Question about Uniden Cordless Phone
Cordless telephone sw/from pulse to tone
I'm having trouble learning how to swtich my phone from pulse to tone, there doesn't seem to be any obvious control/button on the phone.
I would appreciate some assisstance sooner than later if possible. My 900 MHz cordless phone was unplugged and in storage for three weeks. Now it has a pulse instead of a tone and I can't check voice mail because it won't accept my password, and when I call a business and get an electronic menu it won't accept the numbers I enter. Help! I have tried pressing Program and *Tone, and I get the confirmation beep but nothing has changed.
  • 4 more comments
  • cupton5428 Aug 15, 2008
    My GE cordless 900 MHz phone, model 26928GE2-A, was unplugged and in storage for three weeks. Now it has a pulse instead of a tone and I can't check voice mail because it won't accept my password, and when I call a business and get an electronic menu it won't accept the numbers I enter. I have tried pressing Program and *Tone, and I get the confirmation beep but nothing has changed. There is no switch on the back, as the previous Expert suggested.
    Pressing # did not work either.
    The suggestions by jonniewalker have nothing to do with this model of phone. I don't have any of those controls (Store, or In, or Tone/Pulse selection)--if I did I wouldn't need to be asking for help. And by the way, I know that my telephone service provider provides touch-tone service. The phone used to have tone; now it has pulse and I can't switch it back. My other phone--same brand, same model, purchased about the same time--still works fine on tone.
    I have received three separate notifications of the same useless advice from jonniewalker, after I've already said he's not talking about the same model of phone. I don't believe this kind of service is worth $9.99.
  • cupton5428 Aug 18, 2008
    Thank you, Junoon007, but if I had a Tone/Pulse switch I wouldn't need to be asking this forum for help, as I said in my previous comment. I KNOW I can't use tele-services; that is the whole point of my query.
  • cupton5428 Oct 01, 2008
    Apparently none of you read my original postings. All of the suggested solutions either did not refer to the model I have or repeated solutions offered earlier that I had said did not work. If you are going to offer solutions you should read carefully not only the description of the problem but all the previously offered solutions. In case you'd like to know, the phone was worn out; I have replaced it with a newer GE model; thank you all for trying.
    Genius:
  • 1,011 Answers
Dear,
check this link and hope it will solve the problem
http://www.epinions.com/content_56960192132
regards,
Posted on Aug 15, 2008
  • SALMAN NASEER Aug 15, 2008
    dear,
    here also is described where the switch it located.
    check it.....
    www.clarityproducts.com/pdf/userguides/51388.001_Manual.pdf
    regards,
    TONE/PULSE DIALING
    This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for
    touch-tone use. To set to tone or pulse dialing:
    1. Press and hold the program button for two seconds. You will hear a beep.
    2. Press the *tone button to select Tone Dialing or press # pause to select Pulse Dialing.
    3. Press the program button again. You will hear a confirmation tone.
    all these instruction is also included in manuals given here.
    regards,
I just had the same problem with my GE phone and after messing around with it I figured it out. I hope this helps you.
Press the Flash button until you see something like 1 PULSE 2 TONE.
Press the 2 button
Keep pressing the Flash button until the screen clears.
Posted on Oct 01, 2008
  • 1,800 Answers
Move the button on the side of the phone from "P" to "T."
on either the handset or the base. Or maybe it's in the MENU area
or to look if there any reset button in the base / bottom of ur phone ^^
follow me rate me
    Genius:
  • 1,011 Answers
TONE/PULSE SWITCH With this switch you can place the SYDNEY phone in the appropriate dialling system: Pulse or Tone. How do you know in which position this switch must be? • Place the switch in TONE-position (T). • Pick up the handset and dial a random number. • If the connection is made, leave the switch in TONE-position. • If the dialling tone continues and you therefore are unable to make any telephone connection with the desired number, you have to place this switch into PULSE-position (P). This switch is not used in countries where only “TONE” dialling is available. THE ‘TELE-SERVICES’ / P T KEY If your telephone only works in PULSE mode and not in TONE mode as de- scribed above, you normally cannot use the Tele-Services such as Tele- banking, Tele-shopping etc... With this Tele-Services key you can use these services without any problem. During dialling you’ll be able to temporarily switch from PULSE-mode to TONE- mode. • Pick up the phone. • Dial the required number (in PULSE dialling mode). • Wait till connection is made. • Press the P T key. • Each number dialled from this moment is using the TONE dialling mo
e.
  • 10,594 Answers
Hi, I have solution for your phone problem. click HERE and do that exactly as described.
  • Shahid Electronics
    Shahid Electronics Aug 15, 2008
    Hi, do you have its user manual? please let me now to provide you further help.
    Shahid Electronics Aug 16, 2008
    Hello, any update in your phone problem? thanks.
  • 1,031 Answers
Set the TONE/PULSE selection to Tone if you have pulse (rotary). If you don't know which
type of service you have (pulse or tone), check with your phone company.
To program TONE/PULSE for all 3 lines:
1. Press STORE/IN
2. Press 0 for PULSE or Press 1 for TONE
3. Press STORE/IN
4. Press TONE
To program TONE/PULSE for each line individually:
1. Press STORE/IN
3. Press STORE/IN
4. Press LOWER
5. Press line number (1, 2, or 3)
    Master:
  • 521 Answers
In some phones ithe phone mode gets changed by pressing # for few seconds.try this n let me know wether it helped.
  • 594 Answers
What is the make and model of your phone. also you might check the back of your phone sometimes there is a switch next to where the phone line connects that will switch it from pulse to tone dialing.
5 Suggested Answers
  • 7 Answers
SOURCE: Cordless phone
press menu then globel setup and then press dial mode then change the the dial tone you want
Posted on Nov 10, 2007
  • 86 Answers
SOURCE: change/add #'s in Memory
Find your model number and then click this link to download the manual
Manual page
Posted on Jan 20, 2008
  • 3 Answers
SOURCE: Cordless telephone sw/from pulse to tone
In General Electric (GE):
TONE/PULSE DIALING
2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing.
Posted on Aug 09, 2008
SOURCE: Dial Tone but won't call out.
The problem was the main phone line not the phone itself
Posted on Jan 08, 2009
Hii myy phone doesn't want to chang to touch tone what do i do? it is a uniden dect 6.0
You didn't specify the model of your phone, but on many Uniden phones the choice between pulse and tone dialing is on the main menu.
Select the model of your phone from the list beginning at
http://www.uniden.com/owners-manuals/dect-phones/scat/dectphones_mnl/
to get the manual.
Jul 13, 2011 | Uniden DECT 6.0 Cordless Telephone...
I have a Emerson DECT 6.0 with 3 head sets and i cant get the dial tone back from pulse.
It was easy for my Emerson Dect 6.0 to be switched either rotary / pulse by just pressing the "FLASH" button for 3 seconds until it beeped. Problem solved.
Or if that doesn't work, you have to:
Tone/Pulse
You can switch the dial mode. In most situations the TONE option should be selected.
• Press the MENU button. Select BASE using <FLASH - or - CID> and press the MENU button again.
• Using <FLASH - or - CID> select DIAL MODE and press the MENU button.
• Using <FLASH - or - CID> select TONE or PULSE and press the MENU button.
OR
Press and HOLD the "<FLASH" button for approximately 3 seconds. T (Tone) or P (Pulse) appears in the display.
Feb 12, 2010 | Uniden DECT 6.0 Cordless Telephone...
Phone went from touch tone to pulse. . .
Read the manual to reconfigure that option. (Look for Setup button on the phone) I can't guess what model you have. On older phones one could find a switch on the the phone to flip between Tone and Pulse.
Sorry I could not be of much help.
Sep 04, 2009 | Uniden Cordless Telephone
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
What is the difference between pulse and tone? What should I set my phone and fax on?
The difference is that when you set your phone on pulse it works like a switch on/off 1 pulse for number 1, 9 pulses for n9 and so and so.
When you set it on tone each number has a different tone, differnet sound frequency.
You should set your telephone on tone.
Jan 28, 2009 | Uniden DECT 6.0 Cordless Telephone...
Changing from pulse to tone dial
For the GE electric 2.4 GHZ phone where there is no switch, you have to press the program button and hold until it beeps (talk button will start flashing), then press the tone (star) button and program again. It will beep for confirmation
Dec 12, 2008 | Lands Phones
Pulse and tone
in GE:
TONE/PULSE DIALING
Mar 16, 2008 | Lands Phones
Pulse dialing
Setting for Tone: Phone is OFF, then press and hold CHANNEL button for 2 secs until beeps, then press TONE *
Setting for Pulse: Phone is OFF, then press and hold CHANNEL button for 2 secs until beeps, then press #
Jan 11, 2008 | Lands Phones
GE cordless phone
To set for Tone: Ensure the phone is OFF, then press and hold CHANNEL button for 2 secs until beeps, then press TONE *
To set for Pulse: Ensure the phone is OFF, then press and hold CHANNEL button for 2 secs until beeps, then press #
Jan 09, 2008 | Lands Phones
Uniden Cordless Phone Logo
1,399 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
