Question about Gateway 500XL PC Desktop
Gateway 500XL .. sounds like the Power Supply was making a scratching grinding noise.. off/on... I first thought it was the CPU fan and changed it .. not solved... the PC just shut down... maybe overheated... I waited about a half hour and was able to reboot... can I change the power supply myself and if so any tips
  • 38 Answers
Very easy to replace power supply as this is most likely the reason for the shut down due to heat. Make sure when ordering new power supply or buying from a computer parts store that you do not relay on them to give you the right one, you have to do your homework, after you get it do not unplug everything from the mother board, take your time and make sure that when you unplug you know where to plug back and wear anti static bracelet.
Posted on May 18, 2011
Replace power supply
just make sure it has the same or more power than the original. if you're not sure then go for the same make and model power supply.
Jul 08, 2012 | Computers & Internet
A fan is making a horrible noise
hello
if its the CPU fan is making loud screech noises, its time to replace it
if the power supply fan is making the noise, its time to replace power supply , 5188-2859 is HP part number $25-$40
CPU fan = 5188-3722 HP part number , costs about $40-50
please rate my service with 4 thumbs up
Dec 09, 2010 | HP Pavilion Elite m9510f PC Desktop
My gateway 500xl won't power on
The first thing I would try is connecting a new power supply. If you can borrow one from a friend/neighbor/family member/whatever that would be the easiest/cheapest thing to try first. Also make sure all the wires are connected to the right places and securely connected.
Jun 04, 2010 | Gateway 500 XL PC Desktop
Sony vaio fan is making a grinding noise, how can i fix this?
The sony VGN-S460 seems to have an inherent problem with their cpu fans. It is apparent that the fan uses a ball bearing system which over time becomes worn and causes the grinding sound.
The only solution is to replace the entire fan assembly as they are inseparable.
Nov 15, 2009 | Sony VAIO VGN-S460 Notebook
The Computer will not power up. The start light is lit but there is no fan or other power. The power supply tests good. Checked all connections. Can you help?
Pull 1 of the memory sticks out, then try to start, switching each time the memory position till all options are run out.
Sep 16, 2009 | Gateway 500XL PC Desktop
Gateway 838GM will not turn on even after installing new power supply. It was on and began making a loud noise and just quit.
Did you test the old power supply? If not, noise could have come from CPU fan. In either case, problem is most likely main board and/or CPU. Try removing all plugin components except CPU and heat sink and see if you get any signs of life.
Aug 03, 2009 | Gateway 838GM (RB838GM) PC Desktop
STORM HIT COMP AND WON'T BOOT
In all likelyness your motherboard at a minimum is dead. Take it to a technician to check and submit a claim through your house insurance
Jun 27, 2009 | Gateway 500XL PC Desktop
Ijust replaced the cpu fan and now the computer won't boot - it just flashes the gateway logo
make sure that the power reqs for the fan are the same as one you replaced and make sure that the new fan is the same prong (3 or 4). Also make absolutely sure you plugged the new fan power supply inti the CPU fan slot
Apr 15, 2009 | Computers & Internet
Gateway 500xl pc will not turn on power button is lit up yellow
A LOT of Gateway computers will go into this catatonic state because of a dead battery. The battery is on the motherboard -- it looks like a metal disk about 1" in diamter. Check it or replace it. This applies to laptops too (not the actual laptop battery, the CMOS battery -- a laptop will have one on the motherboard too)
Hope this helps
Mar 13, 2009 | Gateway 500XL PC Desktop
GX7022E Gateway computer no power up
*check for the powercord wheather it is good or not
*check the power outlet
*in bios see wheather hardware settings are correct
*open the system then see power switches are connected properly or wheather there is an any loose connection
*check the cpu fan is working properly or cpu is heating and see cpu is placed properly
*keyboard is connected properly
*check jumper settings are proper
Jun 24, 2008 | Gateway GX7022E (RBGX7022E) PC Desktop
Gateway 500XL PC Desktop Logo
203 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
