Question about Dryers
Dryer gets hot, but stays damp inside and clothes don't dry. I removed a birds nest from the outer end of the vent, and there is plenty of hot steamy air coming through, but still having this problem. Dryier is: whirlpool lg7681xsw1
  • Dryers Master
  • 3,361 Answers
Your problem is exhaust vent related. You already removed the birds nest,now straighten and shorten the flexible hose connector.
Short and straight is a must.
Also check the exhaust tube going into the dryer,it probably has a backed up lint blockage.
Posted on May 18, 2011
  • 413 Answers
The vent is probably still stopped up. You are going to have to pull the dryer out and disconnect the 4" vent hose from the back and inspect the vent all the way through.
My maytag gas dryer work on dry cloth and stays hot but as soon as i put wet cloths in it they wont dry ?
My dryers timer wouldn't work correctly and the clothes were taking forever to dry. I decided to check the vent. My advice....Always check your dryer vent before spending any money on unnecessary parts or service calls. This Nest was pulled out of my vent with my shop vac sucking out and my house vac blowing out from inside. It finally broke free and now my dryer works like new.
Sep 24, 2011 | Maytag Atlantis MDG7400AW Gas Dryer
Problem drying clothes
This is the classic symptom of "poor air flow". Another symptom you didn't mention (but I bet is happening) is that the top of the dryer gets VERY hot. OK, don't move your dryer yet... get a flashlight and look behind there. See the flexible vent connecting the dryer to the wall? It must have SMOOTH, FLOWING turns. No crushing allowed. If it's crushed/pinched, you found the problem. It's "choking" off the air flow... not allowing the hot air to escape and containing all of it in the dryer cabinet. If this is the problem, pull the dryer away from the wall about 8" and make sure the vent isn't pinched off anymore. Leave your dryer this far out, it'll ensure that this doesn't happen again. If the flexible vent is OK, there is a blockage in your house's internal dryer duct work somewhere. Turn the dryer on and go outside to where the exhaust is. Check air flow. Check the exhaust vent for debris (I've seen birds build nests in the outside exhaust, incubates the eggs...but your clothes won't get dry!). If your dryer location and the exhaust location are quite a distance (20' or more) from each other, you should hire a professional to come out and thoroughly clean it out for you. In this case, you should have this done once a year as part of routine Home maintenance. To test and verify my solution to this, you can remove the dryer vent from the wall and cover the end of it with a pair of old pantie hose. Then run the dryer as usual (the pantie hose will act as a secondary lint trap). You'll see that the dryer will be happy again and the clothes will dry in no time at all.
Aug 21, 2007 | Whirlpool GGW9200L Gas Dryer
Dryer takes too long to dry. GETS HOT...but not drying. Ran two cycles, frame work was hot, but clothes were not compelety dry. Note: not any lint either.??
make sure all the venting is clear of build up and debris,, clogged venting will not allow the moisture to escape the dryer resulting in damp and undry clothes ,, don't forget to check the outdorr vent and clear anything built up inside of that too
Jul 12, 2011 | Dryers
Dryer is hot and running the clothes don't get dry
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Jun 01, 2011 | Dryers
GE Dryer model DDE8509R0MWW is getting warm but not hot, takes forever for clothes to dry :(
Check the ductwork for excess lint, kinks, bird nests (yes) or anything else that would restrict the air flow. There is a lazy man's shortcut for electric dryers ONLY: Disconnect the dryer vent and run a load of damp clothes... if the dryer dries the load in normal time, the duct is clogged or kinked. If it doesn't, it's something wrong inside the dryer.
The most common reason for your problem is the cycling thermostat. This is cheap and relatively easy to fix. GE cycling thermostats require turning OFF the power and removing the front of the dryer. It's located on the blower housing. Two wires, two screws. If you have an ohm meter, a good one will read zero ohms.
http://www.repairclinic.com/PartDetail/Cycling-Thermostat/276447?modelNumber=DDE8509RCMWW
The other possibility is the heater element. GE has a dual element. If half of this heater breaks, it takes a long time to dry towels and jeans. Incredibly, GE gets about $200 for these because you can't replace only the heating coil (which was only about $30)... you have to buy the whole unit. This requires removal of the drum. Not impossible for do-it-yourselfers, but it's a challenge for first timers.
Good luck.
Mar 03, 2011 | Dryers
Clothes aren't drying
Check the vent ducting for obstructions, like lint deposits, insect or birds nests and kinks in any of the flexible duct.
May 17, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Whirlpool 6th sense dryer gets hot but is not drying the clothes as effectively as it used to
i think air vent is clogged. check the vent line, remove if you have to, but check outside vent on house wall first. may be even birds nest there.check hole where vent attaches to machine.-plz rate-bozcro
Sep 20, 2009 | Dryers
My electric dryer gets hot but the cloths are not drying
Please check your dryer venting, all of it, or at least as much as you can. I would start at the discharge outside. May be full of lint, covered by plants. or a bird may have built a nest inside. If air is not flowing through the dryer and to the outside clothes get hot but stay wet. Is the case of the dryer hot? Another indicator your vent needs to be cleared. This should be done before you run the dryer again, or you could cause thermal fuses and other little gizmos to break.
Jun 14, 2009 | LG DLE2532W Electric Dryer
Dryer heats up but clothes won't dry
Sounds like to me, that you need to check the vent going outside from the dryer. I had the same problem, and found a birds nest in the dryer vent on the outside of my house restricing air flow. If that doesn't fix the problem, look into a new heating element and or thermostats for the dryers. The old ones could just not be getting hot enough anymore. Good luck.
Apr 08, 2008 | Whirlpool LER5636P Electric Dryer
Dryer seems to work, but clothes end up damp?
Corwyn, looks like the problem you are having is not with the dryer. The vent line is probably clogged up, which caused the moisture to stay inside the dryer. To make sure this is a vent problem, you can disconnect the vent hose behind the dryer and run it for one load with it disconnected. If it runs fine, then the vent line needs cleaning. Usually it needs special equipment and is very hard to do yourself. It would cost you around $90 to get a professional out to do it for you. Gendos....post back.
Dec 19, 2006 | Whirlpool LER6636PW Electric Dryer
Dryers Logo
197 people viewed this question
Top Dryers Experts
