Question about Sport & Outdoor - Others
Ran out of gas. Filled up with gas. will not start. Turns over good, has been running good until now. Check fuel filter and it seems fine. Is there a trick I'm missing??
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 40 Answers
Did you prime the fuel pump? check the purge solenoid systems it would be helpful for me to know the year make and model :-)
Posted on Feb 25, 2015
    Problem Solver:
  • 5 Answers
You should check the spark plugs, they migth have suffered from the lower quality gas that was left after you burnt everything.
Posted on May 19, 2011
1986 Jaguar XJ6 Won't start. rolls over but that is it. replaced fuel pump relay and fuel pump. seems to have fuel at pump inlet, nothing comes out the outlet. I am lost. car ran out of gas before this...
if your fuel pump and relay are new, how about your fuel filter, if your fuel pump is working but no fuel turns out, check fuel pump polarity, if ok, there will be a clogging in fuel lines, take a high pressure air and plug it to fuel outlet in fuel lines test port, allow air to go back up to fuel tank and observe if the air goes, if not, check or change fuel line, if the air goes to tank, direct your fuel relay pin 30 and 87 and check if the fuel runs to the injectors, if not, change a good fuel pump
Jun 27, 2010 | 1990 Jaguar XJ6
Repaced rotor cap plugs wires, ran fine. tell
First thing I would do is change your fuel filter. Check all vacuum lines and all your wire connections. Also check fuel pump relay to see if it is faulty or if there is shorted wires under the relay or fuse blocks.
Oct 11, 2009 | 1995 Ford F250
Ran out of fuel
The reason is: When you completely run out of gas your gas lines are completely drained of fuel. When you refuel the car the fuel lines are still empty, and you will need to crank the car until the fuel pump has filled the gas lines and established the correct fuel pressure.I also suggest you turn key to on position to let electrical system run fuel pump and when ready to crank over engine have battery hooked up to a battery charger this should do it!!
Aug 22, 2009 | 2001 Chevrolet Cavalier
22 hp Briggs Intek will not run at full speed without choke on
sounds like you sucked up dirt in the carb needs to be taken off and cleaned
Jul 17, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Not starting ran out of gas,added gas and still not starting,can hear fuel pump running,smell gas at engine and exhaust.
Gas line filter may be dirty and clogged. Change it. There could be sediment or dirt in the tank that you drew up to the filter when you ran out of gas and it has built up and is blocking gas from getting into the engine.
May 28, 2009 | 2001 Chevrolet Cavalier
1997 grand prix gtp car stalls
has to be corroded fuel pump resistor behind passenger head light under hood but Im sure by now you have done the research and found that out already 97 gtps had recalls because its in an easy spot to get corroded can buy a new kit for 40 bucks or so through gm or online
May 27, 2009 | 1997 Pontiac Grand Prix
Car won't start without adding gas to air intake then won't idle
Check the fuel filter, you may have clogged it when you filled the tank.
Mar 15, 2009 | 1989 Audi 90
E85 fuel in a regular gas tank
drain the tank change the fuel filter motor will be fine
it'll run funky until the e85 is flushed out
Dec 12, 2008 | 2001 Ford Windstar
Sport & Outdoor - Others Logo
54 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
