Question about Compaq Evo N610C Notebook
Compaq n610c screen turning off then back on after a halfhour
Sometimes I turn on my compaq and it comes up fine. then the next time the spash screen comes up and goes black.I leave it on and come back in about an half hour and the screen is on. If I turn it off and turn it back on its fine.But if I leave it set for a couple of hours it acts up again
  • jcox1980 Aug 23, 2008
    I am turning the laptop on and it always does this I never get a good boot. I have tried to use a restore CD however it tells me that it is checking my hardware and then nothing.
    Problem Solver:
  • 12 Answers
Hello dear sir madam
how are you ...i wont to tell you that can you sell the laptop for me ...i am in nigeria and i wont laptop to use... so therefore if you like to sell you can mail me ...... this is my mail jamessmith0009@mail2world.com
Posted on Aug 14, 2008
Screen does not come on when I switch my compaq evo n610c on ? Any Ideas ?
If you see a dark screen meaning look deep into the screen if you see a logo thru it then it means that the life of the bulbs is done you have to replace the screen is cheap on ebay i got mine there and it works fine to take apart is also easy. But before you spend your money attache an external monitor to it from the VGA on back if it show on the screen then yes your screen is bad if it does'nt then the board is bad.
Oct 01, 2010 | Compaq Evo N610C Notebook
My compaq evo n610c switches itself on when the
Disconnect the power cable from the Notebook and then remove the Battery pack. While the Battery pack is removed, press and hold the power button on the Notebook for 15 seconds.
Next, reinsert the Battery pack and connect the power cord to the Notebook and turn it ON. While the Computer is booting, you can view the information on the bottom of the screen to get to the Setup Screen.
On the Setup screen, use the right arrow key to highlight the "Exit" menu, then select the option "load/get default" and press the Enter key followed by F10 keypress to reset the BIOS and save and exit the screen.
Feb 26, 2010 | Compaq Evo N610C Notebook
Screen turn off of Compaq Evo Notebook N610c
check your settings under power options in control panel, also check advanced power options in bios. very likley you will find problem here.
Jul 25, 2009 | Compaq Evo Notebook N610c
Compaq Evo doesnt turn on.
When you plug the laptop to the power adapter, you should see the indicator led lit up telling that it has good connection to the ac adaptor. It wont turn on because either there is a loose connection to the power adaptor and hasn't been charging the battery, or the power adaptor itself is bad. Check the power plug with a miltimeter, it should be around 19 Volts.
Jul 02, 2009 | Compaq Evo N610C Notebook
My evo n610c wont do anything
While turning on your laptop keep tapping the F8 key...It will give you Advanced boot options...Select Safe mode frm the menu ... it will go to the safe mode ... then try to do a system restore to the date when it was working fine...Best of luck.
Jun 15, 2009 | Compaq Evo N610C Notebook
Pink screen
It sounds like a bad inverter. A local service technician should be able to do it for under $100. Here the rate is about $70.
May 26, 2009 | HP Compaq Evo Notebook N610c
Powered off.
Any beeps when you turn it on? unplug everything and then plug it back in. Make sure the monitor connections are good and that you have it turned on. Again make sure it's turned on. Sometimes it's the simple stuff. Was the monitor working well before it failed? Do you have a video card?
Remove the battery, AC, count to ten and try one last time?
Jan 01, 2008 | Compaq Evo N610C Notebook
No splash screen, no activity just lights (evo N610c) Plz help.
turn on your computer and do nothing,, when it seems the computer stop running key in fn+f4.
Dec 30, 2007 | Compaq Evo N610C Notebook
Compaq Evo N610c
You should first try reseating the RAM, HDD, CD/DVD, and power cables.  If that doesn't work, then you have something a little more major wrong, I guess you didn't write down the error number that came up on the blue screen....
Oct 28, 2007 | HP Compaq Evo n610c Notebook
Compaq EVO N610c
Hey there i might be young im 14 years old but i have the same laptop (Compaq N610c) and i had the same problem i found out that if you take the ram out and rub the small golden plates with a rubber then place it back (the ram is found next to the mouse pad) i then powered the laptop up without the hard drive i then took the battery several times and powered up it then started working again within 5 mins of taking the battery in and then taking it out again it then starting to power up with the screen showing the logo at the begining after it had shown the logo i turned it off then inserted the hard drive back into the laptop and powered up it worked and is still working now Hope This Helps :D My Email Adress Is znet-productions@hotmail.co.uk
if you have anymore problems.
Sep 11, 2007 | HP Compaq Evo n610c Notebook
Compaq Evo N610C Notebook Logo
172 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
