Question about Vacuums
I purchased a Dirt Devil Venturi Vacuum kit for pool and spa but had no directions. I am wondering if it is used with water in the spa and how it gets rid of the dirt. Thanks
  • 1 more comment
  • Anonymous Aug 21, 2008
    I also
    I brought a dirt devil venturi vacuum for pools and spa's but it has no direction. I am not sure how to finish putting it together or how it works. Can someone please help
  • gigglemite Sep 01, 2008
    I have the same problem. If anyone knows how to put it together, please share.
I had the same problem but so long after the listing of these other posts, it may only be helpful for new inquiries. I found the website for the manufacturer & they have a 1 page instruction sheet for this vacuum.
http://www.glipoolproducts.com/assets/manual/accessories_blossom&venturi.pdf
or try this link and look under Dirt Devil Accessories.
Posted on Jul 27, 2009
I just bought one and I know that when you use it the water pressure sucks up the debris and pushes it into the bag. My question is how do you put it together????
Posted on Aug 18, 2008
Brush roller won't turn
Hey, this is Jeremy with Crucial Vacuum,
There are 2 potential reasons as to why your Dirt Devil AccuCharge roller brush is not working:
1) The roller brush may be blocked by debris that was picked up by the vacuum. To remove the blockage, switch your vacuum 'OFF' and unplug before proceeding. Then, lay the vacuum down and try to remove anything that is lodged in the roller brush.
2) If the vacuum cleaner brush is not spinning the belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace if needed.
You can purchase replacement parts for Dirt Devil direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/dirt-devil.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Jun 26, 2015 | Dirt Devil AccuCharge 15.6-Volt Cordless...
Dirt devil powerburst isn't spaying cleaner anymore
Hey there Angie, this is Jeremy from Crucial Vacuum,
Sorry to hear you are having some trouble with your Dirt Devil Powerburst. Below I have listed some things you can check on to remedy the situation.
  1. Make sure that the two rubber gaskets are attached to the removable tanks (and seat properly on them).
  2. Make sure that nothing is clogged in any of the tubes or chambers.
  3. Make sure the sprayer is not clogged. Over time soap residue can harder and build-up preventing the solution to pass through.
  4. When you turn on the machine, do NOT spray it. WAIT. Run it for 60 seconds in order to prime the pumps.
  5. If that fails, you can try running a mixture of water and vinegar to try to clean the lines.
You can purchase replacement Dirt Devil parts direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Jeremy Lerner
Jun 25, 2015 | Dirt Devil Vacuums
My vacum cleaner won't pick when attached to the parts or bottom
Hi, it's Allie from Crucial Vacuum.
It sounds like your unit may have a blockage. Checking your hose for any blockages is very easy. Remove the hose from both ends and check for blockages, any leftover debris or clog will not allow the unit to have suction.
You can purchase direct your replacement belts, filters and rollerbrush from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/dirt-devil-f1-kit.html
Alejandra (Allie) Sepulveda-Rivera
Sep 04, 2014 | Dirt Devil Breeze Bagless Cyclonic Upright...
How to replace filter
Hello! Happy to help with that. To replace the filter simply twist the dirt cup lid off of the dirt cup. Remove the old filter and replace with the new one. Twist and lock the dirt cup lid back on. This vacuum takes a Dirt Devil F1 filter. Follow the link below to purchase the filter directly from dirtdevil.com. Thanks!
F1 HEPA Filter
Aug 11, 2014 | Dirt Devil Featherlite Bagless Vacuum...
Dirt devil featherlite vaccum were does the extra hose go?
Hi, it's Jeremy from Crucial Vacuum.
Attached is a copy of the user's manual for the Dirt Devil Featherlite Bagless Vacuum M085845. You can find a diagram of your vacuum on page 11 depicting where each part is located. The 2 hoses for your vacuum are listed as numbers 22 and 23.
http://dirtdevil.com/file/898/
You can purchase direct your replacement Dirt Devil parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Jeremy Lerner
Aug 04, 2014 | Dirt Devil Featherlite Bagless Vacuum...
Dirt Devil Rampage Robotic Pool Vacuum wont climb side and stays in deep end all the time?
If a pool vac is not climbing the side of the pool this is one of several things main things . a blockage in the pipe (try inserting garden hose to flush it. or insufficient vacuum at the skimmer box (Test with your hand) or a break inside the unit - if the third, you probably need to take it in for repair.
May 17, 2014 | Dirt Devil Rampage Robotic Pool Cleaner...
Dirt devil pool vacuum slow stays on pool sides
go to http://dirtdevil.com/support/ get the support section and download manual, troubleshooting, video for troubleshooting, and fix it.
God bless you
Sep 16, 2012 | Dirt Devil Vacuums
Replacing the drive track.
The tracks for the Dirt Devil Rampage pool cleaner are the same as the AquavacTigershark. Simple look for the parts for the Tigershark. Its the same exact thing.
Jun 20, 2010 | Dirt Devil Rampage Robotic Pool Cleaner...
Dirt devil easy steamer need directions to use
Thank you for responding to my question. I should have spent some time really looking at my little machine. It wasn't hard to figure out -once I found and read the back of the cleaning solution bottle and tried my luck following the water to cleaner ratio.. Opening, adding the cleaning solution and water and re-closing the reservoir was pretty easy. Everything worked out fine...and my carpet is...spotless. Thank you, Cmarie
Mar 27, 2008 | Dirt Devil Easy Steamer Upright Wet/Dry...
Vacuums Logo
657 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
