Question about Amana RC17 Microwave Oven
It says call for service - Amana RC17 Microwave Oven
Getting an "EE" and it
Check this against your code, but iff EE is flashing you may have an internal electrical fault that needs to be checked out by a repair person.
  1. Frigidaire
  2. GE
  3. Panasonic
  4. Sharp
  5. Whirlpool
Sharp commercial grade microwave codes....
EE Mode Reason Action Required EE 1, EE 2 Magnetron failure
Call for service*
EE 3 Both magnetrons failed Call for service. EE 4 R-23GT, R-24GT and R-25JT only
Voltage too high Follow instructions on page 5 of Operation Manual under VOLTAGE SELECT to change from 208V to 230V. If problem is not corrected, call an electrician. EE 5 R-23GT, R-24GT and R-25JT only
Voltage too low Follow instructions on page 5 of Operation Manual under VOLTAGE SELECT to change from 230V to 208V. If problem is not corrected, call an electrician. EE 6, EE10, EE16 Thermistors failure Call for service. EE 7 Exhaust air temperature too high
Check that nothing is blocking air intake openings on oven back or that oven exterior is very hot. Correct. Wait a few minutes and try again. If problem persists, call for service.
EE 8 Circuit failure Call for service. EE 9 Maximum time is exceeded
Check page 11 in the Operation Manual. Touch STOP/CLEAR pad, and reprogram correctly.
EE 0 Fan lock error Call for service. EE17 Magnetron temperature too high
Touch STOP/CLEAR pad. Wait a few minutes and try again. If problem persists, call for service.
* EE 1 and EE 2: Can continue to use oven before service; however, check food carefully as additional cooking time will be needed.
Any time the EE is flashing, the servicer should be called. When EE is not flashing, check the reason and correct. Service is not necessary.
Aug 20, 2011 | Microwave Ovens
We bought a Samsung over the range Microwave less than 6 months ago. Today it died. We went through the troubleshooting and it appears to be the microwave. Where is a service provider in Madison, Wi? Can...
Hi and welcome to FixYa, I am Kelly.
I beleive that your Microwave has a 1 year warranty. Since you did not provide a model number I can not verify that. Having said that you should visit the Samsung website and make sure your Microwave is registered using the link below before calling for warranty service other wise they will refuse the warranty service request.
REGISTRATION
http://www.samsung.com/us/support/account/regist
SERVICE LOCATOR
and then use this link to find out who can service it for you.
http://www.samsung.com/us/support/service/location
You can call them at: 1-800-726-7864 and find out also. (
I think the internal fuse has failed but.. if it is infact "in warranty" Let the service provider do it for you for free. I did in home warranty service for 40 years and you have to go through the hassle of making the call and getting an authorization number.
If it is not in warranty I am certain that Sears can service it for you.
Thanks for choosing FixYa,
Kelly
Mar 25, 2011 | Samsung 1.8 Cu. Ft. Over-the-Range...
My Black and Decker is not working when I switch it ON. Need a service center who can fix it
For the USA you can find a the closest service center here:
http://www.blackanddecker.com/Service-Centers.aspx
For other countries access your site here:
http://www.blackanddecker.eu/landing/world_north_am.html
Look under Customer Service or Service Centers to find the search function for your service center.
Feb 05, 2011 | Microwave Ovens
Pls give address of samsung service centerin pune city & swargate area
You can contact these people who are the Samsung service providers. Specular Services 24 Amar Enclave Pune Solapur Road Wanowari Tel No 56235476/77 9822066239
United Refrigeration Works 605 NanaPeth New Alpana Talkies Pune Tel Nos 26336856 9890066272
You must have been provided with a booklet, when you purchased the Oven, giving you the Warranty Card and the list of service centers.
Nov 26, 2010 | Microwave Ovens
Where is the thermistor
Many Microwaves do NOT use a thermistor, as such, they do however have thermostat type electronics, what you need to do is get a service manual, this will have a schematic diagram.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/280381a25d6e9bd885256e380058a213?OpenDocument
Above find a service manual for a generic service manual.
Jun 03, 2010 | Microwave Ovens
Service center at hyd
NO SERVICE CENTRE IS AVAILABLE IN HYDERABAD FOR EMERSON Microwave Ovens. IF U HAVE ANY PROBLEM WITH UR OVEN THEN U CAN VISIT UR NEAREST KENSTAR / LG SERVICE CENTRE/ ELECTRICIAN'S SHOP, THEY WILL HELP U IN THIS MATTER.
THANKS ALOT,
SANJEEV KUMAR,
CELL.NO: +919876388918
Feb 01, 2010 | Emerson Microwave Ovens
Hai this is gopi from mumbai india , i need to service my oven has it is not working from 3 months get me the addresses near by to me i stay near by anderi east marol pipe line road
Please click the link below to see the service center near you.
You will get a perfect technician for service you oven.
But, please rate my answer the best.
http://www.andherieast.com/listings/services/electricals2.htm
Thanks, you are welcome for any problem here.
I am Indian too...
East or west India is the best.
Jan 03, 2009 | Microwave Ovens
Not cooking no heat
Dear friend,
ngfam at you service! happy to assist!
This means the magnetron tube is blown
and not worth replacing unless you have a$700. or more microwave!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 28, 2008 | Microwave Ovens
Panasonic Oven repair
The oven is Normaly service by board and parts swapping. The processor board would be difficult to service without proper diagnostics. If you take in consideration of the time and the extent of the diagnostics to analyse the fault, it would not be cost effective.
The most common causes of failure is the power supplies, and safety switches. Follow the information in the service manual to take voltage reading and test the switches.
If you have to work in the high voltage section, take great precaution. This is very dangerous to work on. You will need the proper high voltage test meter probe to check for proper high voltage operation. The service people swap out parts to test. This is the fastest, safest, and easiest way to service these.
Normally, outside of warranty we found these not worth to service unless the fault was very simple.
Jerry G.
Apr 09, 2008 | Panasonic NN-S753 Microwave Oven
Looking for LG LMV1915NV service company in Seattle area
Television & Video Sales & Service 525 Dexter North, Seattle, WA 98105 (206) 784-4178 A M Stereo & Video 12509 Lake City Way Northeast, Seattle, WA 98125 (206) 364-5904 AAT Television 3429 4th Avenue South, Seattle, WA 98134 (206) 447-2288 AC TV & Video Sales & Service Mobile Svc & Installations - Authorized Dealer (206) 784-4178 (360) 643-3254 (877) 764-5539 (toll-free) Email: kenactvvideo.com Adams TV 4411 Fremont Avenue North, Seattle, WA 98103 (206) 632-4211 (206) 632-1280 (fax)
Oct 14, 2006 | LG LMV1915NV 1000 Watts Microwave Oven
Amana RC17 Microwave Oven Logo
51 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
foster_mommy
Level 1 Expert
Jim Thurston
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
