TVs is that they always default to the Antenna/coax input first when they are restarted. Most people use the TV to display an input signal (like the cable box or a DVD player) connected either to the S-video or to one of the 3 composite video inputs, not to the coax input, which just displays the channel numbers from 1-125 when it's set to do that (hit the "display" button on your remote to toggle showing the channel numbers for the coax input). If there's no signal coming into the coax input, the screen with appear blue. (If it's blue, it simply means it's not getting a signal via the input to which the TV is currently set. You can turn off the blue screen in the menu settings, but then you'll just get a blank screen. It's probably better just to leave the screen blue; at least you can tell the TV's actually trying to display something that way.)
You have to manually select the proper input by pressing the "video" button either on the remote (lower right corner) or the "video" button directly on the TV (hidden control panel under the middle of the margin around the bottom of the TV screen. You'll have to press on the door, and the whole control panel rolls open to reveal another set of composite inputs and some buttons. The video button is the one farthest to the left.)
Anyhow, by pressing the video buttons, you'll cycle through the various inputs. Assuming your cable converter box is functioning properly, powered on, receiving a signal from the cable company, and connected to the TV via a(n) appropriate wire(s) connected correctly, you should see the output from the cable box on the screen when you cycle through to display the proper video input.
Another possibility: the power outage fried the input to which your cable box was connected on the back of the TV. If that's the case, your cable box would probably also have sustained damage. You can check to see if the various video inputs on the TV are working by connecting different source inputs (like a BluRay/DVD/VCR player, video game console, video camera, etc.) to one of the other inputs and see if you get a picture when the TV is set to the appropriate inputs. (Remember, the "video" button is what selects/changes/cycles through the various video inputs.) One of the sets of inputs went bad on my TV. I just use the other ones.
Posted on Oct 07, 2011
Dont remember the code for the remote to my television
Hello
Try with these codes. These codes are of universal remote control with Apex Digital.
015 226 037
May 10, 2011 | Apex Digital AT2702 27" TV
Have an apex tv model #At3208s, no picture sound just chirping sound when plugged in and power turned on! should i repair or just buy another one?
Hi
this sounds like a short on the ht(B+ line) out of the power supply most likely causes are a s/c line output tranistor or a faultry flyback transformer
Regards windyhouse
Mar 29, 2010 | Apex Digital AT3208S 32" TV
Cannot use comcast remote for volume or to turn off apex 32" at3208s
See http://www.comcast.com/corporate/customers/customer_support/remotes.html
Feb 13, 2010 | Apex Digital AT3208S 32" TV
Apex AT3208s not switch on TV.Light diode red glow.
AT3208s 32" will not turn on have good power supply.
Apr 19, 2009 | Apex Digital AT3208S 32" TV
Apex tv
should be inside the back cover on the left hand side toward the rear of the television
Feb 18, 2009 | Apex Digital AT3208S 32" TV
Blue Screen of Death???
I have same problem, screen is blue for cable TV, same for DVD and for the S-video imput. The menues works good for adjust the color or the TV lenguages, but I can see only the blue screen.
Sep 14, 2008 | Apex Digital AT3208S 32" TV
Where do I find APEX parts? 32" PF3225 sound card
Hallo,
I have a Apex Sound Card.
If you need it send me a mail.
Mar 14, 2008 | Apex Digital AT3208S 32" TV
Loss of Picture on Right and left side
Take your remote control, press volume to 0
Press the mute button on your remote, at the same time, press the menu button on your TV for 3 seconds.
A menu will apear, press the right arrow on your remote to go to menu 002 to fix your problem.
gbr@yahoo.com
Jan 02, 2008 | Apex Digital AT3208S 32" TV
Finding a code
What is the model number of the Apex TV you are using this remote for?
The CK5G-C1 remote was supplied only with model AT3208S TV. It will require no code when used with that model. If trying to use it with any other model TV, you can try the other Apex TV codes found in the AT3208s user's manual that can be found in .pdf format at : http://www.apexdigitalinc.com/manual/AT3208S.pdf
Let me know if this helps, or I can be of further help.
In any case, good luck!
Oct 22, 2007 | Apex Digital PF3220 32" TV
Televison & Video Logo
142 people viewed this question
Top Televison & Video Experts
Electro Med Services...
