Question about Sony MHC-GX40 CD Shelf System
Everytime i turn the volume up to a certain level whether it the radio or a cd it will shut its self off and read protect power off is there n e way of taking that off??
    Brigadier General:
  • 8,546 Answers
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on May 18, 2011
My stereo in 1997 chevy caviler is turning off and on when turned up to a high volume. I have a sony xplod 52 watt by 4 channel radio. With two 6x9 sony xplod 50 watt rms and 300 watt peak power in the...
Most likely cause is heat. The clearances behind the radio are often not sufficient to provde the proper air coolling that the higher power radios need. The heat sinks on the rear of the radio require a certain amount of air flow to dissipate the heat generated under high load conditions. If you add summer heat to the equation, you can have the radio going into thermal cutout to protect it circuity.
May 27, 2011 | 1997 Chevrolet Cavalier
Boat stereo shuts off when turning up the volume
When any radio shuts off wth high volume it is caused by several things.
1. The maximum power output was reached and the unit goes into the self protection mode.
2. The most common reason.... The power transistor has partially failed and will not provide the partially amplfied output necessary.
3. Units with removable face plates vibrate enough to disengage the face plate contacts so the unit shuts off.
4. The speakers are too big for the radio causing it to self protect. (system mis-match)
5. Loose connectors/pins on the radio input and output connections.
6. A poor system ground that is good enough for low volume use but when high power use is encountered the ground is not good enough to carry the amperage necessary.
These are the most comon reasons for a unit to shut off at higher volumes.
It is not always an easy fix troubleshooting this problem. I know first hand as a life long electrician that has the exact same problem with the radio in my automobile. (Mine appears to be a power transistor grounding problem) With shipping to the repair center each way and the flat rate repair cost it would cost as much as a new one!
Thanks for using FixYa.
Kelly
May 12, 2010 | Boating
Regarding a Yamaha RX-V757 receiver, if I have my volume set above approximately -28, whether I'm playing a DVD or listening to a music CD, the units power shutsoff. When I turn it back on the display says...
Try turning up the volume with just the FM selected (and tuned to a station). If you can adjust the volume to an appreciably higher level when simply tuning in a radio station, then your CD/DVD player may be outputting a signal with a DC offset, which is getting amplified when you turn up the volume, and past a certain point the protection circuitry is sensing too much DC being sent to the speakers and shuts the unit down. If the unit is getting hot, there is likely an internal problem, or you have a shorted speaker wire, or even a bad speaker. Replace the speaker wires as a test, and you can also run the unit with only one speaker connected at a time to see if any are the source of your problem.
Yes, it's possible that there's nothing wrong with the wires or the speakers, and the unit simply needs a trip to the shop, but it's your job to rule out the easy stuff before you pack it up and take it in.
Nov 21, 2009 | Yamaha Audio Players & Recorders
Sound from stereo goes on/off intermittently. Stereo power remains on, but sound will go off whether you are listening to the radio or a cd. Is there a seperate amplifier hidden somewhere?
It might not be the answer but do you have Traffic News set up? Many radios have a different volume setting for Traffic News which may have been set to a low level. Try turning the volume up when it has muted and it may solve it.
Oct 15, 2009 | Mazda 626 Cars & Trucks
Gemsound power amplifier exa3955 keeps shutting off.
it is most likely that the shutting off is an precautionary system response to protect your amp and drivers. check all connections again for wrong polarity.
Feb 01, 2009 | Audio Players & Recorders
Radio shuts off at volume of 16 or more
Maybe a protection component cutting in.
If you have speakers that are too powerful for the radio it may shut down to protect the amplifier from overdriving the speakers. That produces too much heat in the amp chips/transistors and they either have a overload cut out protection circuit or they burn out.
Even if the speakers are the stock fitted ones the wattage could be bigger than the amp in the radio can handle.
There's probably no way of knowing how powerful the speakers in the truck are but you could try the radio with another set.
Max 50 Watts for that radio. If you don't have the manual for it, it's available here:
http://www.kenwoodusa.com/Support/Car_Entertainment_Owners_Manuals/#_
Mar 07, 2008 | Kenwood KDC-319 CD Player
Avr 3806 power shuts off when volume turned up
Hello david 420
It looks like your receiver's high-speed protection circuit is being activated. It is definitively not a fuse. When a fuse pops, you have to physically replace it. When the protection circuit is activated, the speaker output is cut off and the power supply indicator flashes. There are a few reasons why this happens:
1.- Your speaker wire connections are loose. Whether they are banana plugs or bare wire ends, make sure the speaker terminals on the back of your receiver are tight using clockwise turning.
2.- Verify that your speakers have an impedance between 6 and 16 ohms. Your receiver was designed to work with that impedance range. Any impedance lower than 6 ohms will activate the protection circuitry.
3.- The receiver is used at high volume levels over a long period, which results in an
extreme temperature rise. Improving the ventilation conditions around the unit might help alleviate the problem.
If after complying with these suggestions, problem is still present, you might need to have the unit checked by a professional for possible circuit failure.
Hope this helps. Let me know.
cancerags
Dec 31, 2007 | Denon AVR-3806 Receiver
Sharp-XLES50 Help...
If the unit stays on at a low volume and cuts off when volume is raised, then fan motor maybe defective. If it cuts off no matter what volume level it's on then output IC maybe at fault.
Nov 04, 2007 | Sharp XL-ES50 CD Shelf System
Head Unit Shuts Off At a Certain Volume
check your ground, it could be that your antenna is the only source of ground, in which case the deck does not have enough power to stay on when it draws too much power. I've seen exactly what you are saying many many times. Ground it really reallly good.
May 10, 2007 | Alpine CDA-9853 CD Player
Unit going into protection mode
You should first have or check the impedance and resistance of the speakers. then if all the speakers and wiring checks good, the only way to tell if this unit is good or the output section has no problems, is to hook up load resistors to where the speakers go, insert 400 to 1000 hz @.775MV into an input, hook up an osilliscope to the load resistors and slowly turn up the volume and see if the waveform clips before it shuts down. I doubt if you will have the equipment to preform these test but a good repair shop will be able to help you out. If it does not clip or go out then its all speaker wiring and/or the speakers.
Oct 04, 2006 | Sony STR-DE575 Receiver
Sony MHC-GX40 CD Shelf System Logo
62 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
