Question about ASUS Eee PC 900HA 89Inch Netbook Carrying Case VersaSport Bag Black (894581674305)
Hello, I have ASUS Ecc PC 900 HA I have problems w/ monitor ...some times ok another times black .I check video card ok.What exactly problem...thanks
  • 2,567 Answers
One possibility is a defective inverter board. Another is a defective backlight bulb.
Please refer to the following article for details on ow to diagnose these faults & fix them:
http://www.fixya.com/support/r6430776-troubleshooting_laptop_power_failures
If none of these proved to be the root cause of the issue, you will have one last possibility; which is a bad or loose LCD screen cable. In order to check it, you will need to disassemble the LCD panel & make sure that the cable is not defective, & that it is connected tight on both ends.
Posted on May 18, 2011
I have recently built a new PC with an Asus P8H61-M and upon turning the PC on I am recieving no Visual on either of my monitors
Hello
If this is the first time to turn you on your computer check first the power supply of your computer if connected to their proper connector. Check your memory if clip properly in there memory slot. If you are using Video Card check it if it is properly connected to the connector. Then connect your VGA connector at the back of your computer when you have video card connect the VGA Cable of you monitor to the video card VGA output if does not have connect it with the onboard VGA output. Then press the power switch if the unit is still no visual in monitor try to search or hear a beeping sound in your computer by its on board buzzer. Find which beep you hear from your computer.
No Beep- No Power, Loose Card, or Short.
One Short Beep- Normal Post,, Computer is OK.
2 Short Beep- POST error, review screen for error code
Continues Beep- No power, Loose Card, or Short
Repeating Short Beep- No Power Loose Card or Short
One Long And Short Beep- Motherboard Issue
One Long and Two Short Beep- Video (mono/CGA Display Circuitry) Issue.
One long and three short beep- Video (EGA) Display Circuitry
Three Long Beep- Keyboard/ Keyboard Card Error
One Beep, Blank or Incorrect Display -Video Display Circuitry
Hope this help with your problem. Keep on touch in fixya
Jul 19, 2011 | ASUS P8H61M Intel H61 TX Motherboard
Hi, I have a strange problem ASUS X70IO laptop. CPU core Duo T6500, Ram 4Gb, and an nvida GEFORCE GT 120M 1gb. The Problem is that sometimes (randomly) my monitor became black with strange colored...
This is definitely a display issue ,going black could be the inverter or cable, as you are getting vertical line, it seems you need to change the display.It seems the heat produced by the video card in your system is too high if the cooling is not enough it might give you this problem due to over heating. Maximum GPU Temperature (in C) 105 C for nvida GEFORCE GT 120M.
The screen resolution for your laptop is WXGA++(1600 x 900) which is 17",for this kind of display I would say display nothing less than 1920x1080 or 1920x1200 is high defination (HD) display.
The GRAPHICS card you have in the system it has
  • Maximum Digital Resolution 2560x1600
  • Maximum VGA Resolution 2048x1536
  • Maximum GPU Temperature (in C) 105 C
  • Maximum Graphics Card Power (W) 50 W
Try to decrease the hardware acceleration of the video card and check how it works.Other wise replace the display.
Sep 30, 2010 | Computers & Internet
Problem with geforce 8400 gf video card and asus vw 193f monitor. Monitor doesnt work properly.
The native resoltion for this monitor is 1440 x 900 @60Hz for best picture. Are you able to set your PC resolution to this number?
Sep 23, 2010 | ASUS VW193T Monitor
Asus Eee pc 900. Boots up but after booting only shows black screen. How do I fix this?
If you are only getting a black screen and you are sure it's booting (how do you know?), then the problem would be the incorrect video settings in Windows. In this case, you might try starting in safe mode and resetting the video adapter.
If you see stuff on the screen as the system boots but then it goes black, then it's definitely a Windows issue.
If you see nothing at all but hear the system starting, then it's a hardware issue involving the video card.
Aug 06, 2010 | ASUS Eee PC 900 Notebook
I have 1Gb memory in A1 & A2 Power is
check your ram modules and also check if your video cards fans are running right. If both are ok then try clearing the bios it should work out
Nov 17, 2009 | ASUS NCT-D (90MSV430G0UAY) Motherboard
Hello, My Asus P4P800 SE motherboard has stopped recognizing my monitor LG Flatron 22'' . I have 2 PCs connected by a KVM switch. When I boot machine A, the monitor stays black. When I put the video card...
test both machines one at a time on the monitor without the kvm switch then hook up the kvm switch to machine A if all works well power off then hook up machine B and see what happens, it maybe that the switch is set to the other pc than the one you want to use first so the screen stays black untill its switched over
Oct 03, 2009 | ASUS Computers & Internet
Eepc 900 HA, MONITOR IS BLACK. IT LOOKS LIKE IS TURN OFF
Good day sir/maam, if you look very close to the LCD, you can see something like windows, but its really dark? chances are your LCD just lost its inverter module that powers your LCD's backlight. visit a local notebook dealer to confirm the problem. Ask if they have sources of LCD inverters for your laptop model. the service and replacement also.
Oct 02, 2009 | ASUS Eee PC 900 Notebook
Ram problem..
carthi, I do not think the problem your having currently has anything to do with your memory. If your video card was integrated into the board I might agree there could be a problem with your memory but that is not true. Your video card is an AGP8x device. Black & red colored lines can be produced from either a bad monitor or a bad video card. Your K8S-MX motherboard can not run DDR1 ( unless you mean that slot 1 DIMM you replaced). Your board only supports, 2x184-pin DDR DIMM sockets for up to 2GB non-ECC PC3200 / PC2700 /PC1600 DDR DIMM's. No video display suggests your video card may be going bad or monitor is going bad. To prove this concept, please temporally switch your monitor with a monitor you know functions correctly. If you can not temporally switch your monitor with someone else than replace your AGP8x video card. You can find up to six pages of AGP8x video cards listed at the link below.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=318&
The XFX cards carry Lifetime Warranty.
If you find you have more questions feel free to ask.
Good Luck & Kind Regards.
Mike
Mar 24, 2008 | ASUS K8S-MX Motherboard
ASUS Eee PC 900HA 89Inch Netbook Carrying Case VersaSport Bag Black (894581674305) Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
