Desktop Acer M1641: 1 IDE optical drive+ 1 SATA HDD. When SATA disabled,both drives appear in Bios n boot sequence. When SATA enbled, only optical drive in Bios. When both are present (as said before) Vista install cant continue because it does not find the HDD. Nowhere to find a detailed instruction for correct Bios settings, just specs and the like... Any help ? Regards, DH
  • 27,725 Answers
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to IDE-1 means Pri slave escape then press f10 to save to cmos to restart
you will have to have master with slave set up
you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
Hope this helps
Posted on May 18, 2011
Testimonial: "to a degree. best was to download into a diskett Nvidia Raid driver (2 files) and then xp install went smoothly. Thanks ."
I installed a sata dvd drive in my dc5100 sff the boot order recognises it as an ide drive
i dont think it matter if your system detects it as sata or ide, both interface will work in installing OS, the important thing is you changed your boot order. originally it was supposed to boot in 1st drive whichever it is hard drive or dvd drive. go to bios then follow the instruction in how to move the order of boot sequence, mine is SHIFT key then PLUS.
Feb 28, 2014 | HP Compaq dc5100 Small Form Factor PC...
Pc
start pc press F2 or Delete enter Bios, check boot priority is dvd-rw od hdd set to suit, change ide/sata cable to hdd they do burn out... make sure sata 1 hdd / or ide 1 master, for C drive. hope this helps. I/O errors can occur usually swapping order of boot can fix this...
May 30, 2013 | Acer Aspire Computers & Internet
Transfered XP to internal Sata disk with controller . MOBO A7V8X-X, BIOS version 1014. Disk is recognized during boot. Disconnected all IDE drives. System won't boot from sata disk. Booting from CD results...
get to the bios boot section
( on starting the computer hold down the delete key until the bios screen shows
in that section you will see boot preference
organize the sequence that the unit will boot from save and esc
so sata hard drive =1
cd=2
external hard dive =3 etc
Sep 11, 2017 | ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
I have to replace the hard drive in a thinkcenter s50
Remove harddrive make sure it is set to master. while hard drive is out boot up computer it will boot to the motherboard. Find the boot menu and set your cd drive as the first device. Save and shut down the computer. Install your hard drive now boot up and as soon as you can insert disk.
Sep 21, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Acer M1100 Desktop w/ a different HDD and Optical will not boot
Disconnect the hard drive and dvd from the motherboard
Power on
If you get video and cmos access power off and connect dvd
repeat and connect hard drive
getting video and cmos access has nothing to do with the hard drive...with no hard drive or optical drive you still would have access to cmos
go 1 step at a time to find bottle neck
Jul 02, 2009 | Computers & Internet
IS HD161HJ COMPATABLE WITH MS-6741
Be sure that SATA is enabled in your BIOS settings. Sometimes if the computer ships with an IDE drive, the company that builds them will disable SATA in the BIOS. Also, while you are in your BIOS, if you decide to use just the SATA drive, you need to disable your IDE and set the bios up to boot the computer from your new drive on the SATA connector.
Mar 27, 2009 | E-Machines eMachines Refurbished EMA...
My computer Acer desktop (ASE 700-ED630M) won't boot to windows. Disk boot failure, controller device 00 no device detected. This may have happened after an xp update. How can I change the bios to correct...
Initially check the connectivity of the cable, whether sata/ ide from motherboard to hdd., also do check in the bios., priority of the boot level whether your hdd is selected., in the first or 2nd., and also do check whther your hdd is detecting in the bios., if not your hdd got problem...
Mar 27, 2009 | Acer Aspire L310 - Core 2 Duo E6300 1.86...
Cannot boot up Inspiron 8200
Could be a tough one. Can you get into the bios ( F8  or F10 ) while booting and check if the HDD is being recognised in the first place ? If it recognises, then check for Boot sequence. I would also suggest to try the Recovery CD that came along with computer.
Feb 02, 2009 | Dell Inspiron 8200 Notebook
How to format SATA drive
Hi, the setting will be in the BIOS menu. switch on and hit F2 or whatever it is for your motherboard (it should say on screen). then go to the HDD settings and enable SATA
Feb 20, 2008 | ASUS P4V8X-X Motherboard
Hard drive
Have you gone into the BIOS to see if the IDE drive is recognized? If not, you may need to alter a BIOS setting to tell the system you'll be using both SATA and IDE drives. If the drive does appear in the BIOS then it may be a Windows setting that's causing the problem.
Let us know.
Dec 09, 2007 | Acer APFV MT (APFVUP5152) PC Desktop
Computers & Internet Logo
131 people viewed this question
David Payne
David Payne
