Question about Panasonic CQ-C8303U CD Player
Face plate keeps opening and closing since battery went dead and was replaced
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Panasonic Master
  • 2,226 Answers
If there is a reset switch, try pressing it. The reset switch is usually a pencil tip sized indentation on the face and will not be marked or will be behind the face on the sub panel.
Posted on May 18, 2011
Have a battery drain issue overnight
The antenna has failed & needs to be replaced
No relays,you said open,open means no connection
or current flow.
Relays seldom fail but sure are talked about more than face book
or I-pads
You provided no vehicle,make,model,etc
A bad horn switch,clock spring under steering wheel ?
Some times you have acc modules that time out after the
drivers door is opened,they fail & thing stay energized
& battery goes dead after about 3 days
Nov 22, 2012 | Cars & Trucks
I have an Elna 6003Q sewing machine. My light bulb went out and I need to replace it. How do you get it out and replace it?
some call it a lamp cover door or face plate it's on the left side of the sewing machine
some sewing machines have a hinge at the back of the face plate, you can gently pull it open to change the bulb
some machines -in the middle of the face plate there is a plastic plug, use a screw driver to gently lift the plug & then unscrew the screw & change the bulb.put the face plate back on put the srew back in & put the plug back in to concile the screw
Sep 27, 2010 | Elna 2007 Mechanical Sewing Machine
My StreetPilot c330 ( 4 years old ) went dead and I can not get it to come back on. I have checked the fuse and pushed the reset button.
PULL OFF SILVER FACEPLATE AND A RESET BUTTON IS BEHIND FACE PLATE COVER PLUG UNIT UP TO POWER SOURCE PRESS RESET BUTTON AND THEN PRESS POWER BUTTON,YES BATTERY MAY BE DEAD BUT AS LONG AS YOU KEEP CONNECTED TO A POWER SOURCE IT WILL WORK.
MINE DID THE SAME THING I JUST KEEP CONNECTED TO CIG ADAPTER IN MY CAR.
Oct 25, 2009 | Garmin StreetPilot C330 GPS Receiver
Casio Pathfinder PAG-50 battery replacement
ensure all three of the springs are present
the 2 at the top confirm that the case is closed the on at the bottom sends the sound signal.
ensure the metal casing on the back of the movement is not touching the back. and check the movement is correctly seated
Mar 28, 2009 | Casio Watches
Honeywell programmer gone dead
lift the face plate off and change the batteries
Jul 07, 2017 | Honeywell 2-way Oscillating Ceramic Heater
Face plate will not close, retract into dash,radio plays!
Get your Shifter shortened, it will give you faster more controlled shifts, and keep your knuckles out of the dash.
Nov 18, 2007 | Kenwood KDC-MP628 CD Player
Dual XD7600 Head Unit Problems
Sounds like the flexible connector that connects to the drop-down front panel is bad, broken pattern lead.
Aug 07, 2007 | Dual XD7600 CD Player
Panasonic CQ-C8303U CD Player Logo
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
