How many sq ft 32'x20' height 12' - Office Equipment & Supplies
  • 38 Answers
If you are looking for just a floor size than you multiply lenght with width to get the square footage.
Posted on May 19, 2011
How to figure 12x12 sq ft
12 x12 = 144 sq ft
12 x12 x12 = 1728 cubic ft
May 02, 2015 | Heating & Cooling
I need the formula for figuring square feet, say a 12 x 25 foot square---Need to know how much paint would be needed?
12 x 25= 300 sq ft.
Divide that by whatever the paint can says the coverage is.
if paint says 1 gallon covers 200 sq ft then u need 1.5 gallons
Apr 03, 2015 | Miscellaneous
I have a Minerva 44" Fan. I have Vaulted Ceilings with a 12-12 pitch. The down rod is 3/4 in. What slope ceiling adapter is recommended ?
Mike, a 12/12 pitch is 45 degrees. You may have to use a little math to figure out how far down to hang the 44" fan to keep from hitting the angle of the ceiling. Geometry specifically. Remember the A sq + B sq = C sq for figuring the hypoteneuse of a right triangle?? If the ceiling fan is 44", the base (A) of the right triangle is 22" with NO CLEARANCE to the angled ceiling. A 45 degree angle dictates the base and the height are equal, so height (B) of the triangle is also 22" with NO CLEARANCE. If you want a few inches of clearance, extend the height by 4" and there should be enough clearance to allow the fan operation.
I would suggest playing with the figures before you buy the extension rods though. The simple answer to you question remains however...45 degrees.
Mar 08, 2015 | Dryers
Convert 30pounds per sq.foot to pounds per cubic foot(concrete=150#/cubic foot at 1in. thick conc. slab).
These are not the same, so cannot be directly converted.
Pounds per sq ft is a measure of pressure, while lbs / cu ft is a measure of density, weight per unit volume.
I think maybe what you are doing here is converting the weight of concrete in a 1" slab, where a sq ft would contain
1 x 1 x 1/12 = .0833 cu ft
The figure of 150 lb/ cu ft is correct for the average density of concrete, so the above slab would have
1/12 x 150 = 12.5 lbs/sq ft at 1" thickness
BTW that is a thin slab of concrete, insufficient even for a light-duty pathway. If you are referring to a screed for tiling or similar, that is cement.
Mar 01, 2015 | Office Equipment & Supplies
What is the cubic feet equal to 30" x 25" ?
You need three dimensions for a volume.
30 inches by 25 inches is 750 square inches or about 5.21 square feet.
Sep 14, 2014 | Office Equipment & Supplies
800 sq ft equal how maney linear ft
It depends on the width of the individual boards. In 12" width you will need 800 lineal feet.A formula you can use is Width in ft ...such as (width in inches divided by 12) such as 8in divided by 12 = .66666 ..............then , in this example...800 divided by .66666= 1,200.012 if using any width board, just find the decimal equivalent for the width , then divide the total Sq.Ft by this decimal equivalent to obtain your answer in lineal feet needed. Good Luck
Sep 01, 2014 | Crafts & Hobbies
Hi i need to know how to convert 80 sq ft to cubic meters
You don't. Square feet is a measure of area while cubic meters is a measure of volume.
Consider a room 8 ft by 10 ft. The floor area is 80 square ft. What's the volume of the room in cubic feet (let's not worry about converting to meters yet). Well, that depends on the height of the ceiling, doesn't it? If the ceiling is 8 ft high then the volume is 640 cubic feet. If the ceiling is 12 ft high then the volume is 960 cubic feet. Without that third dimension, you can't calculate the volume.
Oct 18, 2013 | Office Equipment & Supplies
What does 3900 square feet equal in linear feet
if you are talking about a home it is huge. But sq. footage is calculated by multiplying width by depth{ or height}. a room 100' x 39' would be 3900 sq./ft. a 10'x10' is 100 sq./ft.
Dec 07, 2012 | Measuring Tools & Sensors
Filter for QCA Aruba xl
QCA has used 4 different sized filters in their tubs through the years.
  • c-4326 4-15/16" x 13-15/16" 25 sq ft
  • c-4950 4-15/16" x 13-15/16" 50 sq ft
  • c-4995 4-15/16" x 23-5/8" 95 sq ft
  • c-5397 5-5/16" x 17-13/16" 80 sq ft
you will need to measure the inside height and diameter of housing and see which one will fit best.
Jan 30, 2009 | Qca Spas Majestic Series Aruba Xl Hot Tub
157 people viewed this question
k24674
