Question about HP Officejet 4110 All-In-One InkJet Printer
When i turn my ofice jet 4110 on, rhe yelow light comes on for approximately -3 seconds and is immediately replaced by the flashing red light which stays on no mattr what i try.
    Problem Solver:
  • 17 Answers
There are usually 2 culprits for this. Try these first and they might solve your problem.
1. ink cartridge jam - sometimes the ink cartridge is loose. just remove it and put it back.
2. paper jam (or other stuff) - sometimes some paper/paper clip/ rubber band gets jammed in the paper feed
Try also looking at the PC/laptop which it is connected to. There is a chance that a message will show the actual printer problem.
Posted on May 18, 2011
Sony fd trinitron colour television kv 29ls60e
The power supply probably is failing.
Jan 10, 2014 | Televison & Video
Constant flashing lights,all three of the red, all of the yellow and one green. The chair was not at a full charge. I traveled approximately 20 feet, then I turned the chair around. Next ,I turned the...
You can visit this website to find answers on what the flashing trouble indicator lights mean: http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Locate the page that has the controller used on your power chair/scooter and count how many lights are flashing to diagnose the trouble. If your insurance purchased the power chair for you, they may also cover the repairs; contact them for information.
Oct 29, 2010 | Jet 3 Ultra Power Chair
Blinking red light above the lowest setting on filter queen defender air purifier.
1. Plug unit into outlet. 2. Press power ON/OFF switch to the ON position. 3. Allow unit to start running at low speed. 4. PRESS and HOLD both the UP and DOWN arrow buttons until the FILTER REPLACEMENT INDICATOR starts to blink. 5. Release both the UP and DOWN arrow buttons. 6. While the FILTER REPLACEMENT INDICATOR is still flashing, again PRESS and HOLD both the UP and DOWN arrow buttons untile the FILTER REPLACEMENT INDICATOR turns off.
If the steps above have been performed properly, the Filter Replacement Indicator will turn offand not flash again for 11 months. If the Filter Replacement Indicator remains on, repeat the steps again.
*Note that in step 6 above, the Filter Replacement Indicator MUST still be flashing when the buttons are pressed the second time.The Filter Replacement Indicator will continue to flash for approximately 3 seconds after the buttons are released as required in step 5 above.
Sep 23, 2010 | Filter Queen Defender Air Purifier
2002 Lincoln Towncar, Audiovox asp901, customer lost her keys and had new ones cut and reprogrammed. Now the remote start will not work. The pats light flashes and it wont start with the remote. I need to...
The PATS bypass module should have disconnected during the new key programming. First, you need two programmed keys present. Put the first key in the ignition, turn ignition on, wait for security light to go out. Remove key, immediately put second key in the ignition and turn ignition on. Wait for the security light to go out, remote start vehicle with controller, immediately remove key. Let the vehicle start and run for approximately 10 seconds. Apply brake to shutdown, wait approximately 10 seconds. Remote start to test. If vehicle does not start, repeat process.
Sep 15, 2010 | Audiovox APS901 Car Prestige Remote Start
Ps3 when i press the buton turns green and after 3 seconds turns yelow and then red
Yes this is the yellow light of death and it is caused by overheating on the main chips, either use a good repair guide to fix it or send it in and get it fixed.
Sep 11, 2010 | Sony Playstation 3 (PS3) Console
VW Golf Mk4 1.4 16v Oil Light Warning on Dash
Measure your oil at normal operating temp, without the engine running of course. This will give you a more accurate reading once the oil has circulated in the system.
The system works like this:
  • With the ignition on, the oil pressure indicator light on the dash should come on and flash. Once the engine is started, the light should go out and stay out as long as the engine is running.
  • If the oil pressure drops below approximately 0.3 bar or 5 psi when the engine is running below 2000 rpm, the light will flash.
  • If the oil pressure drops below approximately 1.8 bar or 27 psi when the engine is running above 2000 rpm for more than 3 seconds, the indicator light will flash and the buzzer will sound.
If either this two warnings occur:
  • The engine should be switched off immediately and the oil level should be checked.
Apr 29, 2010 | 1999 Volkswagen Golf
Hitachi 55" when I turn it on the screen is blask and no sound.
first step to take:
refer to the user's manual to find: How to replace the lamp?
and second replace the lamp. www.andrewselectronics.com. prefer original ones.
Mar 29, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
PS3 light turns GREEN, w/ blinkin BLUE, to YELLOW, to flashin RED
it is fried and needs repairs if you break the seal by trying it yourself you void the warrany
Mar 15, 2009 | Sony Playstation 3 40GB System Console
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Epson Stylus Ink Jet Printer
1. Turn printer off
2. Press the left 2 buttons down and continue holding them down while turning the power button on. (all 3 are now pressed down)
3. In 3 or 4 seconds, the paper feed (jam) LED light begins to flash. (middle button)
4. Within 3 seconds as the paper feed button LED still flashes, release all 3 buttons together and immediately press down the ink cleaning button (left) and continue to hold down for about 10 - 20 seconds. As soon as the cleaning docking button LED flash, release it. That's it! You are now reset and ready to go.
NOTE: This is a strict timimg procedure and must be done fairly precisely in order for it to work. It may require several attempts for it to work for you. But...it does work! Happy printing!
Oct 12, 2007 | Epson Stylus Color 880i InkJet Printer
HP Officejet 4110 All-In-One InkJet Printer Logo
Ben Johnson
