Question about Logitech QuickCam Communicate STX Personal Web Camera
Log in problem
When I log on I get Runner file (LogitechDesktopMessenger.exe) lacks a
(the app id separator)
  • ledfordlady Oct 01, 2008
    when I log on I get Runner file (LogitechDesktopMessenger.exe) lacks a
    Novelist:
  • 250 Answers
Hi Kirkpilarmax, Here how to solve your issue:
Please proceed to Clean boot before installing: http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=228
Before running the installer, locate the EXE file and right click on it -> Properties -> Run as administrator
Then select, custom install and do not select logitechdesktopmessenger
Thanks and have a nice day ! Julien
Posted on Aug 02, 2010
6ya staff
SOURCE:
When I go on-line, I receive this message ''RUNNER FILE ERROR''
Probably was uninstalled already. 2 solutions:
1.Right click on My Computer select Explore
Select C; click explore again
Select Program Files folder, explore
Find the kodak Program and Delete
the folder.
2. Go Start y type MSCONFIG in RUN or Search
hit enter, a window will appear on
your screen in the tab "STARTUP"
un-check the line that contents
Kodak application. Press OK and
Re-Start the computer.
Apr 10, 2010 | Computers & Internet
(LOGITECHDESKTOPMESSENGER.EXE)
Hello marchits2002, please have a look in your Startup and disable the filename you stated above from running on startup.
To do this - Press Windows Key + R (to open the Run Dialog), then type MSCONFIG.EXE and press Enter.
You can now see the fourth tab called Startup, have a look at the list and uncheck any startup items you don't find necessary.
Apply the changes and restart computer. Done.
Mar 19, 2010 | Computers & Internet
Unable to access Kodak EasyShare software
Perform a clean uninstall:
1) uninstall the software from your OS
2) run the clear utility program www.kodak.com/go/clear
3) type "regedit" w/ out the quote on the run command, then delete hkey_local_machine\software\kodak
4) run disk cleanup
remove the ff:
  • Downloaded Program Files
  • Temporary Internet Files
  • Recycle Bin
  • Temporary Files
5) reinstall the software again at www.kodak.com/go/edl
May 29, 2009 | Kodak EasyShare Z760 Digital Camera
When starting the computer(HP Pavillion 860)I get the message:"Runner Error:Logitech Desktop Messenger.exe.lacks a "-"(the app.id.seperator).What to [email protected]
Start, Run, MSCONFIG, the on the startup tab find the app that matches this and uncheck it, apply changes and rebbotm should clear up the issue.
Mar 10, 2009 | Computers & Internet
I have deleted svchost.exe accidently from windows xp and cannot now log onto windows. I have tried expanding the file from dos however still cannot log on
this is going to be a tough one to fix. since I don't know which svchost you have deleted from the system.
usually when that happen the only solution is to reinstall the OS. even try to fix it from the registry key, the key and the pointer will be there, but not the excution file, and there is not way which svchost control what services.
The Svchost.exe file is located in the %SystemRoot%\System32 folder. At startup, Svchost.exe checks the services part of the registry to construct a list of services that it must load. Multiple instances of Svchost.exe can run at the same time. Each Svchost.exe session can contain a grouping of services. Therefore, separate services can run, depending on how and where Svchost.exe is started. This grouping of services allows for better control and easier debugging.
Svchost.exe groups are identified in the following registry key:
HKEY_LOCAL_MACHINE\Software\Microsoft\WindowsNT\CurrentVersion\SvchostEach value under this key represents a separate Svchost group and appears as a separate instance when you are viewing active processes. Each value is a REG_MULTI_SZ value and contains the services that run under that Svchost group. Each Svchost group can contain one or more service names that are extracted from the registry key.
Dec 02, 2008 | Microsoft Windows XP Home Edition
Runner error Logitech Desktop Messenger. exe.lacks " the app id separator
I'm certain most all PC Desktops don't have that software, eliminate it and the error with it.
Aug 02, 2008 | Computers & Internet
Runner file?
lacks a..[the appidid separetor]
runner file
compaq connections.exe
Jan 03, 2008 | Kodak EasyShare CX7530 Digital Camera
Runner error message!
this as you know is the logitech software update manager that is running in the background and is probably unable to connect with the internet or the logitech site for news and updates. If you do not want the programme to run at all go to Start>run then type msconfig and hit enter, and on the startup tab and look for runner.exe on c:\logitech line and untick it. Click apply and restart pc. If you wish it to run you may have to install the software again as it is either corrupt or unable to connect with the logitech sever.
May 02, 2007 | Logitech QuickCam Communicate STX Personal...
Logitech QuickCam Communicate STX Personal Web Camera Logo
246 people viewed this question
Top Logitech Computers & Internet Experts
Ekse
Damen Wong
Damen Wong
Alun Cox
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
