Question about Toshiba TEC B-572 Printer
The film take-up stop & film supply keep working
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Toshiba TEC Expert
  • 142 Answers
Check in your printer driver if you are not in direct thermal.
Else you have a rewind motor out of order
Posted on May 19, 2011
A clip came off my Cannon sure shot 150u on the left side and it wont wind the film, how do i fix?
hi, this is film camera uses 35mm film , the clip is used to keep the film wound tightly on the take spool, no problem , use ultra thin cello tape on the tip of the film and attach it to the take up spool , ensure that the rewinding stops as soon as the counter reaches 0 or 1 , in case the camera does not have switch, remove the battery on time hope this works
Aug 31, 2016 | Canon Cameras
My camera will begin to turn on but the flash settings won'
is it the auto film load feature on this camera doing this ??? it maybe the type of film u use , most auto loads are not to forgiving on the different types of film , I had this problem as I still use a film camera a lot for infrared photos (digitals too expensive ) and have found that its real picky on whos film I use to weather it works or not , as on some brands of film it just goes on and on and never stops , the only way I can save it from being ruined is to tell it to rewind , it then sucks all the film back into holder and I try it again ,sometimes works sometimes no
Aug 17, 2016 | FUJIFILM instax mini 8 Instant Film Camera
My remote has stopped working for my HTS3520 blu ray, how can I select language choice & start films without it?
If the remote really has stopped working, the practical solution is to obtain a replacement Philips remote that will control all player functions.
Feb 02, 2015 | Philips Televison & Video
Idles rough
You should rebuild the carb if you can. Most likely the needle valve is getting stuck in the port. This can be caused by old gas left in the carb that evaporates and what is left is a yellowish sticky film that keeps the needle valve from sliding smoothly. If this is the case you will also find that yellow film on the bottom of the carb bowl also. Quick fix is to use Gumout carb cleaner. Spray in the carb wait a while and try to start it up. May take a while. once it starts keep spritzing Gumout in the carb little by little and see if this works. If not rebuild the carb. Hope this helps. Lastly before you put any of your equipment away that have gas, let them run out of gas first. Disconnect the supply line and let it run till it stops.
Dec 22, 2013 | Honda Garden
I have a 36 shot film and it stops at 26 shots , need help
At first glance it seems your camera may need repair. First thing I would do is clean the contacts that read the cartage. Put in a cartridge that you can afford to play with. Put the lens cap on keeping light from exposing the film, fire off the frames until it stops. If it still stops at 24-26 rewind the film (hope you have a film puller). Open the camera back fire off some shots then replace the film trying it again. If that does not work the counter is in need of repair.
However, I would not repair it I would purchase another film camera such as the Nikon N80 and if you can afford it the F100. Both are much superior to the N65. You can find N80 at KEH.com for less than $100, As of today, 2013-10-17, I see one in E+ condition for $76, a N65 for $14.
Sep 13, 2013 | Nikon N65 35mm SLR Camera
I have a poloroid camera and need film size 600 and the cost price.
Original Polaroid manufactured film is long out of production and now very expensive and unlikely to work due to flat batteries and stale chemistry. Chemistry may be fresh if the film has been cold stored, but cold kills batteries even faster so such films can only reliably be used in cameras modified to accept an external 4.5v dc power supply.
You can buy new photo packs from "The Impossible Project". Click on the link to see details and prices. Note that this film is not exactly the same as the original material, and if you wish to keep images permanently you must scan them as they will fade quickly.
Aug 02, 2011 | Polaroid POL642956 Film Camera
I HAVE A CANON IR 3300 MACHINE I HAVE ERROR E00000-000
WHAT: Either the main thermistor doesn't attain 30?C 1 second after the power switch is activated or it doesn't attain 70?C 2 seconds thereafter.
WHY: It has a faulty fixing film unit, lack of connectivity with the main thermistor, lack of connectivity with the fixing heater, a faulty main power supply PCB, or the DC controller PCB is faulty.
NOTE: You can reset the error by performing the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
CONNECTOR FIX: Make sure that the connector of the fixing assembly is seated.
A. main power supply PCB (J8) relay connector heater
B. DC controller PCB (J320) relay connector thermistor
FIXING FILM UNIT (THERMISTOR) FIX: With a multimeter, check the interval between pin 1 & pin 2 & between pin 3 & pin 4 of the connector (4-pin) of the thermistor for electrical continuity. A result of ?? means that the circuit is open (lack of connectivity). Resolve this by replacing the fixing film unit.
MAIN POWER SUPPLY PCB, DC CONTROLLER PCB FIX: Press the Start key. If the drive voltage of the heater is supplied by the connector J8 of the main power supply PCB, then the main power supply PCB should be replaced. If not, then the thermistor control mechanism is faulty & the DC controller PCB should be replaced. Use the following to ascertain this:
Main heater: between J8-1 (FSR1) & J8-5 (FSR COM)
Sub heater: between J8-3 (FSR2) & J8-5 (FSR COM)
Sep 25, 2010 | Office Equipment & Supplies
C2557 error message
If is a BW 350 go to service mode ( stop 0 0 stop 01) counter apecial part counter reset drum and dev switc off the very quiqly service mode function run f8. Did you replaced drum and developer?
Aug 11, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
System Error E000 and E003
E002 Error code details Heater temperature error (fails to reachspecific level; inadequate increase)
0000 The temperature of the fixing film is as follows:
1. has exceeded 100°C, but does not reach 115°C within 1 sec thereafter.
2. has exceeded 140°C, but does not reach 150°C within 1 sec thereafter.
3. has exceeded 160°C, but does not reach 165°C within 1 sec thereafter.
Main cause
 The fixing film unit is faulty (i.e., the main thermistor TH1 has poor contact, or the fixing heater is faulty). The main power supply PCB is faulty. The DC controller PCB is faulty.
Caution
 To clear the error, execute the following in service mode: COPIER>FUNCTION>FCLEAR>ERR.
Action
 See the description for E003. E003 Error code details Heater temperature error (abnormal drop; low-temperature detection)
0000 The main thermistor reading is lower than 140°C when paper is moved.
Main cause
 The fixing film unit is faulty (i.e., the main thermistor (TH1) has poor contact or has an open circuit; or, the fixing heater is faulty). The main power supply PCB is faulty. The DC controller PCB is faulty.
Caution
 To clear the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
Action
1. State
 Turn on the power switch, and clear E002/E003. Thereafter, turn off and then on the power switch. Does the fixing heater operate?
 NO: See "The fixing heater fails to operate."
2. Wiring
 Is the wiring from the DC controller PCB to the fixing film unit normal?
 NO: Correct the wiring.
3. Fixing film unit, DC controller PCB
 Try replacing the fixing film unit. Is the problem corrected?
 YES: End.
 NO: Replace the DC controller PCB.
Jul 28, 2009 | Canon imageRUNNER 2000 Copier
Toshiba TEC B-572 Printer Logo
Top Toshiba TEC Office Equipment & Supplies Experts
CheckitRight
CheckitRight
matt
matt
richie46
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
