Question about Car Audio & Video
Radio gets no power when key is turned to aux position, then once the engine is started radio shows "----" screen, as if wrong code is entered. The moment ignition key flicks back to aux mode with engine running theres no power to radio again. I tried waiting an hour as per manual but of course the radio is turning off, so that hour is irrelevant? Seems more like an issue with power source? Just to clarify - in order to keep the radio on i would have to hold the ignition key turned all the way with the starter motor whining. Not possible for the hour needed!!
    New Friend:
    Problem Solver:
  • 5 Answers
Check and re-check all and every wire you touched including the battery.
Posted on Apr 25, 2017
GooFyTiS24
  • 33 Answers
SOURCE: flat battery-applied incorrect rdio code
im sorry im having a little trouble understanding the ?tion, are you trying to remove the radio the correct way or install it and having trouble getting the code off the screen...
Posted on Aug 12, 2008
  • 3 Answers
SOURCE: how do i turn on my radio after safe code error?
possibly a small hole on front panel to reset this using a paper clip??
Posted on Feb 12, 2009
SOURCE: I can't turn the key to starter position
Had this problem. Key would turn round and round and never catch. Sprayed some liquid wrench in the key hole. Works great. I'll keep my fingers crossed that it keeps working.
Posted on Mar 18, 2009
flacooo1
  • 172 Answers
SOURCE: Radio turns off in starting position
this look like a low battery and every time you try to crank your car it takes more power and kill the main power to the radio
solution # 2 the radio as 2 power wires one is always hot ( with current) and the other is connected to the ignition switch if you have replaced the radio those 2 wires maybe are connected backwards the one that goes to the switch is probably connected directly to the battery and the one is suppose to be always hot is probably connected to the switch if you have the original radio have your battery tested and if is ok then try get a haynes book at any auto parts for you car and try to follow the wire that is always hot normally is a yellow or orange wire
solution #3 this apply only if you car still have the original radio
turn your ignition switch to the on position but don't crank your car and turn your radio on select a radio station then turn your ignition key off and wait 3 minutes then turn your ignition switch on again with out cranking your car and the radio should be in the same radio station you select if this test pass then chances are is your battery getting low and if this test fail then the hot wire has a blow fuse look for the fuse inside the hook let me know what happend and good luck
bobbysmema2
  • 90 Answers
SOURCE: The radio is in SAFE mode....
It has to be the wrong code. You have to take in to the VW dealership, (because of so many stolen radios), they will have to verify your registration. Then they will remove your radio, get the serial number put it in to VW hub<( dealership only VW repair site), and retrieve the correct code. Even though the code shown is in your owners manual should have been the correct code sometimes radios get switched. Question at the end you said you pressed seek- did you hold the right lower arrow button, (scan), in till radio began to play?
Posted on Jan 05, 2010
Won't start. key works in aux position but not when turned all the way
If you have power in aux position(ex.)radio works but doesn't when you put the key in the start position,the ignition switch is bad,the contacts are warn out for starting/cranking&run positions,these are used everytime you start your car,but auxillary is ony used once in awhile(ex.)your sitting listening to music while waiting for someone to come,but if you do have radio in the run position,but no cranking/starting you could have a blown resistor on fire wall or fuse for ignition,or the starter has called it quits,good luck I don't know if the starter is clicking rapid or just one click or just no power not cranking or cranking a better description of everything that happens will make this alot easier
Dec 29, 2012 | 2000 Dodge Grand Caravan
1997 BMW 318 convertible radio problems
Remove battery cable for 2 minutes.Then try again...Good Luck!!!!!
Aug 05, 2008 | 2006 BMW 3 Series
After replacing the battery on my Porsche Carrera 2000, I entered the wrong numbers a couple of times on the radio screen asking me to enter 4 digits and then the screen went on a WAIT signal. Now that I...
Yes - there is a solution here.
The problem here is that you must leave continuous power to the radio until the WAIT period is over. Any interruption to the power causes the countdown or wait period to start all over again. The secret is to ensure the key is turned in the ignition to accessories point I or the first point on the ignition that activates power to the radio.
If the key is not turned in the ignition as outlined, the radio will automatically shut off after one hour which is a power saving feature (which is great) but it also has a side effect in this case of shutting off the radio before the time limit has been reached!!
Obviously - as you must leave the key turned in the ignition during the wait period (which may be up to 4 hours) please ensure the vehicle is parked in a safe location and well away from any opportunistic thief.!!
Hope it helps or for anyone reading this in a similar situation - this information applies to many vehicles and radio types as many manufacturers have a similar security feature.
Additionally - for cheap code retrieval for Porsche and many other car radios please see this link.
Thanks for using FixYa.
Mar 18, 2011 | 2000 Porsche 911 Carrera
Radio only says "off"...I need
Call any volvo dealership, speak to someone in service dept, give them the vin# off your vehicle and they will provide the 4 digit code for resetting the radio. Also I was told after receiving the code that if the radio says "Off" to insert the key in the ignition and turn it to the"on" position (don't start the engine up) and leave this way for 2 hours with the radio turn on but still saying Off on the screen. Then after 2 hours the screen should say "Code" and that is when you can enter your code in. The reason it says "Off" is because the invalid code has been entered in too many times. Also with my radio there is a tab on both sides of the radio that you can push in to release the radio. The tabs will come forward and you can grab onto them to pull the radio out. My radio had the new code wrote on the sticker with the serial number on the it. Alot of infomation. Hope some of it helps you.
Mar 07, 2011 | 1997 Volvo 960
I have a 2001 ford F250, I replaced the stock stereo with a Boss bv8965b. It works great til I turn on the exterior driving lights then the screen goes blue like the aux screen but it has the code (Car-)....
Yes, you wire the head unit wrong, there is ground, batt12v constant(usually yellow) Constant because you radio memory, Accessory wire when the key is on(that way your radio turns on and off with the keys, and last but not least you ILLUMINATION WIRE witch when you turn your headlights gives you curren 12v...
ground
Batt 12v
Accessory (on with the key on number 2 position)12v
ILLUMINATION. 12v when lights are turn on
Mar 06, 2018 | BOSS AUDIO SYSTEMS BV8965B Car Video...
Ihello,i own a 1999 volvo S70,my radio says off,i press the wrong code 3x,can you help me please
put a battery charger on the battery,turn key to on postion[engine not running] turn radio to on and let it sit there like that for about 5 hours or untill radio say code then enter right code. if battery goes dead during this you have to dtart over
Aug 27, 2010 | 1999 Volvo S70
I don't have the manual for a 2000 volvo s70.
you have to turn the key to position 1 where the radio comes on but not your instrument panel. then leave it on this position for 2 hrs. the word "code" will come on instead of "off".Then you have to put in your 4 digit security code. to obtain this, call a volvo dealer and have them run your vin. they may ask for proof of ownership. if the radio has never been changed out, this will fix it for you! the radio says "code" if the battery was disconnected, and if the wrong code was punched in 3 times, it went to "off" :-) if you have difficulty, email me at savolvo at yahoo directly.
May 01, 2009 | 2000 Volvo S70
Need to know how to program a radio shack pro-94 handheld scanner
press the "prog" key followed by the "Trunk" key then the number "1" key.
Press the "down arrow" key until you see the initials Ed on the screen
Press the "E" key.
Enter the frequencies (including the decimals)
you must press the E key and the Prog key after each frequency, after you finish entering your frequencies, press the scan key.
If you need to clear your scanner, turn it off, press and hold down the number 2 and number 9 keys, while holding them down turn the scanner back on, "clear" should start flashing on the screen, once "clear" stops flashing you can enter the frequencies.
Jan 03, 2009 | Radio Shack Pro-94 Scanner
Problems with radio code
Your radio is now in "off" mode. To get it back to "code" mode you need to have power to the radio for 2 hours. This can be accomplished by either driving the car for 2 hours, or putting the key into position 1 on the ignition, but make sure to turn off the fan as it will drain the battery in 2 hours. Once you have "code" back you can enter the 4 digit radio code. Caution, many of these radios have been replaced so the code that the dealer gives you may be wrong. If entered and it comes back "EEEEEE" that means it is the wrong code. The radio must be pulled and get the factory serial number from the top of the unit.
Hope this helps!
Dec 26, 2008 | 2001 Volvo V70
Loss of heater and radio
need electrical part of ignition switch
Dec 18, 2008 | 1986 Honda Accord
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
