Question about Schwinn Cycling
I want to raise the handlbars/gooseneck - Schwinn Cycling
    Brigadier General:
  • 8,546 Answers
How do I change the thermostat on my 1998 ML320
This task is going to require many, many lines of answers.
Please contact a public library or a car parts store for a manual to read and follow the steps.
Here is a thumbnail sketch of what to do.
1) drain the radiator into a pan or bucket, being careful no to spill the coolant.
2) locate the thermostat and remove the lower radiator hose where it connects to the gooseneck.
3) Unbolt the thermostat and gooseneck.
4) Clean the block and gooseneck surfaces and replace the thermostat, adding the new gasket if it comes with one.
5) Attach the gooseneck and the lower hose.
6) Add the coolant to the radiator and "burp" the system.
God bless your efforts.
Mar 30, 2018 | Cars & Trucks
Raising handlebars
There is a single central connection to the handlebars This is called the "gooseneck". (Ther handlebars slide through the goosenect and then the gooseneck is tightened to hold the handlebars. The connector to tighten is in the front (so you do not get "injured" if you have a collison). Loosten the connector (it may be allen, or perhaps hex nut.). Raise or adjust the handlebars, then tighten. Make sure it is really tight (do not strip the threads). The handlebar has serrations to lock on to the gooseneck so the handlebar - gooseneck bolt will have to be loosened quite a bit to allow the serrations to "jump" to the next serration.
Sep 20, 2014 | Trek 7100
How do I higher the handlebar on my barracuda slalom bike pls?
Usually there is a bolt on the top of the gooseneck, loosen it (you might have to tap it to loosen it) then raise it up by moving the bars back and forth. but make sure you do not raise it above the safe limit, it is stamped on the handle bar stem. then retighten the bolt
Jun 17, 2013 | Cycling
What is a gooseneck Hitch?
A gooseneck hitch is a
Feb 18, 2013 | Cars & Trucks
American standard fairbury 4500 Series swivelling problem
Pull up on gooseneck and turn counter clockwise until you feel gooseneck thread into the housing a couple of turns
Jun 02, 2012 | American Standard Plumbing
Adjusting gooseneck
loosen the bolts on the neck, adjust to where you want it, then tighten them again
May 28, 2012 | Specialized HRXC Disc
How do you raise the handlebars for the animator first bike by Giant bikes?
David-
To raise or lower the handlebars, first loosen the hex screw on the top of the stem. One or two turns is all that will be necessary. Next, you will need to stand in front of the bike with the front wheel between your legs to brace it, and give the handlebars a forceful twist to the left or right. This action will break the friction of the handlebar stem and the headtube (the headtube is part of the frame where the front forks and the handlebar stem meet...). With the handlebars loosened you can adjust the handlbars up or down. Keep in mind that the stem has only a specific amount of adjustment available...there is a limit to how far it can be extended up, as indicated by a line marked on the stem shaft. Once adjusted to the desired height, check that the handlebars and front fork and wheel are aligned. Tighten the screw in the top of the stem and you're done!
Hope this helps.
DIYpro
May 03, 2011 | Cycling
How to raise handlebars on 2011 crosstrail
You need an allen wrench. On the Top of the "gooseneck" there should be one allen bolt. This is right in the middle of the handle bars, above the tire. You can loosen it there move it up and tighten it back down.
Mar 28, 2011 | Specialized CrossTrail
1985 Ford Ranger Mitsubishi diesel is overheating. Water pump looks good. How do I check it and where is the thermostat located? thanks
Find a garage, maybe Walmart who will test the Radiator cap. Or just buy a new cap and see if it helps. The thermostats are almost always beneath the water supply from the Radiator. If the cap was weak you will get a higher pressure with a new one and the boiling point will be raised which is a good thing.
In that time frame Ford was putting the Thermostats inside the Gooseneck where the main hose is. It was a pain because some of the aftermarket thermostats did not have tabs on them. The tabs were necessary to twist and lock into the Gooseneck housing.
If you are only a recent owner of this truck you may want to investigate further about the thickness of the Radiator. The diesels could have larger Radiators than a gas Ranger, Thanks for using Fixya.
Aug 09, 2010 | 1985 Ford Ranger
I need directions to raise handlbars on a Diamondback Session bike
There should be a bolt or allen head in the of your handle bar goose neck loosen it.Then twist your handle bars side to side they should break free and you'll be able to move them up or down.Don't go to high it won't be safe!
Sep 21, 2009 | Cycling
Cycling Logo
Top Schwinn Cycling Experts
Michial Gueffroy
Jim Goldsmith
Jim Goldsmith
michael
michael
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
