Question about Samsung SMC152F 15 inch Monitor
Where can I buy a deflection yoke for a Sumsung SMC-152F CCTV Monitor?
  • Samsung Master
  • 11,800 Answers
Because this is a color tube the yoke is not sold separately, it's permanently attached to the tubes during manufacturing. You could find a discarded unit or one sold for parts online and retrieve the yoke from its tube. There is no chance for a new one because the tube is no longer in production by Samsung so if you can't find a SH one just buy a new monitor .
Posted on May 18, 2011
  • Azrael SRL May 19, 2011
    Could you please tell me what is wrong with my answer?
Lg tv ic 9370 vertical line and no rastar & retrace
Absence of horizontal scan signal to the deflection yoke. Check all the connection to the deflection yoke. If found OK, the deflection yoke winding [horizontal] is open. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 26, 2015 | LG Televison & Video
My crt acer ac512 monitar only centre line view,c"not full view why?
there are several reasons why picture of crt monitors did not display good picture. if your monitor had horizontal line at the center of the screen?...the faulty is in the vertical deflection, check the vertical oscillator also the fusible resistors & capacitors around that section. if there had vertical line at the center of the screen?..check the horizontal deflection, horizontal output transistor also check the YOKE.
Jul 31, 2014 | Acer Computers & Internet
Where can i buy lg 29 ultraslim tv deflection yoke?
Contact the authorized service center for LG, to buy a genuine one. Electro help
Jul 22, 2014 | LG Televison & Video
Horizontal driver too hot, no eht, power suply is ok.
Hello
If horizontal output transistor gets over heated, the either LOT or Deflection Yoke may have some short in it. You just pull out the picture tube base card from the picture tube neck, and place it somwhere. so that it never gets in contact with any other circuit parts of the TV. Pull out the deflection yoke plugin and put the tv ON, and see whether it overheats now or not. If it overheats no also, LOT is defective, and should be replaced with a same type and number. If it does't overheat now. put the unpluged yoke connection, and switch it ON. If it gets overheats, there is some short in between the horizontal winding section inside the deflection yoke. Caution:- Never place the picture tube base board connected to it, while deflection yoke is disconnected. OK.
Dec 06, 2010 | Televison & Video
Horizontal screen size is too large all drivers are installed on winxp
This is Monitor Problem.you need an monitor service engineer.the problem is in Horizontal Deflection yoke/Horizontal output transistor section.
Nov 14, 2010 | LG Studioworks 563N 15" CRT Monitor
Emerson EWF2704. Plug it in and a high pitch squeal is coming from the board. Originally tv had no vertical now it won't come on at all. Thought there were bad solder joints and re heated them but still...
Hi.
The problem is likely the deflection yoke.
Try to understand if the noise is coming from the flyback transformer, from deflection yoke and ferrite beads in the horizontal deflection circuits or from one of the boards.
If the problem is one of the boards, then the noise may be produced by a melting capacitor.
If problem is the deflection yoke, then the most common fault is still a cold solder joint. Rather than randomly heating all joints you need to check continuity (read Ohms to verify circuit is closed) to ensure that the solder joints are fine.
Here a service manual
Jun 01, 2010 | Televison & Video
I have one red verical line on my monitor. Is there a way to fix it or is it better to plan on buying another monitor?
If the monitor is a conventional CRT type:
  • if the line is top to bottom, then the horizontal deflection yoke and/or an HV capacitor is faulty;
  • if the line is left to right, then chances are the vertical amp IC is defective.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 22, 2008 | Computers & Internet
Does the TOSHIBA TA8445K Vertical Deflection IC fails when the Deflection Yoke is Dirty?
hola tengo un tv onwua que no me habre el verticar ya revise los voltajes y estan bien pero en la pata 11 tengo solo 7 voltios en ves de 12 voltios cual puede ser el problema de mi parte muchas gracias.mi email es ruben_148_2@hotmail.com.
Mar 05, 2008 | Sharp Televison & Video
Cctv monitor
Sound like the vertical deflection circuit is defrctive. Check for cold solder around the vertical IC, Check the Diode and cap that supply power to the Vertical IC. If it still do not work, change out/ replace the virtical IC.
Jerome
Dec 21, 2007 | Computers & Internet
Mitsubishi WS-55807 parts in a VS-60603?
I own a Mitsubishi WS-55807 55 in. for parts if you are interested. Please contact me back if interested. 727-773-8208 Nicole
Sep 29, 2007 | Mitsubishi VS-60603 60" Rear Projection...
Samsung SMC152F 15 inch Monitor Logo
90 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
