Problem with IDS_CL_LOAD_FAIL - Computers & Internet
DLG2351r model LG front load dryer wont start also says CL
It seems as though your machine's door switch is faulty as the machine will not start if this switch does not operate properly.
The reason that I suspect the door switch is because the CL error code stands for "child lock".
Check the door switch for continuity and condition, replace if faulty.
Oct 03, 2014 | LG Dryers
Driver download
http://members.driverguide.com/matches.php?h=0f3b0815dd5cd30921c195faa3a722ee&ids[0]=390004&ids[1]=390006&ids[2]=390024&ids[3]=390012&ids[4]=390020&ids[5]=390010&ids[6]=390027&ids[7]=390005&ids[8]=390021&cid=521&model=P4ES
FIND THIS.
Dec 10, 2013 | Iwill P4ES Motherboard
My 2001 Acura CL Type S won't start. It has been
You said that you replaced the battery so in either case of new or another battery have a load test done as what you describe indicates a failing cell in the battery or loose t/dirty terminals.
Sep 22, 2013 | Cars & Trucks
Message CL has appeared whch is child lcok. How
hold down the rinse and prewash buttons at the same time for 3 seconds , do the same to start it also.
Nov 12, 2009 | LG WD-1045FH Front Load Washer
Problem with installing wireless card on a Emachines G520 with xp
by the device id your device is
DELL WIRELESS 1395 WLAN MINI-CARD for this go here
but emachine G520 xp sp2 driver are
here
and injoy
Jan 21, 2009 | Computers & Internet
1995 VW GOLF CL. I NEED TO CHANGE GLOW PLUGS, HOW DO I DO THIS?
Glow plugs are a lot like spark plugs and change much the same way.There not cheap so just make sure that is your problems as the controller can also fail. especially if the all went down at once.
Dec 06, 2008 | 2002 Volkswagen Jetta TDI
Error Message CL in the front panel
Error message CL solved. CL means child lock. To deactivate press two linked buttons (on my machine the right options button and the temp button) together for a couple of seconds.
Mar 29, 2008 | LG WM-12230FB Front Load Washer
Computers & Internet Logo
321 people viewed this question
David Payne
David Payne
