Question about Toshiba SD-P1700 Portable DVD Player
Toshiba sd-p1750 dvd player not a valid disc
Not a valid disc comesup when disc is inserted
  • 1 more comment
  • sires6 Jan 06, 2009
    Every time I put a disc in now, it says it's "loading disc" and won't respond.
  • 1121Remymart Jan 13, 2009
    I have the same problem. Screen says Not Valid Disc. Sometimes the disc spins continuously.
  • Anonymous Apr 04, 2009
    endless spinning
4 Suggested Answers
SOURCE: Toshiba SD-3980
http://www.tacp.toshiba.com/tacpassets-images/notices/sd-3980_sd-k750.asp
read that
Posted on Mar 23, 2008
SOURCE: Toshiba DVD SD-3980SU2 or SC2 player loads every disc as "bad disc"
Toshiba says:
Information for Owners of Toshiba SD-3980 and SD-K750 DVD Players spacer.gif To ensure the satisfaction of our customers and to maintain the integrity and quality of our products, Toshiba America Consumer Products, L.L.C. is issuing an important product update. This is not a safety issue.
Toshiba is committed to customer service and to continuously improving the quality of its products. It has come to our attention that certain DVD players bearing the model numbers SD-3980 and SD-K750 may at some point in their life stop playing discs due to a component part failure. In such case, the error message "bad" will be shown on the unit's display. Affected units will have "SU2" at the end of the model name (e.g., SD-3980-SU2), which can be found on the back of the unit.
If you own either of these models and experience the issue described above, please contact Toshiba Customer Solutions at 1-800-631-3811 for information on how to obtain a replacement unit.
Posted on Jan 18, 2009
SOURCE: toshiba sd-310vu dvd player makes
The motor that spins the disk rests on rubber shocks. The rear shocks wear out over time allowing the disk to set uneven and rub eventually stopping the disk and giving a disk error. To fix simply put one small flat washer under each of the rear shocks this will level the motor and stop it from rubbing.
Posted on Mar 13, 2009
fieldy14
  • 456 Answers
SOURCE: my Toshiba portable dvd player says no Valid Disc
If the units under warranty you may want to contact Toshiba as it sounds your unit is in need of a replacement laser assembly.
If the unit isnt under warranty, Toshiba should be able to supply the parts you need and as long as you mark every thing that you remove, as to know where it goes when re-assembling the unit. The lasers arent difficult to replace. Good luck.
Posted on Jun 07, 2010
No valid disc toshiba SD P75S
either it is not a valid disc or a problem with the optical pickup in the unit, all discs give this error?/
Apr 07, 2012 | Toshiba Televison & Video
I purchased a toshiba portable dvd player and the disc is not spinning therefore reads no valid disc. I have put in a few discs still same reading? Any suggestions?
Hello
The Sled Motor is defective. this is the motor, whic spins the disc as it has been loaded properly. If the loader mechanism loads the disc properly into place and if the catch up magnet catches the disc in place, and still the dis do not spins, replace the sled motor. OK.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
Disc doesn't spin
Hello
Check whether the disc inserted into the player spins. If it does not spins, replace the sled motor.
SD-P1900SN After inserting movie DVD, I get message, "No Valid Disc". I ensure disc is inserted properly. Bought player a couple of years ago. Have only used it 3 times. Can't find anything in manual...
Check for cracks or scratches on the dvd disc?It a dvd movie disc,not a computer program dvd disc?Take the dvd disc,washes it with some dish washing soap.To clean all the grims and grease out of the dvd disc laser surface to the dvd player laser eye to read the dvd disc.
Jun 17, 2010 | Toshiba SD-P1900 Portable DVD Player
My Toshiba portable dvd player says no Valid Disc
Jun 07, 2010 | Televison & Video
No valid DVD displays on my Toshiba SD-P1850
Most portable dvd players will not read burned dvd/cds. Please be sure to use originals in your dvd player. If you have a user's manual it should tell you if your player reads CDR's or DVD/RWs
Aug 07, 2009 | GPX PDL805 Portable DVD Player
No CD sound on Philips DVD/VCR player
I havent seen this model But in the past I have heard this problem arise. It turned out that there was a mute button for the cd only on the remote and there was no indicator to show it. check for a cd mute or go into the cd play menu and check around in there.
Mar 23, 2006 | Philips DVD740VR DVD Player/VCR
Toshiba SD-P1700 Portable DVD Player Logo
88 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
