Question about Samsung WF448AAP Front Load Washer
Samsung wf448aap How to access and replace pump?
  • 1 more comment
  • sheakoski May 18, 2011
    Model # wf448aap/xaa (Samsung)
    My model is different than one in the video. There are no screws on the bottom of the front panel.
    Washer is on a pedestal mounted to the bottom of the washer. Does this need to be unmounted (4 bolts) first, when washer is on it's back?
  • 4,323 Answers
Hi
Please check this video to replace the drain pump:
Hope this helps...please post back with the model no. for further assistance.
Daniel
Posted on May 18, 2011
  • 1 more comment
  • Daniel Scott
    Daniel Scott May 18, 2011
    Thanks but have you also checked the video
  • Daniel Scott
    Lay down the washer on it back and then remove the screws from the bottom to replace the pump
  • Daniel Scott
    Daniel Scott May 19, 2011
    Yes please unmount the washer from pedestal before proceeding.
The washer is telling me the door will not unlock but it dose
Sounds like the door lock has failed and needs to be replaced. I have attached a link so you can buy the part. DC64 00519B DOOR LOCK
Sep 08, 2015 | Samsung WF448AAP Front Load Washer
I have the Samsung WF448AAP/XAA clothes washer. The large retainer ring for the front door seal came off somehow. Its a heavy gauge steel wire loop with a spring assembly integrated into the loop. How...
You need to reinsert the door seal back onto the door frame and replace the spring clamp back on. The spring is fairly heavy duty and it will require some muscle to get it back on. Good luck
Jun 17, 2011 | Samsung WF448AAP Front Load Washer
Samsung WF448AAP chimed and read to check filter. I drained the water out and cleaned the fillter. It had 2 quarters and a bunch of junk. I cleaned it and restarted machine and the washer starts of...
I would believe that the water pump has given out. If it is going thru the spin cycle after you drain the tub of water it is almost certainly the pump.
Nov 12, 2010 | Samsung WF448AAP Front Load Washer
Our samsung wf448AAPXAA washer will not drain or spin. Its only 2 years old!
The usual problem of this is the pump being broken or blocked. The way it works is that until the bowel is drained or pumped completely The next order to spin will not be received by the control board. Check to make sure the drain hose is at the right hight it could be to high which will cause this malfunction in some machines.
Mar 28, 2010 | Samsung WF448AAP Front Load Washer
Samsung WF448AAP maybe clogged with feathers.
dont put expensive pillows into a washing machine.
Dec 12, 2008 | Samsung WF337AA Front Load Washer
Samsung WF448AAP Front Load Washer Logo
1,076 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
