Question about Fellowes DM8C Cross-Cut Shredder
Where do i put in oil - Fellowes DM8C Cross-Cut Shredder
    Sergeant:
  • 281 Answers
Just squirt it across a page of paper and shred it.
Posted on May 18, 2011
2002 buick rendevous oil pressure
the oil filter is bad . replace it . Good Luck
Feb 25, 2014 | Cars & Trucks
Need to know procedure to change the oil
locate the oil plug, under car. put pan under it to catch the oil.remove oil plug and let it drain. when all oil is out, replace the oil pan plug that you took out.after doing this remove the oil filter and discard it. put on new oil filter and tighten as much as possible only hand tight. then put in the new oil. check for leaks, and thats it. good-day !
Aug 06, 2011 | 1996 Pontiac Sunfire
I want to drain the old oil out so i can replace with new oil,, how do i empty it?
Under your car in the front should be the oil pan. It has a bolt on one of it's sides. Loosen this bolt and take it out. Don't forget to put something under your car to catch the old oil. Also, change the oil filter. You should see the oil filter while you are under your car. Before putting in new oil and filter, make sure you put the bolt back in the oil pan. Put a little new oil into the new filter and wipe some oil with your finger around the oil filter rubber gasket. Make sure you don't overfill with oil !
Dec 30, 2010 | Ford Futura Cars & Trucks
How minny quarts of oil dose a 96 olds aurora hold
A typical automobile holds 4-5 quarts of oil.....Depends on the size of motor. If changing yourself, Drain out all oil, change filter, put oil plug back in. Put 3- 31/2 quarts back into car. put oil cap on and start car. Let run for 2-3 minutes then shut back off. Wait for a few. Pull out dipstick wipe, put back in then pull out a second time...Now you know how much you need to top off level.
Sep 21, 2010 | 1996 Oldsmobile Aurora
I pour oil in and it comes right back out wheree you pour it in underneath you can see it coming out
you put the oil in a car on top of the motor where oil fill is if the oil is comming out where you are putting in underneath you have removed the oil pan plug Put the plug back in Then put the oil in oil fill on top of motor Located on your valve cover
Sep 18, 2010 | 1996 Buick Century
Broken Engine oil Dipstick. Don't know how much oil to put in engine. How many Quarts of engine oil does it need.
if you can't detect oil level or usage, there's no way to determine how much oil to put in the car.
you can drain it all and put in "x" amount of oil. but if it uses oil, think about it, how do you know how much to put in if you can't determine the level.
or put in 2 quarts, go to church and hope it's a german car. The pope, being german, loves german cars now. Therefore jesus does too.
Jun 24, 2010 | Cars & Trucks
2006 hyundai oil filter change
well the ring should stay on the oil filter if there was one on there when you took off the old one it came off and dont need it
May 04, 2010 | 2006 Hyundai Sonata
I have a 1993 Plymouth laser and have never changed oil before, but watched, not sure what to do.
Remove drain plug from oil pan to drain oil. Remove oil filter using filer wrench. Instatt new oil filter. Put oil drain plug back in. Check owner's manual for oil capacity, put all oil in minus one quart. Start engine let run for aproximately 10 seconds. put in rest of oil and check dip stick to ensure corret amont.
Oct 09, 2009 | 1993 Plymouth Laser
OIL PUMP PROBLEMS
check valve in or check oil filter,did you do the timing belt,that runs the oil pump on a 2.0
Mar 19, 2009 | 1996 Plymouth Breeze
Fellowes DM8C Cross-Cut Shredder Logo
50 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
