Question about Emerson NR303TT CD Shelf System
No longer turns on- tried different outlets and the machine will not power on - hence no light, no sound? does not work. is there a fuse or reset button?
  • vincentb4 May 18, 2011
    Yes- just what I thought
    thanks
  • Emerson Master
  • 11,800 Answers
No, neither: the power source is a very simple one that just shuts down if there is a damage (so no fuse) and the control processor is hardware preprogrammed (so no reset button).
If the unit is dead then there is a hardware defect - a part inside it has failed, most likely in the power source since not even the lights are on. To fix that the unit will have to be opened and the components checked, starting with the continuity of the power cable and the working status of the power button.
Some basic experience in electronics is required, if you don't have it then take it to a repair shop.
Posted on May 18, 2011
Washing machine lights went out and now water is coming out of the door when opened. checked fuse in plug but still machine wont work
Turn fill water off soon.
Sounds like a major problem.
are you sure you have power at the outlet? check with other
appliance. Be careful water and electricity do not mix!
Check circuit breaker in the main panel. If poped try to reset
If pops again, call electrician.
Owner's manual troubleshooting?
No help, Call MFG customer service number.
Warranty? follow that route.
Feb 27, 2015 | Washing Machines
Sylvania sa 140 digital timer
Sylvania timers often come with long warranty. Call 888-548-4484/ hardwareinnovations.com
http://waterheatertimer.org/Sylvania-timers-and-manuals.html
Usually if batteries are changed, you want to reset timer. Press reset button, for 5 seconds and then reprogram. If functionality is not restored after reset, then timer has gone bad.
Check outlet for power, makes sure bulb is working, turn light on, try timer on different outlet and with different lamp.
Gene
h
Aug 08, 2013 | Hardware & Accessories
Panasonic viera TC-L42-U22 will not turn. No lights, no sounds, nothing happens... only 1.5 year old. Any suggestions?
There is a primary power supply failure, probably a fuse blown. This is a case to be handled by a qualified service technician.
Jul 17, 2012 | Televison & Video
TV has no power
Someone would have to check for short starting in Horizontal output circuit at the output transistor--voltage checks will also narrow down where likely problem is at.
If power light does not come on usually trouble is at fuse or very near it.
Mar 19, 2012 | Sansui TDC2075 20 in. TV/VCR/DVD Combo
Magnavox hdtv green light
Hello
Unplugging the machine makes it do a reset on itself hence the normal operations after plugging it.This indicates a power problem on the machine or on AC outlet supply.
You may need to check the AC outlet's voltage supply and make sure its in order.Check this by plugging another electrical appliance onto the AC outlet and see its operations.
If the problem persists and the products still on warranty,please let the Magnavox guys have a look at it.
Ken.
Jan 22, 2012 | Televison & Video
The coffee maker will no longer turn on. It shut off one morning and now I cannot get it to turn back on. Tried different outlets and know it is coffeemaker.
If you have no power this is often caused by a thermal fuse that opens up when the temperature is exceeded in the coffee maker. The unit will need to be dis-assembled to assess the situation, some use a power transformer with a built in thermal fuse.
Mar 28, 2011 | Keurig B60 Coffee Maker
Green power light blinks for 1 minute then the lamp light blinks
When Lamp of the TV has been blown out, the LAMP light blinks in red.
When there is an internal malfunction in the TV, the Power led blinks and there will not be any picture on the screen.
Since, both are happening with your TV, it seems that there is an internal malfunction. Hence, your TV requires service.
You may try the following troubleshooting steps before getting the TV serviced.
Disconnect the Power cord from the Wall outlet and connect it to a different working wall outlet.
Disconnect surge protectors if you are using.
Then try resetting the TV to the Factory default settings to check whether the issue is resolved.
Jul 14, 2010 | Sony KDF-E42A10 42 in. LCD Television
Picture had yellow tint and now there is no picture and red light is blinking next to lamp
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team and check for the available options. Sony had repaired free of cost for such issues. Hence, contact the customer relations.
Jan 15, 2010 | Sony KDS-R60XBR2 Television
NO POWER
Inside the microwave is a fuse. If you can, try plugging the microwave into a different outlet (use an extension cord). If it does not power on, you have likely blow the fuse. If you are technical, you may look into replacing the fuse yourself (you will have to remove some parts of the microwave exterior to get to the fuse). Otherwise, if no longer in warranty, you will need to have a shop or handyman replace fuse.
Mar 29, 2008 | Microwave Ovens
Saeco Vienna De Luxe Espresso Machine not turning on
Sounds like it could be a simple fuse in the machine or just needs a reset code
Aug 15, 2007 | Saeco Vienna De Luxe Espresso Machine
Emerson NR303TT CD Shelf System Logo
150 people viewed this question
Top Emerson Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
