Question about Dishwashers
Hello, I have a whirlpool gold GU1200, GU2300 or GU640. From what I have found on line, it sounds like I need the reset code. The cancel and soak and scour buttons are flashing and the dishwasher won't start. Any help would be apprecated. Thanks!
3 Suggested Answers
The Machine
  • 788 Answers
SOURCE: Whirlpool GU1200 XT Dishwasher Will not
I found many forum threads on your subject. Most of them suggest running the diagnostics on the heater to check if it's heating or to pull out the heater element and check its resistance.
Start here: http://www.servicematters.com/clean_led/8178496.pdf
Look here for for a great buletin on the subject: http://fixitnow.com/wp/2006/03/20/whirlpool-built-dishwasher-includes-kitchenaid-and-some-kenmores-wont-start-clean-led-blinks-seven-times/
Then read here and watch the video: http://www.applianceblog.com/mainforums/showthread.php?t=12152
Also read this: http://forum.appliancepartspros.com/dishwasher-repair/199-drain-problems.html
Posted on May 30, 2008
Daniel S
  • 4323 Answers
SOURCE: I have a whirlpool gold
Hi
If the light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Posted on Jul 20, 2011
Gold model GU1200. Is there a filter module and, if so, how do I get access to clean it?
The location is shown as #17 on page 5 of your owner's manual. You may need a magnifying glass to see where the "line" is pointing to, but it does show it in the bottom of the machine. See link below:
http://kitchen.manualsonline.com/manuals/mfg/whirlpool/whirlpool_dishwasher_model_series_gu1200_gu1500_dul300_du640.html?p=5
Sep 29, 2015 | Whirlpool Dishwashers
Press the [Menu] Soft key in standby mode and press
[*] key within 3 seconds to lock the keypad. Keypad lock
remains unlock if [*] is press after 3 seconds.
May 30, 2008 | Whirlpool Dishwashers
Quiet partner whirlpool III gold reset
TRY A RESET CODE
Press the "Sani Rinse," "Heated Dry," "Sani Rinse" and "Heated Dry" buttons on the dishwasher's electronic control panel in quick succession to put the appliance in diagnostic mode.
Close the dishwasher door and engage the door latch.
Wait 10 seconds before pressing the "Cancel" button to reset the dishwasher.
Dec 18, 2013 | Whirlpool Gold Dishwasher with Quiet...
My whirlpool gold cooktop has the control lock button lit up- i can't turn on any buners?
Hello there and welcome to fixya
This is a fairly common issue with these
These cooktops have a internal memory built into them and if they get locked they need to be reset
SO what you will need to do is to unplug the power to the cooktop and leave it sit for 1 hr and do not touch ok then after the hour is up tunr on the power to the cooktop you may hear a audiable beep sound or a click sound this is normal now press the cancel button and you should be all right from here but if not please post me back a comment and tell me what is going on and i will give you further troubleshooting steps ok ?
Best regards Mike
Dec 31, 2011 | Whirlpool 30 in.GJC3054 Electric Cooktop
F1E1 code on whirlpool gold 30" freestanding gas
The E1-F1 error code means that the oven control board has detected a error within the board itself and the control needs to be replaced. The error code can be cleared by pushing the cancel/off button and if it returns shortly thereafter the control defeintly has a defect and should be replaced.
The part number for the control board is W10157245 itcould purchase it at your local appliance parts store or online at;
searspartsdirect.com
repairclinic.com
apdepot.com
partselect.com
apwagner.com
GENE-->-->
Sep 17, 2011 | Whirlpool GFG471LVS Stainless Steel Gas...
Whirlpool GU2300 Dishwasher. The machine stops for long periods during the cycle. All lights go out. If the machine is opened before the cycle finishes, it will not resume. If I try to restart, the normal...
Hi
Door latch.
Open and close the door to make sure the door latch is securely fastened.
Check the dishwasher wiring for a possible loose connection where it connects to the house wiring.
Fuses or circuit breakers.
Check your house fuses or circuit breakers to make sure you have power to the dishwasher.
Thanks for contacting fixya.com
Oct 24, 2009 | Dishwashers
Whirlpool gold gu1200
Sounds like glass fragments against the pump impeller. This may jam the impeller and reduce water pump volume giving poor wash performance and possible inability to evacuate the wash tub. It will not go away and may cause the impeller to fail. Remove screens and get the glass out. Do not poke around with your fingers unless you like cuts.
Sep 26, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool Gold model GU1200 will not start wash cycle
FYI, for anyone else with the same symptoms. I took mine apart and found that the seal on the motor shaft failed and over time corroded the motor shaft bearing causing it to failed. I ordered full motor assembly from the parts store.
Oct 09, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Replace the heating element of a whirlpool GU2300
I have a manual but will need to full model number,,
Jul 09, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Dishwasher Heater Element
service manual for gu1200 and 1500
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/52521bdbd0ef763c85256cbc00520548/$FILE/8178022.pdf
Jun 05, 2008 | Whirlpool GU1200XTLS Stainless Steel...
Dishwashers Logo
67 people viewed this question
Top Dishwashers Experts
Owen Barnes
