Question about Fujitsu LifeBook A6020 PC Notebook
My Fujitsu A6020 notebook laptop has a black screen after booting up. I entered the Bios Menu where it asked for a password to be entered, so I established a password. Then when I rebooted it asked for the password and didn't accept the password. After several attempts it sounded an alarm, so I turned off the pc. Now it beeps 3 times and the screen is black with the fan humming away. How do I correct this pronblem?
    Top Expert:
  • Fujitsu Master
  • 12,962 Answers
Remove the cmos battery for a few minutes and move the cmos jumper (If one) & Disconnect the power supply. While in that state press and hold the power button to discharge all power from unit. Then reinsert the battery and your cmos should be returned to default settings.
Posted on Jul 12, 2017
  • 2427 Answers
SOURCE: Starts to the Fujitsu Screen then nothing
No Actually its fixable
There are a number of issues that can cause this but all of them are hardware related.. Mostly its eighter the hard drive or them main board (bios)
1.) Open up the laptop
You do this by removing the hinge covers, then removing the
face panel(part with the power button)
remove the kwyboard and you wiull have axcess to it..
2.) there is a battery on the main board, simply disconnect it, then remove your laptop battery and hit the power button(switch now) seven times.. Hopefully this will discharge any remaing power and reset your bios..
now try booting, if that works, simply enter your bios(setup) and load the optamised defaults then save and exit..
If that fails, Open back up the laptop again and try disconnecting the hard drive.. If it boots and says no boot disc, then your hard drive is defective and needs to be replaced..
If all that fails you will need to replace your mainboard.. if you are not qualified enough to do this i suggest you take it to a technician,,, Let me know what happens and if you need additional information, just post your question here and i shall reply asap
Posted on Jan 17, 2008
gnkanang
  • 63 Answers
SOURCE: CRASH FUJITSU LIFEBOOK
hi
Run the pc in safe mode and restore it to a later date. that will solve the problem
Posted on Mar 25, 2009
mithunsree
  • 32 Answers
SOURCE: fujitsu a6020 notebook harddrive password help
Rinstall os
Posted on Aug 11, 2009
SOURCE: Lifebook Fujitsu A6020 does not boot up. Hear hard
Hey, i have exactly the same problem with exactly the same computer.
Did you repair yours?
Posted on Feb 24, 2010
elsuirad
  • 26 Answers
SOURCE: fujitsu A6020 powers up but
is that brand new (laptop) use a USB or Flashdrive that has a bootable or windows installer, usa that.
Posted on Aug 16, 2010
Fijustu ah530 corei 5 bios password
BIOS on a Fujitsu C-Series LifeBook b> Resetting the BIOS system of a computer can help revitalize the computer's usage. Oftentimes computers are "broken" when they are misconfigured in the BIOS menu of the computer before it boots up. When the settings are improperly selected, the BIOS prevents the computer from working properly. To get the computer back up and running again, the BIOS needs to be reset. The Fujitsu LifeBook C2111 has its BIOS system located on the motherboard beneath the keyboard.
Turn the Fujitsu laptop over with the computer powered off. Remove the AC adapter and push the battery release latch in and pull the laptop battery out of the Fujitsu. Remove the screw holding the hard drive in place and slide the cover off of the laptop. Remove the two screws underneath the cover that holds the hard drive onto its bracket. Slide the hard drive out of the laptop. Turn the computer back over and lay the screen down so that it is parallel to the surface on which the laptop is resting. Remove the small screw above and to the left of the keyboard with the Phillips screwdriver. Push the keyboard toward the screen until it disengages. Fold the keyboard over the screen and rest it there with the keys facing the screen. You will now see the motherboard of the Fujitsu C2111. Locate the small, round lithium-ion battery on the motherboard and remove it. This is the BIOS battery that stores all of the settings and password of the BIOS when the computer loses power. Hold the power button in on the computer to drain the BIOS system and leave the battery out of the laptop for at least 30 minutes. Place the BIOS battery back into the motherboard and reattach the keyboard. Tighten the keyboard screw that you removed earlier, and turn the Fujitsu back over and reattach the hard drive along with the covers for the hard drive and RAM. Push the computer battery back into place and attach the power cable to the computer. Turn the Fujitsu back on and the BIOS menu will be reset.
or b> Start the computer and press the "F2" key while the system boots, if the computer is currently off. If already on, restart the computer and press the "F2" key while the system boots. The BIOS setup utility will appear. Press the right arrow on the keyboard and scroll over to the "Exit" tab. Press "Enter." A drop-down menu will appear. Scroll down to "Default Settings" using the down arrow key and press "Enter." A dialog box will appear, asking if you are sure you want to load the default settings. Scroll over and select "OK" using the arrow keys and press "Enter." All BIOS settings will reset to the default value. Scroll back to the "Exit" tab using the arrow keys and press "Enter." Scroll down and select "Save Changes and Power Off." Press "Enter." The computer will save the default BIOS settings and power down. Fujitsu Lifebook T Series b> Restart your Fujitsu Lifebook T Series computer. Press "F2" as soon as the computer starts booting. Enter your current BIOS password if prompted. Use your right arrow key to select the "Security" menu. Use your down arrow key to select the password you want to reset. Press "Enter" to select the password. Enter the current password when prompted. Enter your new password or a blank password if you want to clear the password. A blank password resets the BIOS password completely, meaning you do not have to enter a password to enter the BIOS or boot your computer. Press "Enter" to save your password settings.
Repeat the process if you have multiple passwords set. Press "F10" to save all settings and exit the BIOS.
Jan 30, 2013 | Fujitsu LifeBook AH530 NoteBook
Jan 17, 2008 | Fujitsu LifeBook N3520 Notebook
My fujitsu laptop s7110 i cannt enter bios its asking password .how can remove this plz give me a solution
To reset the BIOS password read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Nov 01, 2010 | Fujitsu Siemens LifeBook S7110 Notebook
Fujitsu A6020 powers up but not booting. Battery's fine. Disk not reading restore cd.
Aug 16, 2010 | Fujitsu LifeBook A6020/C Notebook
When I ran the test on the computer it says error code 00410001 "may be hardware error on HDD"? The computer barely stays on, it shuts off randomly, wont even start up and just has a black screen with a...
Go into the BIOS and reset it to defaults. Then reboot it and see if the message goes away. If it doesn't then try another hard drive in the laptop, if the message doesn't go away at that point then the controller on the motherboard is bad. In that case the motherboard would have to be replaced.
Jun 02, 2010 | Fujitsu LifeBook A6020/C Notebook
When I switch on power, system will ON but black screen some times its ON with Fujitsu logo then a strip of white line & afterwords black screen
At boot up press F2 and enter the BIOS. Here from the first Menu see if the HDD is being read as that seems to be the problem that you are facing. The control is not reading the HDD and hence it does not go beyond the Fujitsu Logo. If the HDD is being read then probably the Windows has gone corrupt and would need re installation.
If HDD is not being read then you must show it to a professional.
Dec 26, 2009 | Fujitsu LifeBook E7010 Notebook
I turn my computer on and
Hi there
The black screen that appears before the booting asking for password shows that you have activated security password through BIOS settings.
If nothing is working implies that you don't remember the password or activated it accidentally.
The only solution to your problem is to get into the BIOS settings an deactivate the security password or reset the BIOS settings.
thank you
Jul 24, 2009 | Toshiba Satellite A135-S2386 Notebook...
Locked out of Toshiba laptop, Help!
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Some Toshiba bios passwords can be reset using the Key Disk.exe utility, to do this you need a 1.44Mb floppy disk.
Format the disk to be BOOTABLE using Windows and then with a hex editor, change the first five bytes of the second sector to 4B 45 59 00 00.
Then put the floppy into your machine and boot it up, you’ll be asked for a password, just press Enter. Then when you’re asked to set the password, type Y then Enter, this will get you into the bios configuration where you can then type in a new password.
Mar 26, 2009 | Toshiba Satellite A135 Notebook
Fujitsu LifeBook A6020 PC Notebook Logo
179 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
