Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
I need a diagram of the tubing routes - Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
  • 5,370 Answers
Click the link below:--- http://technoanswers.blogspot.com/2011/05/bissell-9500-proheat-tubing-diagram.html -------- In the link there is complete procedure to disassemble and assemble the cleaner.Also there is diagram to locate and assemble the parts.-------- This should help.Thanks.Helpmech.
Posted on May 18, 2011
Water line routing
The biggest prob with Bissel is not pumping soap. Becuase if you don't run hot water through this tank the soap will dry and clog after cleaning and storing. Before taking it apart try running hot water through the solution tank and help break up the residue, best of luck. Steve
Jun 06, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
NEED TUBE DIAGRAM FOR PROHEAT 7920
Hi There!
Here is a PDF link for a Bissell Service Center Repair Guide. Hope it helps! Juli ;)
newzealand.bissell.com/images/IncludeContent/Service_Center_Help/Upright_Deep_Cleaner_Repair_Guide.pdf
Nov 14, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell PRO Heat Steam Cleaner is not dispensing the water. I took it apart and cannot find any obvious issue with it i.e loose tubes, connectors etc.
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix knob. Pump is bad. Try running a mix of vinegar and water to see if that unclogs the lines.
Apr 27, 2008 | Vacuums
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
262 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
