Question about LG Refrigerators
I have a grl258ds french door fridge. is there a pressure limiting valve built in the fridge
2 Suggested Answers
Macmarkus
  • 2605 Answers
SOURCE: GE French door fridge problem. When you close one
Hello, In a word, Yes. It is totally normal, when you close a door it pushes air into the unit and depending on how it is closed the other door will "pop" open slightly from the "push" of air. Thanks for coming to fixya. macmarkus :)
Posted on Jun 20, 2010
How to replace LG LFX21976ST water valve
follow 1/4 inch water line where it enters fridge panel water solonoid valve is behind it
Dec 30, 2015 | LG LFX21976ST 3 Door French Door...
Jenn air french door water dispenser broken
You have two sides to your 67006531 Dual Water Inlet Valve, so it is very possible the side that controls the water flow for the dispenser is defective. Replace the 67006531 Dual Water Control Valve and I believe your fridge water will work fine.
I will be here should you have more questions, Thanks Sea Breeze
May 20, 2012 | Jenn-Air JFC2070KRS Bottom Freezer French...
I have a samsung 1 year old fridge that wont get cold at all. the compressor, evap and condensor fans all run and i installed a schrader valve on low side to try to vacuum and charge with no luck. it
Compressor should rapidly bring pressure down from standing pressure to running pressure when switched on. If no change, compressor not pumping. Make sure the line tap valve isn't leaking, and the gas you used was correctly charged.
May 19, 2012 | Samsung RF217ACPN 19.7 Cu. Ft. French Door...
Electrolux EW28BS71IS French Door Fridge no water and no ice
First check that you have good water pressure to the water valve. If you do, then the problem is in your refrigerator. And the most likely fault is the solenoid controled water valve which is a one in two out valve. Follow the water line from you house input and the first place it connects is that valve.
Jan 10, 2012 | Electrolux Refrigerators
Several days ago i replaced my water filter - i do not know if this is a coinsidence but now i hear a buzz every once in awhile like something charging - also, the water dispenser is not working and just...
There are two electric water valves which might buzz (especially if dry). One for the ice cubes. One for the water dispenser.
Since both are incorrect, they are probably not the problem. You are not getting water pressure.
It might not be the filter. Time to get wet and test. Could easily be the valve which feeds the fridge. It is probably a self piercing valve which makes a very small hole to get the water from the larger pipe. Close it all the way down (re-pierce the hole) and open it again.
Jun 03, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
The water pressure is very low for the water spout. I replace the filters every six months or so and the place where I buy them told me that the pressure should be a lot higher when a new filter is...
I very much changing the line from copper to plastic will do anything in regards to pressure. You may want to check the fridge inlet water valve though as that may only be partially opening up provided you know the water pressure is normal coming into the house.
Sep 07, 2017 | LG LFC21760 Bottom Freezer French Door...
Water very slow coming out of dispenser filter only 2 months old
The water is switched on through the valve. You can have a restriction in the valve. You can also have a restriction or freezing in the filter. Most problems is the water pressure going into the back of fridge. Hope this helps,
Aug 15, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
Outside of fridge condensation; hissing boiling noise
under the compressor there will be rubber bushes which would have got damaged so change the rubber bush and ur problem may get solved
Jul 25, 2008 | LG LRFC25750 Refrigerator French Door
Refrigerators Logo
64 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
