Question about Sony BRAVIA DAVHDX275 Theater System
I need a remote code for the Sony DAV-HDX275 system for the new Telus Optik TV remote. Have tried all Sony codes that came with the remote and none work. The remote is an AT6400 Alltouch IR Universal Remote Control. Thanks!
SOURCE: need a universal remote control code for sony dav-dz 100
use kameleon urc remote there are a list of codes in back of manual one of the sony codes will work
Posted on Nov 04, 2007
1903 will work for most functions, but not the DVD player buttons.
Posted on Dec 26, 2007
bugpowder
  • 28 Answers
SOURCE: Stuck in progressive scan mode.
Based on your description, it seems that you set the DVD to progressive scan output, but have it hooked up to a TV (CRT) that cannot accept this signal. Because the TV can't accept the signal, you can't view the DVD menu to change the setting back to interlaced.
On the back panel you have "Component Video Out" for output via component cables, but there is also a yellow RCA connection labeled "Video Out". This is a "composite video" connection which does not support progressive scan. Try disconnecting the component cables and connect the composite video to a TV. The DVD will likely (hopefully) send a compatible signal (480i) through this connection, which will give you access to the menu.
Posted on May 12, 2008
welcomejee
  • 10594 Answers
SOURCE: Remote
Hello creyn,
why dont you join both TV n Theater system remotes togather with rubber band?
Posted on May 27, 2008
SOURCE: Codes for DAV-HDX275 BRAVIA
Amigo conseguiste resposta para trocar a regiao do home theather de 1 para 4? No aguardo, em.maciel@ibest.com.br
Posted on Aug 16, 2008
I have Telus Optik TV with a Cisco remote and an Electron TV (32", not sure the model number) and I need a code to program my remote. Nothing in the Telus guide, autosearch not working. Anyone? Thanks
1012. This is the code to check with Electron TV. If you wish to get more, check these sites. http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 21, 2013 | Televison & Video
Hi I am unable to program my COMCAST remote to control my DAV-HDX275. I have tried all codes suggested by comcast in vain. Help please
These directions also work for Sony DAV-IS10
It seems like most (maybe all) Sony HTIB do not work with the Comcast Custom Remote. I've found a work around that fixes the volume control and power button though. Hope it helpsicon1.png you all. I have a DAVHDX275 but I think this will work for most Sony HTIB systems.
What you need to do is steal some codes from a like product and then hardcode in the changesicon1.png you need to the comcast remote. Set your AUX to 21232 (a sony code for TV/VCRs).
Then do the following:
1. While still on AUX, press and hold SETUP again until the remote blinks twice
2. Type 994
3. Press and release SETUP
4. Type 32975
5. Press and release VOL+
The remote should blink twice. That should reprogram the VOL+ to work with your Sony HT device. For each of the following function codes, follow the same steps and use the codes listed below:
Vol+ = 32975
Vol- = 31951
Powericon1.png = 32719
Good luck. Let me know if it works.
Aug 14, 2011 | Sony BRAVIA DAV-HDX267W Theater System...
Program code for sony home theater DAV-DX250
my home theater model dav dz270 but my remoteis missing please help me what is the remote number
Mar 27, 2010 | Sony DAV-DX250 System
Need 5-digit code for universal remote on DAV-X1
There may be no code in the library of your Insight remote. You may have to try a different universal remote.
Apr 04, 2017 | Sony DAV-X1 System
Dish Network 5.0 IR Remote Sony DAV-HDX275
The code for the 6.3 ir/uhf pro remote when set to uhf is 794. Fist hold down aux until all lights blink then press 2 then enter 794 and press #.
Jan 25, 2009 | Durabrand HT-3915 System
Aug 11, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
I need device codes for sony DAV HD279w home theater/dvd player controlled by comcast digital cable remote control (none of the codes work in the manual and I tried searching for code and still no luck)...
It seems like most (maybe all) Sony HTIB do not work with the Comcast Custom Remote. I've found a work around that fixes the volume control and power button though. Hope it helps you all. I have a DAVHDX275 but I think this will work for most Sony HTIB systems.
What you need to do is steal some codes from a like product and then hardcode in the changes you need to the comcast remote. Set your AUX to 21232 (a sony code for TV/VCRs).
2. Type 994
4. Type 32975
Vol+ = 32975
Vol- = 31951
Power = 32719
Jul 27, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Sony Trinirton TV and DAV-HDX 275 System
Here are a couple of the most common reasons for your problem:
Make sure you have selected the right input source on the DAV-HDX275 that your TV station source (cable, satellite, direct TV or whatever you get TV stations from) is connected to on the DAV-HDX275.
Also make sure that if you are using a digital input (HDMI, optical, or coaxial) from the TV station source, that the DAV-HDX275 in set for a digital input and on the right source.
If you are using an analog source (red and white RCA jacks) for the TV stations , make sure you do not have the digital input activated for that source on the DAV-HD275. You need to select the analog option.
You must also be sure that you have a cable, whether it is analog or digital, connected from the cable box to the DAV-HD275.
I hope this was helpful to you, it is always very important to double check all the connections and make sure the stereo is set to the right type of input (digital or analog).
If you have found this to be helpful, a good rating is always appreciated. Thanks and let me know if you need any more help.
Jun 22, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Remote code for DAV-IS10
Hey guys I was looking around as well ...I found a universal remote that actually worked A++++ .....the name is SONY multi brand remote commander RM-V210 the trick is try under the BOSE code it worked for me picked it up at Walmart for like $12 bucks..
Dec 29, 2007 | Sony DAV-IS10 System
Remote
Hello creyn,
Dec 28, 2007 | Sony DAV-DX250 System
Sony BRAVIA DAVHDX275 Theater System Logo
312 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
