Question about Canon PIXMA MX320 Color USB InkJet Printer
My printer says that it has a paper jam but it doesn't have one... the Alarm light turns on right after the printer is turned on and it says to clear the paper jam and press (OK) but even if I press ok it still doesn't go away... what should I do to be able to use the printer again???
    Top Expert:
  • Canon Master
  • 14,161 Answers
Posted on Jun 14, 2015
SOURCE: "Clear paper jam" error, but there is no jam!
try open the gear mover paper is slip. i have fix the problem same.
Posted on Apr 06, 2008
SOURCE: mp830 shows paper output slot jam
I cannot receive faxes or print anything.
The message says that "there is no paper in the machine". There us plenty of paper in the machine and I push "OK" and get the same message
Posted on Jun 27, 2008
TIPS72
  • 369 Answers
SOURCE: Canon MP610 - Paper jam error message
PLEASE REMOVE THE POWER CABLE AND REINSERT IT IT SHOUL BE OK AND IF STILL PERSIST JUST RESTART THE PC IF STILL RESIST PLEASE LET SOME TECHNICIAN TO CHECK FOR THE SENSOR FOR THE PAPER JAM ...
GOOD LUCK
Posted on Jan 04, 2009
SOURCE: says paper jam but there is none. pixma mp450
Take any paper out of the paper feeder and get a plastic ruler the softer the better lift the top of the printer up so you can see where the print cartridges are now push the ruler down through the paper feed roller be careful because you could break the rollers go from left to right right to left twice and check for any debris once you have done this unplug the printer for about 20 seconds then plug back in and let it reset then try copying or printing a doc and see how you go!
Posted on Mar 11, 2009
pineworks
  • 4041 Answers
SOURCE: Paper Jammed alarm shows, even though there isn't
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 17, 2010
I spent lots of time last night trying to get my printer to work - it did a couple times and now it won't print out again - trying to print from the computer to the printer.
IF THE PRINTER has any ALARM LIGHT. check for paper jam or BAD paper pick up roller not grabing the paper (clean or replace it).
If the printer doesn't blink ALARM. check if you have failed jobs in QUE; IF YES DELETE IT AND TRY TO PRINT AGAIN OR TRY UNINSTALL AND REINSTALL THE PRINTER DRIVER.
Dec 11, 2014 | Kodak ESP3250 All in One Printer
Paper Jam
Hi Matt,
Here's how to:-
  • First turn the printer off and on.This is known to automatically clear paper jams by pushing the stuck paper out.
  • Remove all the papers from the feed trays.
  • Remove the cover from the housing of the printer to gain access into the inside of the printer.
  • Check for the jammed paper inside and gently pull it out.
  • Press on the flashing paper jam button to make the clearing easy.
  • If this doesn't clear the jam,unplug the printer from power and try removing the stuck papers firmly.
  • Plug the printer back and try printing now.
Check out these video tutorials for more on the same.
Hope this helps.Thanks!
Dec 16, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Canon mp220 pulling paper to the right and jamming
This is caused either by a small piece of paper left in the printer after a paper jam where the majority of a sheet of paper has been pulled out but with a corner torn off and still left in the printer or it can be from a foreign object dropped into the paper feed tray. Sometimes turning the printer upside down and shaking it can dislodge the object, if it doesn't, you will need to take the printer apart to look for the problem. A few philips head screws around the printer will need to be removed first then carefully 'pop' the plastic clips apart using a small flat screwdriver.
Sep 11, 2011 | Office Equipment & Supplies
On printer error cod 6A00 displayed, on computer screen icon says service error 5C10. Have cleaned ink wells and wiped off excess ink. After cleaning far right side a long skinny black piece came out,...
Hi
Error 5C10 means a paper jam or the printer has encountered an internal error. And error 6A00 is caused due a paper jam in the sheet feed unit or near the print head. You can also reset the printer to resolve this issue. On the printer press and hold the ON/OFF button or unplug the power cord. Wait for 10 seconds, press power button ON/OFF button again. If this doesn't resolve the error code then unplug the printer for 10 minutes. Also, inspect the back panel of the printer for any paper jams. To clear the paper jams---
Turn off the printer and disconnect the power cord and USB cable. Remove the jammed paper slowly using the following procedure. Open the rear cover to check if the paper is jammed. Pull out the cassette and check if the paper is jammed inside the cassette area. Stand the printer with the rear side down, holding the document cover. Press the tabs together and pull the green cover toward you. Check if the paper is jammed. (If you were not doing Duplex printing, you do not have to follow this procedure.) Close the green cover and place the printer back to a normal position. Reconnect the power cord and power on the printer. Confirm the Alarm light is off. Load paper back into the ASF or cassette. Press to clear the message and continue printing. If you are printing from application software, follow the instructions displayed on your computer. Hope this helps... Please post back if you need more information.
Daniel
Jun 20, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Paper feeds about half way and then stops. All of the indicator lights come on.
If you get a paper jam, the Paper Jam indicator light promptsyou to clear the paper path. If the paper has just started to feed from thepaper feeder when the jam occurs, pull the paper straight up out of the paper feeder. Open and close the printer cover toresume printing. If the paper jam occurs inside the printer, remove the paper from the output bin. Turn the printeroff, then on. If this doesn't clear the jam, open the printer cover.Remove the print cartridge and cover it.For additional assistance, please contactLexmark Technical Support
Apr 11, 2011 | Lexmark Optra E312L Laser Printer
Ready and alarm lights keep blinking. will not print
Service manual: ready and alarm blinking :
Paper Jam
Clear the paper jam and press the panel button if the printer
does not automatically resume printing.
Misfeed:
Re-install the paper and press the panel button.
Clear the jammed paper inside the printer. Press the panel button
if the printer does not automatically resume printing.
check the sensors:
1) Turn off the printer power switch, open the front cover, and remove the drum unit.
2) Turn on the printer while pressing the control panel button. The Drum LED comes ON.
3) Lightly press the panel button again.
Alarm LED is ON = Front registration sensor is turned ON.
4) Press and release the panel button again.
Drum LED is ON = Paper eject sensor is turned ON.
If sensors are On, paper is being detected, Off- no paper
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 21, 2011 | Brother HL 1240 Printer
Hi, "ALARM" appear on my
Hi Good day!! Maybe you have a paper jam that cause your printer to alarm.
To clear a rear-feed paper jam:
1. Turn off printer
2. Turn platen knob to back paper out of printer. Remove any ripped pieces of paper.
3. Reload paper, turn printer back on and press FF/LOAD button.
If your paper keeps jamming the chances are excellent that you have bits of paper stuck in the paper in the paper path. To eliminate this problem:
1. Turn off printer.
2. Use platen knob to back paper out of printer.
3. Remove the paper separator.
Thank you for using fixYa
Don't forget to vote thanks!!
Nov 03, 2010 | Oki Electric Industry MICROLINE 791 Matrix...
Brother HL 1250 Laser Printer Alarm light blinks at same time as ready light and printer does not print - why?
I have saeen this happen and there is usually a paper jam somewhere in the machine. Remember, it doesn't take much of a piece of paper to jam. Use a flashlight and look inside your printer closely. Also check your toner supply level.
Oct 02, 2010 | Brother HL 1250 Laser Printer
My canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MX320 Color USB InkJet Printer Logo
102 people viewed this question
old marine
old marine
