20 y.o. 35 inch mitsubishi tv doesnt turn on right away. takes sometimes a hour to show a tv screen; once on, no problems
  • 6,993 Answers
This is symptom is of a dying component on your power supply board.
This issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
All these can be checked on the power supply board.
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes).
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Regards.
Posted on May 18, 2011
My mitsubishi ws 65511 turns itself off. sometimes right away sometimes after hours of watching tv
I believe you have an overheating problem. Unplug your set and go to the back, make shire all dust is free from the cooling holes. This should fix your problem. If not pull a little further from thevwall and put a personal fan blowing on the back. Hope this helps.
Sep 30, 2011 | Mitsubishi WS-65511 65" Rear Projection...
Mitsubishi 62 inch, Lamp Problem
it sounds like the lamp is not seating right, make sure it is, try unplugging the tv instead of messing with the lamp if it powers on then you are better off calling a tv shop.
Dec 30, 2009 | Televison & Video
TV screen goes black, sometimes for hours
This model series had a odd problem that caused this. It was the Hoizonal wire connctors for the yoke. If my memory serves me right, the Yoke wire harness went from Yoke to Yoke and plugged in at the casing of each yoke. What I found is the solder connection on the small board of each Yoke was intermitent. Please be careful if you choose to tackle this. It is in a HV Area.
Hope this helps,
Skyassoc
Jun 19, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WS 65857 Picture problem.
Mitsubishi's have been known to "burn in" when you have a stationary image on the screen for too long. Usually its not a problem but in some cases I've seen..if its hours and hours of game play..or even places like home shopping network that have phone numbers that never move during the broadcast...it can cause the image to burn the screen.
The projection tubes would not be burned...it would be the mirror viewing screen.
Apr 24, 2009 | Mitsubishi WS-65857 65" Rear Projection...
Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
Apr 18, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Picture jumps after a few hours turned on
I have a 3 yr old 55 inch mitsubishi TV and when I turn it on the green light starts flashing and I must reset the TV about four times before it finally comes on has anyone had this problem if so what solution did you have?
Jul 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Thin blue line
I am a Sharp Servicing Technician. You posted this before. Ive got the same model TV as you do LC46D62U. I think the line you are experiencing is simply the broadcast. I notice it on some HD shows that broadcast the side bars. (Always on the Ellen Degeneres Show). Ive taken some picture.
1) Here's the line on the left that i experience
2) Later on in the broadcast, it goes away.
One way to check if its a TV problem or not. When the line shows up again, hit the MENU button on the remote. If the line appears to be "behind" the menu, then it is simply the broadcast.
If the line appears to be "on top" of the menu or shows right through the menu, then it is a TV problem.
Im thinking the reason it takes hours for hte line to appear is because it only shows up on certain shows or certain HD broadcasts.
Mar 27, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Tv doesnt always come on straight away
Need more input, what model, what brand, do it turn on if you hit the side.
Regards
What About Bob
Feb 19, 2008 | Televison & Video
Televison & Video Logo
11 people viewed this question
Top Televison & Video Experts
Electro Med Services...
