Question about Garden
Just changed a blown fuse on my Mastercraft 2G air compressor. The compressor won't start, though the on/off light is on. Is there a reset button? Thank you
2 Suggested Answers
  • 1015 Answers
SOURCE: mastercraft model#820250 air compressor only
I think you are going to need to replace your regulator.I think true value and ace hardware handle mastercraft so you can give them a try for parts.
Posted on Aug 29, 2011
Mastercraft air compressor parts
just get some ptfe tape from and plumbing shop and wrap the plug
May 19, 2014 | Air Tools & Compressors
Immobilizer won't reset on 2002 kia Rio
put fuse back in disconnect batt wait 60 seconds re attach, when the horn starts honking lock and unlock drivers door with the key while doors closed window down. get in car and start it, should be fine now.
Mar 12, 2013 | 2002 Kia Rio
Power door locks won't work and the instrument pnnel lights won't turn on. I replaced blown fuse a 20mp one in position 14 I believe. worked ok till I tried to lock the doors, the fuse blew
Hello. Try looking at the black earth that goes from the drivers door and into the A frame which is covered in a rubber sheath. The wire can break after opening and shutting the door over several years and as it's normally the thicker wire is more prone to break. Also check the other wires visually for any chaffing and tugging on each wire. If more electrical parts start failing, air con blowers etc it will be an earth. Hope this helps
Nov 03, 2012 | 2002 Dodge Neon
Jenn air. Quiet seriesii won't start. Lights on panel flashing. Tried turning off power for fifteen minutes at breaker.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 28, 2012 | Dishwashers
A/cfor1987bmwdoes'ntstart
have you checked fuses?
If no blown fuses check for power at A/C clutch.
If your uncertain of voltage you can jumper a wire from positive lead on battery to the a/c clutch (while engine is running). If it runs then your problem could be in the wiring.
Jun 17, 2012 | Air Tools & Compressors
Mastercraft model#820250 air compressor only goes to 50psi won't shut off (no air leaks)
Aug 29, 2011 | Garden
My mastercraft 10" table saw
Reset button on the motor?
Aug 27, 2011 | Saws
The air conditioning unit won't work. The lights behind the panel light up, and when I turn the air all the way to cold, you can hear a click like it wants to go on, but can't. Do you know how to...
Check the fuse block. Sounds like the compressor fuse is blown. Maybe a 32Amp. It's a biggie. Maybe looks like a black relay in the engine compartment on the left side along with an array of large fuses. You can check the fuse box inside the car as well, but those are controlling smaller items like lights. The big boys are in the engine compartment. Also check for loose wires around the AC compressor and make sure the belt is not broken or missing.
May 25, 2011 | 2004 Saab 9-3
Garden Logo
74 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
