Question about RCA D52130 52" Rear Projection Television
RCA D52130 My problem started with the picture starting to fade and then would go to black. I would turn it off, and then it would come back. I might have a pictue for a couple of days, I would repeat the same process and it would work. The other day it went out and I have not been able to get picture back. I have sound all the time. Any help would be greatly appreciated and loction of parts would be a great plus. Thanks, Greg Wright
  • callawayx250 Aug 14, 2008
    do you know were to purchase, is it hard to do, is it a commen problem?
    Could not ask for better here. Wonderful response time. Thanks Alot.
    Master:
  • 521 Answers
Problem in the powersupply boards is get it replaced it will work properly for sure.
Posted on Aug 14, 2008
  • 2 more comments
  • tech expert12 Aug 14, 2008
    check whether any ic is short or any capacitor is buldged up get it replaced it will work properly.not too costly.if you know soldering.
    yes it is very very easy you can get both the ic and the capacitor at the electronic shop you should know the soldering procedure properly.or you can call the electric repair person he can also do the normal soldering.
    it looks like small and medium sized tiny drum.
    ic looks like black small rectangle with thin silver or steel colour legs in it if it seems like it is burned or looks like fused up you have to change that.thanks.do it properly.do not forget to rate this solution.
SOURCE:
Only one channel does not have volume (sap) appears??
My rca d52130 tv want show the menu for my cable. the picture is blared with no colorls. My kids hit a button on the black or gray remote control and the picture is showing but real bad picture. Please help me because to get it fix will cost $500. and I can't afford that right now.
Nov 01, 2009 | RCA F25648 25" TV
I have a rca hd56w66, my screen shuts off but the audio still stays on. For a few days, it started fading to orange and then to green and then out to black. After about a minute, the picture would come...
Sounds like you lost the power supply to guns, now this doen't mean you have to go looking for it, you will need a repair person to fix it. Word of advise, if you haven't had one of these fixed before it can range in upwards of 600.00 or more to fix now days.
Oct 09, 2009 | RCA HD56W66 56" HDTV
52" rca rear projection
the picture is bent inward and shadow looking sides are cut off.
Aug 10, 2009 | RCA D52130 52" Rear Projection Television
Still can,t find fuses in back amp 250v and 6.3
I have only found one fuse on this, but there's probably others. The one i found was to the left and behind the plug. you have to take off the black plastic covering the plug, and all the other connections. You can see the fuse if you look between the bottom of the vertical and horizontal circuit boards in the corner.
Mar 02, 2009 | RCA D52130 52" Rear Projection Television
I have sound but no picture?
i setup a remote code on the remote so the tv goes on /off and the volume but no picture on screen how when i put the dvd player i can see the movie but noy regular tv please help
May 08, 2008 | RCA D52130 52" Rear Projection Television
RCA D52130 CHASSIS CTC211A PROBLEM
Do you hear a click when you try to power it up? If no you may have a blown fuse. But if the fuse is blown chances are a short has caused that condition. Check the fuse to see if its blown and let me know and I will try to help you out with it.
Mar 27, 2008 | RCA D52130 52" Rear Projection Television
RCA 32" TV - Model #32F531T - Faded to black
Isolate filament voltage from CRT,i.e. unplug Crt socket from pix tube.Measure filament voltage on CRT PCB.If present,suspect bad pix tube.If missing,solder any/all connects in filament circuit,meaning CRT board first then main PCB.
Aug 08, 2007 | RCA 32F531T 32" TV
RCA D52130 52" Rear Projection Television Logo
175 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
