I have a linde H50D s/n H2X394R01351, 2004. 4 cyl. engine. they just put a timing belt, tensioner & pully kit. Engine was noisy and after 6 hours use the enging quit running. I pulled the timing top cover and there was a round hole in the timing belt. They took it in and removed the head and said a plungercame out of the head causing the came to lockup. Bending intake valve. They said they seen this happen before on the 4 cylinder engine. As for the belt. Thet are not sure what happen. My question. Is this what happens to linde 4 cylinder engines
hmerchant110
  • 7191 Answers
SOURCE: What are the torque specifications
You have posted the question under Websites category.
Kindly submit the question under Tractors section on the website by clicking this link so that the best experts in that category can view and post a solution to the problem.
Thanks for using FixYa.
Posted on Nov 21, 2010
hmerchant110
  • 7191 Answers
SOURCE: Fault code 559 (fuel pump
You have posted the problem under "Website" category.
Kindly submit the question under Cars section on the website by clicking this link so that the best car experts can view and post a solution to the problem.
On the page which opens, type the question in the "Ask an Expert" box on the right hand side of the page. Then, click on "Post a problem" button.
Posted on Dec 16, 2010
vanherringto
  • 1738 Answers
SOURCE: Request the cylinder head torque
Here's a link to the head torque specs of all engines. The Yanmar 6HAL DTN should be there as well. Scroll towards the bottom of the page to view the information you need.
http://www.aera.org/downloads/Torque3.pdf
Note: Click the + sign in the magnifying glass at the top to enlarge the information. This web page is in PDF format and may take a minute to load on your computer. Be patient.
I hope this helps.
Posted on Jan 25, 2011
hmerchant110
  • 7191 Answers
SOURCE: holden astra cdx 2003 TS1.8
You have posted the problem under "Website" category and so it is forwarded to Website experts.
Kindly re-submit the question under cars section on FixYa website by clicking this link so that the best car experts can view and post a solution to the problem.
Posted on Aug 11, 2011
emissionwiz
  • 79024 Answers
SOURCE: 2008 gmc Sierra cylinder 6 missfire and backfiring out intake
Sounds like you have a flat camshaft lobe.
Posted on Sep 19, 2012
Looking for timing mark's for a 1997 camry with a 2.2 4cyl motor?
You find the timing marks on the picture below.
Removal
Remove auxiliary 1. drive belts.
2. Support engine.
Remove:
Engine mounting and bracket.
Timing belt upper cover [1].
3.
4. Turn crankshaft clockwise to TDC on No.1 cylinder. Ensure timing marks aligned [2] & [3].
Remove:
Crankshaft pulley bolt [4].
Crankshaft pulley [5]. Use tool No.09213-60017.
5.
6. Ensure timing marks aligned [2] & [3].
7. Slacken tensioner bolt [6]. Move tensioner away from belt and lightly tighten bolt.
Remove:
Timing belt lower cover [7].
Crankshaft sprocket guide washer [9].
Timing belt.
Tensioner pulley.
Installation
Installation
1. Check tensioner pulley for smooth operation.
2. Check free length of tensioner spring is 46,0 mm [8]. Replace spring if necessary.
3. Fit tensioner and spring. Ensure spring is connected correctly.
4. tighten bolt [6].
5. Ensure timing marks aligned [2] & [3].
6. Fit timing belt. Ensure belt is taut between sprockets.
Install:
7.
8. Slacken tensioner bolt 1/2 turn [6].
9. Turn crankshaft two turns clockwise to TDC on No.1 cylinder. Ensure timing marks aligned [2] & [3].
Turn crankshaft slowly 1 7/8 turns clockwise until crankshaft pulley timing mark [3] aligned with 45° BTDC mark [10] on
timing belt lower cover [7].
10.
11. Tighten tensioner bolt [6]. Tightening torque: 42 Nm.
12. Install components in reverse order of removal.
13. Tighten crankshaft pulley bolt [4]. Tightening torque: 108 Nm.
Manufacturer: Toyota
Jun 25, 2010 | 1997 Toyota Camry
Need to know how to adjust serpentine belt, please show diagram. 6 cyl engine.
Really don't need a diagram. Loosen the slide bolts on the power steering pump. loosen or tighten the pump by turning the jack screw (long transverse bolt) under the pump. Once the belt is tightened up, lock down the slide bolts and you are finished.
Jun 17, 2010 | 1994 Jeep Grand Cherokee
How to fit a cambelt on a volvo s60 t5
remove drivers wheel then plastic wheel arch then put jack under engine and remove the engine mount then take off fan belt and timing belt cover mark your two top cam pullys and the crank pully then remove your belt and tensioner put new belt and tensioner on making sure all your marks line up then put on the crank pully and turn engine over twice by hand using a ratchett on the crank pully bolt if it turns over and your marks still line up put it all back together and start the car
Mar 14, 2010 | 2002 Volvo S60
I have a squeeking noise next to steering pump picasso
remove aux drive belt and run engine
if noise goes then you have a noisy pully (poss tensioner pully and unit or crank pully)
if it is still there it will probably be the tensioner on the cam belt
Nov 06, 2009 | 1987 Peugeot Liberte
Remove water pump
Disconnect battery earth lead. Do not turn crankshaft or camshaft whn timing beld removed. Remove spark plugs to ease turning engine. Turn engine in normal direction of rotation (unless otherwise stated) Do not turn engine via camshaft or other sprockets. Observe all tightening torques. Remove engine, remve RH engine mounting. Remove auxiliary drive belts, water pump pulley, crankshaft pulley, timing belt upper cover, timing belt lower cover. Turn crankshaft clockwise to TDC on No. 1 cylinder, slacken tensioner bolts 5 & 6. Move tensioner away from belt and lightly tighten bolts. Remove timing belt. Remove water pump and replace with new one. Suggest to replace cambelt as well.
Installation
Ensure timing marks aligned3 & 4. Fit timing belt in anti-clockwise direction, standing at crankshaft sprocket. Ensure belt is taut between sprockets on non-tensioned side. Slacken tensioner bolt 5. slacken tensioner bolt 6. Allow tensioner to operate. Tighten tensioner bolt 6. Tighten tensioner bolt 5. Turn crankshaft on turn clockwise. Ensure crankshaft sprocket timing marks aligned 4.
Slacken tensioner bolt 5. Slacken tensioner bolt 6. Allow tensioner to operate. Tighten tensioner 6. Tighten torque: 20 - 26 Nm. Tighten tensioner bolt 5. tighten torque: 20 - 26 Nm. Apply thumb pressure to belt at middle. Approximately 5kg. Belt should deflect to 1/4 of tensioner bolt head width 7. Belt tention can also be set using burroghs (BT-33-73F) tension gauge 10 at middle. Turn crankshaft 90 ° anti clockwise. Check belt tension is 9.5 16,5kg (engine must be cold). Install components in reverse order of removal. Fit cranckshaft pully. Tighten crankshaft pully bolts 8. G4-J: Tightening torque: 12-15Nm.
G4-N/G4-k: Tightening torque: 10-12Nm
G4EA: Tighten crankshaft pully bolt 9. Tighten torque: 140-150Nm.
Nov 04, 2009 | Hyundai Excel Cars & Trucks
Replace 2000 buick park ave serpentine belt
Firt - study & write down (draw) the belt path,,
and be sure about it..
Then - put a wrench on the nut in the center of the tension pully.. Move the tension pully to loosen the belt.. Pull belt off..
Repeat to put new one on..
Should be pretty easy..
Jul 09, 2009 | 2000 Buick Park Avenue
Does 98 toyota camry have timing belt or chain? When do I know if it needs to be replaced? Has 140000 miles on it. Have been told if belt snaps, it can destroy engine.
Both the 4 and 6 cyl. engines in this car have belts. The 4's don't last as long because they lack a tensioner and get noisy. Toyotas for the most part do not get hurt when the belt breaks. non interference engines...nice huh?
Jul 06, 2009 | 1998 Toyota Camry
Hondai sonota
Which engine? 4 cylinder (2.4 lit) or V6 (2.7 lit)? Two different procedures as well as different belts. The 4 cylinder also has a balance belt. See next image:
Here's the 2.7 V6 belt:
The replacement procedure is nearly the same at the start (removing, accy drive belts, pullys, support engine & remove front engine mount, remove T.B covers, disconnect Cam Position Sensor & Crank Position Sensor connectors, etc.). When you get to this point on the V6, you also have to remove the front engine mounting bracket from the front of the engine (4 14mm bolts, also a 12mm bolt which bolts the dipstick tube to the side of it) Put crank shaft at TDC (top dead center w/ALL timing marks aligned) remove hydraulic tensioner (2 12 mm bolts), then remove the belt. You'll need to recompress the hydraulic (auto) tensioner in a vise and insert a retaining pin through the pin-holes at the top (through the tensioner piston) to keep it compressed when you reinstall it. Otherwise, you won't be able to install it. Assembly is reverse order of dissassembly. Inspect your pullys while you're in there (check for pully bearing noise, leaking grease, smooth rotation, also the water pump pully, etc.) Replace components as needed. Careful not to damage Crankshaft Position Sensor wire harness.
The 4 Cylinder is quite different. You not only change the timing belt, but also the countershaft (balance) belt, which is behind the crank position sensor blade. IMPORTANT: ALL TIMING MARKS ALIGNED BEFORE REMOVING ANYTHING) There are two (2) counter-shafts (balance shafts). one driven by the timing belt, the other by the crankshaft sprocket behind the timing belt sprocket at the front of the crankshaft.
Jun 02, 2009 | 2001 Hyundai Sonata
Noisy engine suggesting cam belt prob at 50,000 miles
Do you mean the "Timing Belt"? There is NO Cam belt.. .there is, however, a "Cam Timing Chain"... connects the Intake & Exhaust cams together under the cam cover (valve cover). Unless you actually INSPECT the Timing Belt, no one can know... the noise might be anything! Valve tappets, timing belt Idler pully, tensioner pully, water pump bearing, you name it. Solution: Take vehicle into Hyundai Service Center - pay the diagnostic fee - they will give you an estimate of repairs (if needed) (parts, labor, tax, time-frame, etc.). This way you'll know if there's actually a problem and what it is, as well as what's required to fix it... OR that there's nothing at all wrong.
May 12, 2009 | 2006 Hyundai Elantra
Serpentine belt for 1998 mercury tracer
Hey there MSM,
  • Get a 14mm or 9/16" socket and a long handled ratchet or breaker bar.
  • Get the belt around all the pulleys except the A/C compressor or Alternator. The routing diagram is on one of the radiator supports.
  • The tensioner pulley is near the Alternator toward the center of the engine. It's on a spring loaded arm. Get your socket on the center nut of this pulley.
  • Slowly pull the ratchet toward the center of the engine. The pulley will pivot on the arm allowing you to get the belt on the final pulley.
  • Slowly release the tension.
  • You're done
Mike
Jun 05, 2008 | 1998 Mercury Tracer
Computers & Internet Logo
David Payne
David Payne
