Question about Shimano Tiagra ST-4500
I need the schematic to put back together the left shifter. i think i have a broken spring. i have the shifter more than 50% taken apart but i do not want to go any further without the schematic to put it back together.
    Brigadier General:
  • 8,546 Answers
I removed the handle to clean under it and the parts came out and I cannot figure out how to put it back together.
I haven't seen any Kitchen Aid processors where the handle part of the bowl is dismantlable. I think you will find it is broken and you are up for a new bowl. The cover is normally glued on with no intention that it was ever going to be taken apart.
Sep 03, 2015 | KitchenAid KFP0711 KFP0711OB 7-Cup Food...
My shifter is not changeing the gears how do i fix this problem?
The cable my have come off at one end or the other or broke somewhere in between inside the sheathing.
Jul 30, 2012 | Cycling
I have a model 21a- 410-062 MTD tiller that i had to replace the shifting forks on. The trouble is I cannot figure out hoe to get the shifting clutch collar back on the shaft or i don't know how it goes...
there's a pretty good schematic here:
http://www.m-and-d.com/pdfs/MTD/410-420.pdf
and a reference diagram here:
http://int.custhelp.com/ci/fattach/get/15094/1173195151/session/L2F2LzEvc2lkLzJPNmdRanNr
I've had mine apart twice, first time to replace the shifter fork, 2nd time to find why it keeps popping out of gear.
Apr 20, 2011 | Garden
My daughter pulled to hard on the ceiling fan pulling out the chain. i have taken it off and apart, nothing appears to be broken but im trying to figure out how to put it together so it retracks, i...
Don't even bother to repair the pull chain switch, get a new one at KMart, HomeDepot or similar store for less than $2.
Two times I've repaired one, it comes apart when I need it the most.
Good Day! Don't forget to rate this post!!
Sep 09, 2010 | Vacuums
I have a 1986 Yamaha YFM80 4 speed youth model and the choke is taken apart. I need a schematic or directions to put it back together again. Like the spring; how many times is the spring wound up when...
the spring has to have just enough tension so when engine starts the vacuum in the induction tract can open it ,other wise engine will stall with no air getting in
Jul 05, 2010 | Yamaha V Star Silverado Motorcycles
MTD Series 410 rear tine tiller. Tines won't engage.
I had the same problem. After splitting the case, I found that the shifting fork was bent and the pins that move the shift collar were worn. I made new pins for and reinforced the shifting fork, put it back together and if worked for a few minutes until it would jump out of gear while tilling. I would try to hold the external shifting rod down so that it would not jump out of gear but eventually it quit working completely. I tore it down again and the pins were already work out. I ordered a new detent ball and spring for less than $10 including shipping. This seems to have cured the problem. Apparently the detent spring was weak which allowed the shifting collar to disengage from the drive gear when under load. The original spring had been replaced with a new part number so it may have been made stronger. Tearing one apart is not easy but is certainly doable. To make it easier, put the nuts back on the bolts from where they came. Also get the parts manual picture to help with reassembly. Be careful with the case gasket. It costs a ton for a new one but since the grease is so thick, you could probably silicone it back together if you destroy the gasket.
Apr 19, 2010 | Mtd Garden
Thumbwheel of left side of IQUE3600 needs re-assembly
I have this same issue. Not sure yet what the answer is, but you will have to take it apart. The spring lays on top of the thumb wheel and the ends fit into notches so you have to seat one and then pull the other end back and up till it will seat in the notch. Then you have to place the thumb wheel back in place and put the silver cap on top. I had it all together but putting the unit back together just right will be difficult as my thumb wheel isn't seated right.. Guess you just have to keep at it till you line everything up correctly. I also had the problem with the brightness not being adjustable but haven't fixed that yet.
Mar 12, 2010 | Garmin iQue 3600 GPS Receiver
How to re assemble recoil spring on macallister pro 50 lawn mower. I have inherited this machine which has only been used a few times and the previous owner has given up on it. The whole recoil housing has...
Hello there it is hard to do but with patients you can put a loop of tape or a cable tie around the start of the coil and everytime you rewing the coil you can put it under the loop to keep it in place hope this helps
Sep 26, 2009 | Garden
Putting on belt
put it around drum,then around motor pulley, then idler pulley with spring attached to, move it forward and slip belt onto idler pulley and release and belt should become tight,then self align belt by manually turning drum before putting unit together
Sep 13, 2009 | Crosley CDE6000 Electric Dryer
Shimano Tiagra ST-4500 Logo
1,067 people viewed this question
Top Shimano Cycling Experts
Michial Gueffroy
john h
Paul Bade
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
