Slow responce scan says i need to replace 4 drivers
  • 21 Answers
I am guessing this is some kind of trojan/mailware you should install a antivirus software and scan your pc. avg offer a free one
Posted on May 18, 2011
Keyboard has delayed responce
You may need to look into taking the computer for repair since it sounds like it's going too slow. Scanning for viruses, defraging etc may also help speed the machine up. If you know how, try to format the machine as this may help speed it up if the system is "too full". Keep in mind formatting deletes everything so be sure to backup your data.
Nov 09, 2013 | HP Compaq nc8230 Notebook
Need mobo manual
Hello you can download a manual here:
http://support.gateway.com/support/drivers/search.asp?st=pn&param=105552
The homepage is here:
https://support.gateway.com/s/MOTHERBD/FIC/105552/105552nv.shtml
And sorry for the slow responce.
Good luck
Oct 18, 2012 | Gateway Foxconn C51GU01 Motherboard
It is a 1998 Olds 88LS. The check engine light was on. The mechanic checked it and there was a code that he said meant "transmission sticking". That code has not since reappeared. I went...
The only way to definitely resolve your problem is to get real time readings on the sensors and controls in the engine management system. That is accomplished with a scan tool; and the scan tool is no better than the mechanic interpreting the data. That said, my guess would be that you have a faulty 0/2 sensor. Occasionally, the torque converter clutch solenoid (TCC solenoid) can stick and cause the torque converter to remain locked up which will stall the engine at stops. That doesn't sound like your problem. The hesitation you're experiencing on accelerating from a stop is a common symptom of a bad 0/2 sensor calling for a too lean fuel mixture. Hope this gets you fixed.
Jul 11, 2011 | 1998 Oldsmobile Eighty Eight
Internet responce is low and opening a file is low,.. like opening youtube is takes a seconds or minutes to open
You can do a few things:
Reset the router by pressing the small button in the back for 15 seconds. You will need to reconfigure the router with the CD provided by the manufacturer.
Move your computer closer to the router. If you have a large house or the signal is weak, moving the router and/or computer for a direct signal will increase the speed of the connection.
Run a scan on your computer using this free tool.
http://malwarebytes.org/
9 out of 10 times, it is malware and/or a virus on the computer that slows down the connection.
Sep 16, 2010 | Computers & Internet
My computer is having slow responce
have you scanned it using the anitvirus? try that, and check for infected files. usually, viruses cause slow performance.
Jul 18, 2010 | Toshiba Satellite A135-S2276 Notebook
Canon scanner speed slow
Various ways....Try these! the slow problem wil get off
How to change the resolution (Windows)
The precision of printouts can be improved by changing scanning resolution.
The higher the scanning resolution is, the more precise the scanned images are represented, however, the file size gets larger.
The scanning resolution can be changed before scanning photos.
Note: When the scanning resolution is doubled, the image data size will be quadrupled.
When the data size is large, the throughput speed may slow down or may occupy too much of the computer's resources (memory).
<Procedures>
Memo: The following is explained using MP Navigator 3.0 procedures.
To scan using MP Navigator:
1. Launch MP Navigator and click Photos/Documents (Platen) on the Scan/Import tab.
80006642en_05sj00759_en_00.jpg- The window you see varies according to the printer model.
2. When the Photos/Documents (Platen) window is displayed, click Specify.
3. When the Scan Settings window is displayed, select the resolution in Scanning Resolution.
If necessary, set other items as well.
4. Click OK.
5. In the Photos/Documents (Platen) window, click Scan to start scanning.
6. Changing the resolution is completed.
To scan using the scanner driver:
1. Launch MP Navigator and click Open Scanner Driver on the Scan/Import tab.
80006642en_05sj00765_en_01.jpg- The window you see varies according to the printer model.
2. Change the resolution.
According to your purpose, set the resolution in Simple Mode with ease, or in Advanced Mode with a detailed setting.
- To set the resolution in Simple Mode:
(1) Select the Simple Mode tab.
(2) Select the output resolution from the Destination pulldown menu.
If necessary, set other items.
- To set the resolution in Advanced Mode:
(1) Select the Advanced Mode tab.
(2) In Output Resolution, select one of the preset resolution, or enter the number from 25 to 19200 to specify your favorite resolution.
3. Click Scan to start scanning.
4. Changing the resolution is completed.
Jun 01, 2010 | Canon CanoScan LiDE 25 Flatbed Scanner
Responce of my nokia n73 is very slow if it is due
its very easy dont install any antivirus for your mobile just install kasper sky net in your pc and scan the memory card the problem will be solved........
Jun 26, 2009 | Nokia N73 Cellular Phone
Solution for 1998 saturn sl
Hello DTC P0341 & P0133 very common saturn Codes.You need to check condition of Plugs & wires,If not New Replace All Plugs & Wires,also I would replace the #1#4 Coil for the P0341.For the P0133 Reaplce your front O2 sensor with an OEM sensor,not an aftermarket.
May 03, 2009 | 1998 Saturn SL
Car running problem
Ok Slow deceleration rev responce was part of the ECU software to keep the emissions down ,however if this has only just started you can try to reset the IAC valve ,the procedure is as follows.
Turn ignition key on ,unplug the IAC valve ,turn the key off ,replug the IAC valve. do this 3-4 times .Then start the engine while holding the gas pedal to 2000 rpm ,then slowley let the go of the gas pedal till the engine idles .
The IAC valve is located on the throtle body and has 4 wires to it.
Sometimes the throtle body needs to be cleaned and then reset.
Jan 02, 2009 | 1999 Daewoo Lanos
Slow startup, slow responce.
Well this is an obvious fix but replace your HDD with a 7200 rpm SATA HDD from http://www.newegg.com
It should be a fairly cheap upgrade depending on how much storage you need.
You should see a significant improvement. I be willing to bet your HDD is a slow 5200 rpm and slow seek time.
Remember, the slowest parts of your computer is your HDD and CDROM
Aug 21, 2008 | Acer Aspire 3690-2196 Notebook
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
