Question about Canon PIXMA iP3000 InkJet Photo Printer
My printer is on but on my pc i got the message printer is offline and all i want to print go s to the wachtrij and i can not print anything
    Novelist:
  • 125 Answers
Well, there are two ways of you see "off line" message.
1. Unhooked with computer or power code.
2. Cartridge is not feasible..(may be not readable however, can't locate the ink level)
Assuming #2 appear to be right for your case.
Try to reset your printer prior to printer
Posted on May 19, 2011
HOW TO FIX...PRINTER IS OFFLINE BUT IT IS ON...WE ARE UNABLE TO PRINT.
If you are getting a status message as the printer is offline on your pc,and afterward you can't ready to print the reports.
Steps to Resolve the Printer Offline Issue:
Step 1:
At first, you need to check your network through the HP Scan Doctor which encourages you to discover and fix the printing issues.
Steps To Run the HP Scan Doctor
    •Open the HP Scan Doctor tool by double tapping the symbol.
    •Start- - >Select your printer- - > Fix Printing
    •Then the list of issues displayed on the screen as result.
    •If the tool shows the white checkmarks at that point there is no issue.
    •If the tool shows the white wrench then the issues are found and repaired
    •If the tool shows the yellow shout point then the issues are found however that can't be solved or skipped.
    •If the device shows the red stamp then you have to take after the on-screen guidelines to determine the issues.
    Step 2:
      Set Your Printer as Default Printer
      •Search your gadget on your PC and select your printer and uncheck the Pause Printing and Use Printer Offline
    •If you can capable print implies your printer is online.
    Officejet 4650 keeps going offline then proceeds with following step Step 3:
    Check Whether You Connect With Correct Port
      •Go to printer- - > Printer Properties - >Port
      •For USB association utilize USB or DOT4
      •For Network Connection use WSD, organize, Standard TCP/IP Port Step 4:
      •Update the printer firmware which may resolve your issues
      Step 5:
      •Manually connect the wired or wireless connection
      Step 6:
        •For network connection just you have to add the second printer to your Windows.
        •Select your printer - > Properties - >Add Port - > Standard TCP/IP Port - > Next port
        •Now you can ready to print implies stop the troubleshooting. Still get the same issue mean you need to connect the printer customer support via +1-800-836-3987
Jan 08, 2016 | Office Equipment & Supplies
Receiving consistence "printer offline" message. Printer will not print although the printer is on and is properly connected. Have checked it with the pc and the laptop. The printer is fine. Is there...
Go to your Control Panel from the Start Menu. If your OS is Windows XP Click on Printers and other Hardware. Right click on your Canon Printer you are using .Scroll down to Properties. Click on Properties . It should give you the option to put the Printer in question "Printer Online". Click Printer Online. That should remove the option from Offline to Online .Then try to print from your Printer.
Jul 31, 2010 | Canon PIXMA iP1600 Printer
Trying to print 'offline'. Computer recognises it is offline but will not print. Error message says 'Printer is offline' which is as it should be. Printer is HP photosmart C4580.
So, if you want to print, the printer must be online. Offline method doesn't work to print. When the computer sayst that the printer is offline, it means ypur printer is turned off or you don't connected the printer to PC.
As in conclusion, if you want to print set the printer online.
Oct 05, 2009 | HP Photosmart C4580 All-in-One InkJet...
Printer not responding
I had the same problem after I accidentally pulled the power cord out of the printer - it turned out to be the firewall on my PC, when the printer reconnected to the wireless network it got a new IP address and the firewall was blocking incoming messages from it.
Jun 13, 2009 | Canon PIXMA MP620 All-In-One InkJet...
I was trying to print using a PIXMA iP1300 but it doesn't allow printing withe a message box appearing "printer is offline".can you help me please
Printer offline : make online in printer properties.Printer offline when start to print : head problem. Replace head.
Jun 12, 2009 | Canon PIXMA iP1300 Printer
False "printer is offline" message
Try to cheeck the port from ur printer to ur cp is been connected.
May 19, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Printer message says it is offline
Hi
Kindly check the usb cable if its fine then try going into control panel open printer and faxes option & set your printer as default .
Thanks
Jan 03, 2009 | Brother HL 2140 Laser Printer
Installed hp psc 1310 will copy great every time printer is turned on it prints test sheet, but will not print anything from computer the message is "user intervention required use printer...
Click START then PRINTER AND FAXES double click your printer when the printer windows open click PRINTER uncheck USE PRINTER OFFLINE i think that the reason why you cannot print because the printer is offline
Apr 14, 2008 | Computers & Internet
Canon PIXMA iP3000 InkJet Photo Printer Logo
63 people viewed this question
old marine
old marine
