Question about Panasonic KX T7436 Corded Phone KX-T7436
My phone will NOT let me call out when i dial a number it says its restricted. how do i fix this problem???
  • Panasonic Master
  • 2,460 Answers
Here's a phone system lesson. Panasonic discontinued your TD phone system about 8 years ago, so you either got a super deal or the system has been installed that long ago. Restrictions are programmed into the system by an installer and manager. There's a Class of Service override access by dialing 47 on the intercom and a code. Since the 7436 is a special phone, it's probably the one attached to extension 101. If that phone is restricted, clearly whoever owns the system doesn't want whatever you're dialing to be dialed.
Now you wouldn't be asking "someone on the internet" for instructions on how to beat the restrictions would you?
I didn't think so. Check with the system owner or installer.
Carl
Posted on May 18, 2011
Hoe I do disable outgoing call FDN restricted
Fixed Dial Number (FDN), allows you to restrict outgoing calls to a limited set of phone numbers on your Samsung Galaxy Note 2.
How to enable FDN on Samsung Galaxy Note 2
  • From the Home screen, tap Phone icon.
  • Press Menu key and then tap Call settings > Additional settings > Fixed Dialing Numbers.
  • Tap Disable FDN.
  • At the prompt, enter your PIN2 code and tap OK.
Mar 10, 2015 | Samsung Galaxy Note II GT-N7100 16GB Gray-...
What does outgoing call are restricted by fdn mean
FDN(Fixed Dial Number) if enabled, allows you to restrict your outgoing calls to the limited set of phone numbers that are included in the Fixed Dialing Number list.
Jun 10, 2014 | Motorola Mobility Verizon Wireless Droid...
Outgoing calls are restricted by fdn
This means that Fixed Dialing is enabled to certain numbers. You'll have to disable this function in order to call other numbers.
Mark
Motorola Support
Have a 1976 Mickey Mouse push button phone. I get a dial tone, but not able to dial out
This may be something as simple as REVERSING the line wires or a bad tone pad. Some pre 1980's tone pads didn't have polarity guard (EPG) and that's what we used to restrict dialing on touch tone lines (poor man's dialing restriction).
You can open up the jack the phone plugs into and reverse the red and green wires, or open up the phone and do the same thing. If it were my choice, I'd reverse the jack. If that doesn't fix it, pry off the faceplate cover over the dial, read the part number on the right side of the tone pad and post back. I'm sure I have an equivalent in the warehouse (outside of my 2 TT Mickey's) that I can give you a price on.
Carl
Jun 20, 2011 | Disney Classic Mickey Mouse Telephone
FDN restricted
You have fixed dialing on in your mobile. (Restricted to calling only certain numbers - or no numbers) Find call settings on your phone and deactivate FDN it should be in the call setings or in the contacts.
Feb 18, 2011 | Cell Phones
Error message "Number FDN restricted"
I can receive the call from outsider but wont be able to make call to outsider. When I trying to dial out to somebody it says "number FDN restricted" Please help.
Jun 14, 2010 | Samsung SGH-t219 Cellular Phone
Restricted calls on my lg chocalate
When a cell phone is lost the cell company often places restrictions on teh phone so outrageous bills are not ran up on an account. The reason the numbers that are already input into the phone can be dialed may help ensure it is returned.
Jun 19, 2009 | Cell Phones
Got new sgh-g600 wont let me do anything
You have enable the feature called "Fixed Dial List". You need your PIN2 to enable or disable this feature. Using this feature will restrict your calls or text messages only to numbers in the list.
Navigate to your phone security menu, and disable fixed dial list.
Regards,
dC
Dec 26, 2008 | Samsung SGH-D500 Cellular Phone
Cannot fax
Is thi sin an office?
Are you using a direct outside line or is it an office extension?
Your office extension may have restrictions on it and you would need to remove those.
I would confrim the numbers are fax numbers and that that line is ok by:
  • Dialing those fax numbers from a working phone line other than the fax machine
  • Unplug the fax and plug in a regular phone in the same line and see if you can dial out and then try those fax numbers again.
If the numbers work from a normal phone but not the fax line, then I would check that line for restrictions.
Dec 12, 2008 | HP OfficeJet 6110 All-In-One InkJet...
д.ї.Щ.є
Most likely his phone is set to restrict. If you want to, you can have your phone changed so know one can call on restricted which means this guy would have to dial *82 and then your number so then you could see his number
Jun 30, 2008 | Nokia 2610 Cellular Phone
Panasonic KX T7436 Corded Phone KX-T7436 Logo
348 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
