Question about Philips 50PFP5332D 50 in. Plasma Television
Power on difficulties. - Philips 50PFP5332D 50 in. Plasma Television
    Genius:
  • 1,156 Answers
Either the power supply has an issue , or you have a bad buffer board and Ysus scan board or both.red light indicating may mean power supply , 7 blinks the buffers and y board.
It could be just a few bad capacitors on the Power Supply, there could be a bad capacitor on the Y board if its bad it needs to be replaced with the buffers together
If you want to attempt the repair yourself you can do a visual of the power board caps will appear swollen on top.
The ones you are looking for are located almost center bottom of the power board,Usually I can see them clearly with the back on simply shining a light into the back through the holes
With the back removed you will see a few circuit boards the upper one (ac cord runs to it through a small board) is the power supply, it has a lot of capacitors on it (cylindrical standing straight up soldered in and marked on the sides with the positive/negative sides and uf and Volts values)
Philips uses 2200uf or 3300uf at 35Volts rating capacitors, they cost about $1-$2 each
The power board and back unscrew with a torx bit and screwdriver size 10 and 15 , if you do not know how to desolder and resolder then do not attempt this as you may damage the TV more than fix it.
We do not recommend do it yourself, but depending on your knowledge and technical ability you may be able to.
You can replace the whole power supply, .
If there is a blinking red light on the TV count the blinks,if it still blinks after replacing the swollen cap this would indicate a bad buffer board ,
check the capacitors by looking for the swollen tops .
I hope that will helpout.....
Posted on May 18, 2011
Difficulty turning on and off 46 inch Vizio tv
Try using the power on/ off button on the tv. If it operates normally then the remote looks guilty
Jan 02, 2014 | Vizio VO Televison & Video
WAT THE CHEAT FOR GOD OF WAR
Knows cheats for god of war and how to get them:
Credits
Completethe game once under any difficulty setting.
Deleted Levels
Heroic Possibilities
Visions of Ancient Greece
Monsters of Myth
Birth of the Beast
God Mode
Character Graveyard
Challenge of the Gods
In-Game Movies
A Secret Revealed
CompleteSpartan mode.
The Fate of the Titan
May 30, 2011 | Sony PlayStation 2 Slimline Console
Program shuts down during exercise. Resets to default program. As if rebooted. have all new parts,(alternator, key board, gray cable, resistor, power input )
I am having the same issue with my 4XXX StairMaster unit.
I am suspecting that the voltage regulator on the lower board is at fault and that a lower board replacement is in order. I have checked everything else (motor, resistor, power supply).
Try this:
My machine REBOOTS if I choose:
- Rolling Hills
- 200 lbs
- Difficulty 20
- 20 minutes
My machine OPERATES NORMALLY when I choose:
- Rolling Hills
- 200 lbs
- Difficulty 1
- 20 minutes
Apparently, the problem only manifests itself at HIGH RPM, which is probably related to a LOWER BOARD / VOLTAGE REGULATOR issue.
Graham Leach
Apr 12, 2011 | Stairmaster 4400 PT Stair Stepper
No power hp pavilian dv 1000
OK i will assist you through this (where you have any difficulty comeback i am always here) First take off the docking device, is power up on battery power if No power up AC next power up the docking device. Second Reset power. cheers
Dec 09, 2009 | HP Pavilion dv1000 Notebook
What level of difficulty would replacing an inlet valve pose?
If the water runs at any time the power is off to the machine, you need to change the inlet valve.
It depends on the model on how hard it is to change.
The water level switch has no adjustment on it. it would need changed if it is acting up.
Get me a model # and I can get you instructions on changing valve.
Vic
May 30, 2009 | Washing Machines
Dell W-2600 LCD TV Will not Power up
power board is bad and needs removed, researched, and replaced. if having difficulties locating, email me.
Dec 03, 2008 | Trimm Technologies DA5-DECS03 Power Unit...
Whats the cheats of god of war chain of olympus psp game
There isn't any coed for it actually, but heres a list of unlockables:
Challenge Of Hades: Successfully complete the game on any difficulty.
Character Concept Art: Successfully complete the game on any difficulty.
Environments Concept Art: Successfully complete the Challenge Of Hades.
God Mode: Successfully complete the game on any difficulty.
In-Game Movies: Successfully complete the game on any difficulty.
Inside Ready at Dawn Studios: Successfully complete the game on any difficulty.
Making Of Attica: Successfully complete the game on the God difficulty.
McKratos costume: Successfully complete the Challenge Of Hades. This costume increases your Attack skill.
Mime Of War costume: Successfully complete the game on the God difficulty. This costume gives 10x Red Orbs and makes weapons invisible.
Outtakes Concept Art: Successfully complete the game on the God difficulty.
Spud Of War costume: Successfully complete the game on any difficulty. This costume increases your Magic skill.
The Lost Levels: Successfully complete the Challenge Of Hades
Nov 19, 2008 | Sony PlayStation Portable (PSP) Console
I am having difficulty booting up the computer. The computer will only power up if I switch the power bar on and off several times.
maybe the power cord from avr to cpu is not set tightly please set it up. second maybe your avr has no power output try to plug power cord direct to the power outlet.
Aug 03, 2008 | Compaq Computers & Internet
Philips 50PFP5332D 50 in. Plasma Television Logo
103 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
