Question about Kodak ESP 5 Printer
My kodak esp 3200 is printing backwards. how do i fix it?
j0llyc
  • 8 Answers
SOURCE: Solid black line when scanning or copying from KODAK ESP-3
Get a damp soft cloth and clean the scanner glass. If that doesn't resolve the issue there is a chance the scanning unit itself is damaged.
Let me know.
Cheers, Chris
Posted on Jun 21, 2009
  • 295 Answers
SOURCE: Kodak ESP 3 printer does not print YELLOW
no,kodak replace printheads free of cost, and if they send a printhead and that doesnt solve issue and in next 30 days,u have same issue,then kodak sends a replacement printer. and esp-3 printers are considered o be in warranty tilll now even if they are 24 months old. kodak is the best.. ur issue will be resolved.dont worry
Posted on Jul 27, 2009
  • 15 Answers
SOURCE: My Kodak ESP 3 all-in-one printer will not print
you may try to clean the printhead and recalibrate the printer. if this will not correct the problem, you need to replace the printhead. I suggest contacting Kodak technical support to have a replacement printhead.
Posted on Apr 17, 2010
  • 35 Answers
SOURCE: purchased Kodak ESP 3250 yesterday. Not printing photographs.
Yes sounds to me like one of your ink cartridge is empty. Replace and try again.
Posted on Jul 26, 2010
Testimonial: "Hi - the printer was caput - had to be replaced. Thank you for help."
SOURCE: I have a paper jam in my Kodak ESP 3200 series
Please check the link below,
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg01093/ESP3200Series_XUG_GLB_en.pdf
Page 7 Printer Overview point 6 is the rear clean out area.
Hope this helps
Posted on Nov 17, 2010
My Kodak printer ESP 3200 Series has stopped printing. It functions as it will print but no black ink will print. I have checked the cartridge levels and all ok, done the maintenance tests and now not...
The following may work: remove all the ink supplies. Remove the printhead and soak it for about 5 minutes in 0.5" of very hot water. Gently blot the printhead on a soft damp paper towel to remove the excess water, then replace in the printer and then reinstall the ink supplies.
Mar 30, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
My Kodak esp 3200 won't print labels on Avery label pages. WILL print the labels on regular copy paper. Any suggestions on what to do?
I am having the same problem except you didn't address the problem. It's not that the printer prints badly, jams or crashes. The printer literally passes the label paper through the printer and then prints on the next piece of copy paper. I reset my printer not to print the last page first and it still did it. Then I put the label paper second in the feeder. It passed through the first piece of copy paper and the
labels and printed on the third. It's like the printer senses the thicker paper and skips it. My printer is a Kodak ESP C315 and I have no setting for thick paper only plain and photopapers.
Sep 22, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have a brand new kodak esp 3200 all in one printer. The ink cartridges do not last for the 400 or so sheets that is says but that is not the problem. The quality of the print is not good. I constantly...
Brand new ? take it back to the store ? ask for a replacement but pick a different brand ,maybe a small $ adjustment might be necessary depending if you pick a more or less expensive brand .
Oct 23, 2017 | Kodak ESP 3 Multifunction Printer/ Copier/...
Is tosshiba satellite computers are compatibile to kodak esp 3200 or3250
Yes ofcourse toshiba is compatible wi th kodak esp
it will run without any problems.so go for it
Thanks
Jul 28, 2010 | Kodak Esp 3250 Allinone Multifunction ( ...
How do I clear a paper jam in the Kodak ESP-3 can't get to the paper
If you have tried the Kodak standard instructions for clearing the paper jam problem and it did not help try the procedure below. Works for esp 7.
1. Open the printing area of the printer (containing the ink cartridges).
2. The Ink cartridge holder should be to right side of track.
3. Look on left side, below the track for the cartridge that is used to
clean the print heads.It can be identified by a square black pad
approx. 1" sqaure that appears to be made of "felt".
If it is visible this is most likely your problem.
4. To correct problem locate the flat latching lever approx. 3/4" wide that
sticks up about 1/2" above the cartridge. It is locacted just behind
the "felt" square. Gently push lever toward rear which should free the
cleaning cartridge and allow the entir cartridge to move slightly
backward.
5. Close the top of the printer and cycle the printer off and back on.
If this is the problem, the "paper jam" error will now be gone.
This is such a simple fix I do not know why kodak does not inform
customers of this problem and how to fix it.
Jan 17, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have Kodak esp 5 all in one- says I have paper jam--- but no paper inside
backward.
Jan 14, 2010 | Kodak ESP 5 Printer
Kodak ESP 5 new cartridges color prints fine black will not print. Only have used Kodak replacement cartridges. How can this be fixed.
Try cleaning the printhead.
Press Menu > Select maintenance > Select clean printhead.
If still black does not print, call Kodak tech support, printhead will be replaced free of charge
Nov 22, 2009 | Kodak ESP 5 Printer
Kodak ESP3:paper light flashes red,can't print-is totally useless
kodak has certain problems with esp-3 printers. it cannot give u a cash refund call kodak @ 1800 421 6699 . they will upgrade ur printer and give u a kodak esp-5. they have been giving esp-5 lately in return for esp-3
Jul 23, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP 5 Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
