Baxi bermuda 50/6 inset 3 boiler lites up but vry small flame on burner and dosn get bigger den goes out 2 lockout after 2 r 3 mins any ideas
    Brigadier General:
  • 4,736 Answers
Please previous response left for you at 5:09 pm ET , 5/18/2011
Posted on May 18, 2011
Baxi bermuda inset 2 fire goes out
Check the thermocouple and clean the pilot
Dec 27, 2016 | Heating & Cooling
Boiler not running smoothly
needs tune up change filter and nozzle and check electrodes are clean with no build up and clean out chambers
Oct 10, 2016 | Heating & Cooling
Baxi duo-tec boiler - when water comes on flame roars up. When i put the heating on the flames roar for 5 minutes then die down.
is the boiler a combi if so have you checked the pressure. it needs to be at 1.5 bar 2 bar at the most . also check that the heat the boiler is producing is completeing the circuit on the heating if you have access to the pipe work there should be 2 or 3 22mm copper pipes. now turn the heating on and check which one is getting warm. the one that is is your flow and in about 2 to 3 min there should be one more pipe getting hot let me no if this is the case
Oct 27, 2012 | Universal 900MM Super Thermocouple Baxi...
Were can i get a mannual for a baxi bermuda 50/5inset back boiler fire
You can download one from there wed site baxi potterton wed site
Apr 10, 2012 | Heating & Cooling
Baxi bermuda 50/6 inset 3 burner ignites but vry small flame on it and dusn get any bigger boiler den goes 2 lock out after 2 or 3 mins any ideas
Mark, it sounds like the pilot may be dirty and needs cleaning. A can of compressed air with a straw nozzle (like you clean your computer with) works well for doing this. Also, make sure that the inline ON/OFF gas valve, on the gas line going to the heater is fully OPEN.
Hope this helps you troubleshoot and solve the problem. Please let me know. Thanks.
May 18, 2011 | Heating & Cooling
Instructions on how to re light my pilot light onb a baxi bermuda back boiler picture if possible thanks
http://www.baxi.co.uk/products/bermuda-back-boiler-unit.htm?view=download , i hope that will help
Feb 16, 2011 | Heating & Cooling
How to light pilot light for baxi bermuda sp3
Go to this link.Bottom of page 15 on the manual
http://www.aroundtownflats.com/manuals/Boilers/Baxi/BAXI%20BERMUDA%20SP3%20GCNo.37-077-63.pdf
Basically it says (turn on the power first) Turn the knob to the the star/flame marking. Push the knob in, hold it for approximately 10 seconds. Release and check the small flame is lit. Now turn it to your desired heat setting.
Jul 21, 2010 | Heating & Cooling
Got a baxi bermuda 552, back boiler not working
Hi clean pilot light and change the thermocouple , you will have to remove the gasfire to get to the boiler if unsure best get a gas fitter to do this as this is not easy to explaine , simple job but you have to know what you are doing , it might be you need a service on the bbu and the gasfire then the thermocouple could be done at this time.
Feb 20, 2010 | Heating & Cooling
Baxi solo 3 70pf boiler problem
This happened to me and it was a rubber pipe inside had perished so it was detecting a loss of pressure. You can see it if you take the main cover off and also the front clipped on cover. Its at the top on the right. You need to replace it with heatproof pipe. Good luck!
Dec 31, 2009 | M20 X-Treme Radar Detector
My oil boiler is a Danesmoor SLPJ 20-25 with an Electro Oil Inter 2011 burner. The oil tank ran out and after refilling the burner ran ok for approximately 6 minutes, the control box chattered and the...
you could have a problem with a temperature sensor.
it would not be the flame sensor since it could not wait 6 mins to sense that there is flame in the unit.
could be a temperature sensor problem where it is sensing a temperature which could be correct but it is sending a wrong signal to the controller to turn off the flame and start another cycle.
tnx 4 using fixya,
drcool
Oct 04, 2008 | Heating & Cooling
Heating & Cooling Logo
166 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
