Question about Numark CD Mix2
My numark cd mix2 won't play a disc on the left hand side, it just says no disc
    Sergeant:
  • 158 Answers
Hallo! This is caused by the laser fault. First unplug the cord, high voltage!!! Disassemble the device, look under the cd place you will see a little lense. Clean it VERY DELICATE with a piece of cottonwool with alcohol, can clean it twice with alcohol and then with a dry one. If doesn't help, then need to replace the laser reader system with a new one, it's that where the lense is placed, it must have on it an badge with the serial number, you can search it by that number/code.
Posted on May 18, 2011
My numark NDX400 is acting strange. When i am
i did have same problem,i sale them in secend hand shope,not trsutfull ndx400 to be honest.after that i buye new numark mix express.that better than ndx400
Aug 03, 2013 | Numark Industries Numark NDX400 Tabletop...
Need to find how to open a NXD200 from numark... cause i got a problem with 1 button
It's just the screws in the bottom that hold the top and bottom shells together Possibly some on the sides.
Sep 21, 2011 | Numark Industries Numark NDX200 Tabletop...
Numark KMX02 left hand CD will not eject
Usual cause is a little rubber belt either deteriorated or is slipping that drives the carriage to do the eject. Open unit and recover the CD and the drive belt will be obvious...
Apr 14, 2011 | Numark Industries Numark KMX02 Dual Deck...
Yes how to set up to an amp
There are two balanced outputs from the mixer as well as two RCA outputs (right & left). The simplest connection would be to run RCA cables from the RCA mixer output to the auxiliary input on an amp.
If you want to use the balanced outputs from the mixer, you will need adapters (or cables with correct plugs) to go from balanced conectors to RCA or 1/4 " inputs on the amp.
More info, let me know.
Charlie
Mar 27, 2011 | Numark CD Mix2
One of the trays on my CD2 will not open. There is a cd still in there. The other tray is working fine. How do I get the tray to eject?
The safe way is to remove the cover. SOMETIMES the problem is a little rubber belt that drives the tray carriage loses traction. To protect the disk, remove the cover and investigate the problem and manually remove the disk.
Jan 01, 2011 | Numark CD Mix2
How do i cue a song in order to beat mix
TURN MACHINE ON CUE IN BEAT MIX.
Dec 22, 2010 | Numark CD Mix2
Im trying to hook up two sets of passive speaker, one pair is connected to a QSC amp and the other pair is connected to a Kenwood amp. Is this possible without using another mixer like a mackie 1402.
you should be fine, you can get splitters, little adapters to split the input cables into 2, so that you can use one ouytput to run 2 channels. just hook up the output cables to the output on the numark, and use the splitter adapter to split the sound between the 2 amps.
Oct 05, 2010 | Numark CD Mix2
How to set it up to an amp
You would need 1 set of stereo audio cables to connect from this to the amp. It is impossible for us to guess at what amp you are using to know what connections are on it. Where possible you should use XLR types or TRS balanvced types. Somnetimes all that are available are RCA jacks.
Jun 30, 2010 | Numark CD Mix2
Numark CD Mix2 Logo
202 people viewed this question
Top Numark Music Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
J.D. Browning
J.D. Browning
rhodesworks
Are you a Numark Music Expert? Answer questions, earn points and help others
