Drops toner inside machine. I just changed yellow high yield toner cartridge two weeks ago and it just went out. Changed cartridge and their was yellow toner inside machine. HELP
  • Paul Higgins May 18, 2011
    please provide the make and model of printer
    Problem Solver:
  • 10 Answers
It sounds as if the toner has leaked, maybe it was cracked or seated incorrectly. Toner is so fine that if you use a standard vacuum cleaner the toner may just fly out of the back.
It's still worth trying to vacuum out the spilt toner. Remove all other cartridges first
Inspect the Yellow cartridge for damage to determine if it was that or the printer at fault.
Posted on May 18, 2011
Dell H515C Yellow Toner Cartridge is spilling toner
usually when toner spills from the cartridge, it's due to a bad recovery blade or mylar. There is a clear plastic that runs the lenght of the / toner it may be bent.
Mar 25, 2014 | Dell H515C High Yield Yellow Toner...
I changed the Ink Cartridge a week ago but my printer is flashing the yellow toner button and will not print.
Take the toner cartridge out, give it a shake and put it back in.
How many pages did you print in the last week?
their "high yield" cartridge is only rated at 7000 pages so I am guessing the regular cartridge is rated around 3000 (or 6 reams)
It may also be complaining that the drum needs replacing depending on how long you've owned it.
Feb 24, 2011 | Brother HL 5250DN Laser Printer
Toner light is on on Brother HL-2170 Laser Printer and the computer is not recognizing a print task. Can you help me fix this problem? Also, I just replaced toner a couple weeks ago.
Description of Problem 100000013553
I just replaced the toner cartridge and the Toner LED is still on, or the status monitor continues to display the message "Toner Life End". What can I do?
Description of Solution 200000017394
@font-face { font-family: Verdana;}@page Section1 {size: 8.5in 11.0in; margin: 1.0in 1.25in 1.0in 1.25in; }P.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman"}LI.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman"}DIV.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman"}A:link { COLOR: blue; TEXT-DECORATION: underline}SPAN.MsoHyperlink { COLOR: blue; TEXT-DECORATION: underline}A:visited { COLOR: purple; TEXT-DECORATION: underline}SPAN.MsoHyperlinkFollowed { COLOR: purple; TEXT-DECORATION: underline}DIV.Section1 { page: Section1} If the Toner LED is still on, or the status monitor continues to display the message "Toner Life End" after installing a new toner cartridge, verify you are using a genuine Brother toner cartridge.
The yield of the TN starter toner cartridge is approx. 1,000 pages.
The yield of the TN330 toner cartridge is approx. 1,500 pages.
The yield of the TN360 toner cartridge is approx. 2,600 pages.
Approximate cartridge yield is declared in accordance with ISO/IEC 19752(Letter/A4).
Brother strongly recommends that customers use only genuine Brother drum units and/or toner cartridges. Each Brother laser printer is designed to work at pre-set temperatures that are matched exactly to each of our individual toner formulations. Each individual component is designed to work with the other to ensure quality and reliability. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability. The Brother limited warranty does not apply to any problem that is caused by the use of third party drum units, toner cartridges or toner.
1. Verify you installed a NEW, out of the box, genuine Brother toner cartridge (TN360/TN330).
If a toner cartridge from another machine was installed (even if there?s still toner left in the used cartridge) or a starter toner cartridge (included with the purchase of a machine) was installed, the Toner LED will stay on and the message "Toner Life End" would continue to appear on the display.
2. Verify the toner cartridge is installed correctly by following the steps listed below:
a. Open the front cover by pulling the tabs on the left and right side of the printer towards you.
b. Lift the drum unit slightly and pull it out. Place the drum unit on a piece of disposable paper or cloth to avoid spilling and scattering the toner.
c. Remove the toner cartridge from the drum by holding down the lock lever (blue tab) on the left side of the drum unit and lift the toner out. Handle the toner cartridge carefully. If toner scatters on your hands or clothes, immediately wash it off with cold water.
d. Gently rock the toner cartridge from side to side five or six times to distribute the toner evenly inside the cartridge.
e. Place the toner cartridge into the drum (be sure it clicks into place).
f. Clean the primary corona wire inside the drum unit by gently sliding the blue tab on the top of the cartridge from right to left several times. Return the blue tab to the home position before reinstalling the drum unit assembly.
g. Reseat the drum unit into the printer pressing it in securely.
h. Close the front cover making sure it latches on both sides.
If the Toner LED is still on or the status monitor continues to display the message "Toner Life End" the printer will need service.
The printer has a one year limited exchange warranty. If the printer is in warranty, call Brother Customer Service at 1-877-Brother (1-877-276-8437) for warranty options.
If the printer is out of warranty, contact a Brother Authorized Service Center for repair by clicking on the link below:
http://www.brother-usa.com/service/default.aspx
Jul 21, 2010 | Brother HL-2170W Laser Printer
My orange light next to the yellow dot blinking and the printer will not print
When the orange light is solid it means the cartridge is low and you can still print. But when the orange light is flashing it means the cartridge is empty and the printer stops printing. To continue printing you will need to replace the yellow toner cartridge. The part numbers are Q3972 regular yield or Q3962A high yield.
Jun 23, 2010 | HP LaserJet 2550n Printer
I changed me toner cartridge and it ran out quick
Hello
The toner cartridge yield varies depending on the cartridge but should print something about 1500 pages for normal cartridges or 2600 for high yield.
If you only printed about 100 or 200 pages your cartridge might be defective or did not reset.
You should call brother, they can check the serial number to see if the cartridge is defective or not. 1-877-brother for free lifetime tech support
Thanks,
Pat
May 12, 2010 | Brother Office Equipment & Supplies
I need black ink for my lexmarkc540n printer
This is the worst printer! i advise everyone not to buy!! changing ink every week!!!!! total garbage!!!!!!
Nov 08, 2009 | Lexmark C540N PROD SPECS TBD Printer
The pages that print are dark with toner all over the paper.
Barb,
1) if you are refilling the toner cartridge, it may be the blade and roller need to be replaced.
2) if you are using a high yield cartridge, the drum unit will need to be replaced every 2 1/2 cartridges.
The yield for the drum unit is every 20K pages. The drum unit may also be remanufactured.
May 26, 2009 | Brother MFC-8840D All-In-One Laser Printer
Replacing Toner
How to tell on brother mfc-8440 or mfc-9440cn , the total copies printed so far
Sep 07, 2008 | Brother MFC-9440CN Laser Printer
Change of toner
I have a brother mfc 7840w
I first used the electrical tape trick and that worked for a while. Then got the toner low message again. I then tried the *00 trick, which works as follows:
1. lift lid and open front cover
2. press clear/back. "Replace Drum?" will appear on the screen.
3. Press "*00" it will then read accepted and the toner low error (End of Toner Life) should go away.
4. close it all up and your done.
Jun 08, 2008 | Brother MFC 7420 All-In-One Laser Printer
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
