Question about Cameras
My hitachi vhs movie vm-5000a wont record - Cameras
Benimur
  • 6966 Answers
SOURCE: recording from one vhs recorder to another.
If your plan is to copy a VHS movie to a blank VHS tape, the connections would require a 3 wire RCA connector/cable. The unit where the original movie will be played will be the player. Connect the yellow video RCA cable to the VIDEO OUT, the red & white to the AUDIO L/R OUT. On the 2nd unit designated as recorder, slip in the blank VHS tape. Connect the other end of the RCA 3 wire cable to yellow VIDEO IN, the red & white to the AUDIO L/R IN. Connect the RF OUT of the 2nd unit (recorder to the ANT IN of a TV set. Set the TV to either Channel 3 or 4 as the case may be.
If the recorder has a manual selector or via remote, pls verify that it is set to Video and not tuner (or channels) input.
Press Record on the recorder (2nd unit), press play on the 1st unit (player). The TV will serve as monitor to your copying progress.
Hope that this be of some help/idea. Pls post back how things turned out or shoould you need additional information.
Good luck and kind regards.
Posted on Nov 11, 2007
rizla
  • 1463 Answers
SOURCE: record from VHS to DVD
i should imagine so if they are not copy protected films i.e shop ones .if they are tv films on tapes etc then it would be possible to do so.
via insert the vhs tape and insert the blank dvd in to its tray
play the vhs tape and press rec to record on to dvd .
although the manual might give a better guide to doing this .
Online User Manual and Guide for Samsung DVD-V4600 DVD Player / VCR Combo by FixYa, Page #1
riz.
Posted on Mar 26, 2008
william_turn
  • 4 Answers
SOURCE: HOW DO I RECORD A DVD TO A VHS ON A VHS DVD COMBO BY PHILIPS
By using slysoft software(www.slysoft.com) you can make a copy of the disc on your computer which will remove the encryption code. Then you can take the new disc and copy to vhs.
Posted on Dec 17, 2008
  • 108 Answers
SOURCE: recording dvd's
As long as the tapes do not have a copy gaurd on them they should record to the dvd. Home moves, tv shows that were recorded or unprotected tapes can also be dubbed.
Posted on Feb 17, 2009
  • 8457 Answers
SOURCE: I have a Magnavox Digital Video Disc Recorder
U play another movie like a Hollywood movie DVD disc play on it have no squealing noises wright?Yes,than the blank DVD discs batch u have is bad.Tries buy another batch DVD blank discs,tries recording again should solved this problems.
Posted on Mar 16, 2011
How do I transfer a video from the canon VM-E2 camcorder on to a VHS tape?
No adapter needed only hook up the a/v out of the VM-E2 to the in of the VHS recorder
Nov 10, 2015 | Canon Video Cameras
I have Magnavox DVD player/vcr DV225MG9, does it record from vhs onto dvds? And if not, what do I need to get so that I can copy all of these old vhs movies to dvds?
it won't record dvd's its only a dvd player. only the vcr records
if the vhs movies your trying to record are movies like star wars and stuff like that it's copy protected and no worth the trouble. if it's home movies or something you recorded from tv they might work. if you get a dvd recorder/vhs player.
Jul 20, 2015 | Magnavox Televison & Video
I have a Magnavox Digital Video Disc Recorder & Video Cassette Recorder. Model# ZV427MG9 A. When recording from a VHS home movie tape to DVD there is a high pitch squealing sound. When playing the DVD...
Mar 16, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
I have old home movies on these tapes.. I am looking into buying the Pinacle Dazzle DVD Recorder (convert) will this convert my tapes to DVD? Does anyone know?
You already have Movies on TDK E-HG 120 VHS tapes; All you want is to Transform the media on the tapes into another record Media or on DVD.
The following process would make possible the project
1. A DVD Recorder device would transform the movies already on one media to another media.
Note: The recorder that would be acquired should have a feed area for the VHS tapes on one hand, to be played, while on the other hand, a DVD disk area from which disk medium would be recorded.
Important Notes.
The devices required to make the process achievable includes
1. The DVD Recorder or Player alsoo known with multi perpose functionality for signal convertion capability
2. The DVD recordable disks on which to record a movies onto.
Caution
The process of recording would require selection features determinable on the recorder device else would produce movies with undesireable features
For example; VHS movies are appear in decodeable formats integral when displayed on VHS players. The caution is to select a signal conversion format suitable for movies that have to transform between recordable media.
1. A DVD disk medium has formats as design specification and on which requires consideration when attempting to transfer multi media or motion pictures.
Type of formats of decodes
NTSA standards
PAL standards
Mescem standards
NOTE;
Whenever the option is available, select NTSA or PAL for appropiate code transformation
Your DVD RECORDER DEVICE SHOULD HAVE THE OPTION TO RECORD CONSIDERING MOVIES ACROSS MEDIUM TYPES
REMEMBER;
consult professional advise before acquiring an devices and mediums
If any consultation is required, refer to user guides or manuals of the devices in question.
Consult a technical expert when the need requires it.
Dec 02, 2010 | TDK E-HG 120 VHS Tape
I would like to know if it is possible to copy two vhs movies onto one dvd disk.
Yes, this should be possible, as long as the VHS movies are not copyright protected. Just make sure that the recording mode on the dvd is set to allow enough time for both movies. Just remember: the more you record onto a single disc, the quality of the dubbing (recording of VHS to DVD) is decreased.
Sep 09, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I want to put my VHS movies onto DVD's.
It will copy VHS to DVD. Provided that it is a home movie and not a copywritten movie from the store.
Jan 11, 2010 | Samsung DVD-V4600 DVD Player/VCR
I have a Magnavox ZV427MG9. I follow all directions in manual for dubbing VHS home movies to DVD but when I try to play the DVD back there's nothing on them.What am I doing wrong?
Depending on the procedure you may be pressing the record button instead of the D.Dubbing or Dubbing button. When recording from VHS to DVD you must first, load the blank DVD and VHS home movies, then play the VHS movies, then PAUSE the VHS movie when you want to START recording... then the only the you have to do is pressing the D.Dubbing button or the Dubbing button. If your VHS tapes starts to play after the Dubbing button is pressed you have been successful in Dubbing.
Aug 13, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I dont really know whats wrong with it when ii try to get it to copy a vhs to advd it wont work?
I don't know what recorder machine you have or what your hooking up to do your transferring. You cant convert VHS movie to DVD by plugging in RCA jacks from VHS player to DVD recorder. DVD reads digital and VHS does not because it reads analog and out put analog. you have to covert VHS movie into digital in order to transfer to DVD. There is a program you can buy call Roxio Easy. great stuff, cost 59.00 buck for your desk top computer, everything you need is there to transfer VHS to DVD...hope that help some, good luck.
Jul 12, 2009 | Memorex MVDT2402 24 in. TV/VCR/DVD Combo
I have recorded (on to dvd-rw) my old VHS tapes. They won't play on computer
The PC requires a compatible DVD player software! What are you trying to play the DVD with?
Sep 28, 2017 | Hitachi DV-RX5000U DVD Recorder
Cameras Logo
69 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
