Question about Craftsman Tools & Hardware - Others
Have a MODEL 572.610530 CRAFTSMAN ROTARY TOOL. TURNED ON UNIT AND BEFORE I STARTED USING IT, THE TOOL SHUT DOWN. I EVEN CHANGED OUTLETS TO MAKE SURE IT WASN'T THE OUTLET...IS THERE A WAY TO RESET TO RESTART THE TOOL???
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly. First off you did not mention the age of this tool which would have been quite helpful in my response.
I looked up your parts here:
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Rotary-tool-Parts/Model-572610530/0247/0741520/10043672/00001?blt=06&prst=0&shdMod=572610530
You should inspect the brushes (item 11) for wear or broken springs. From what I can tell this particular model has been in the retail market place for at least 10 years. This would lead me to believe that the brushes are suspect. The brushes can be removed by unscrewing the opposing "screwdriver slotted" plastic caps on the outside of the tool and then carefully lift them out for inspection.
Use a flashlight and inspect the armature where the brushes come into contact. It should be shiny copper colored and not dark or black.
I also note that the switch has 5 speeds. Since it does not work on any speed... I doubt the switch has failed.
Detailed view:
http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2f10043672-00001.png
Your manual:
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0709185.pdf
If you have more questions after inspecting the brushes, feel free to respond anytime with those questions
Thanks for choosing FixYa,
Kelly
Posted on May 18, 2011
Craftsman rotary tool repair
pull the brushes and see if there ok yet
Nov 23, 2011 | Tools & Hardware - Others
I was using my friends Craftsman Rotary tool to shave down a metal door jamb and it got hot so i shut it off. Turned it back on for a second, and has not worked since. It's been 3 days. Is there a way...
You probably burned up the brushes.You can take it to Sears and have them send it in to have them replaced, but in the long run it will be cheaper and a lot faster to buy a new one. Rotary tools are not made to take a lot of stress. Besides your friend will see how much of a nice guy you are and how honest you are and won't be afraid to lend you tools in the future.
Jun 12, 2011 | Craftsman Tools & Hardware - Others
Compressor UP6 25 125, runs all the time but is only under load for a short time, should it shut down between loads?
This unit will shut down if unloaded for a set period of time. Usually 5 to 10 minutes. This time could be longer if some one has changed it from the factory setting. There is a timer in the control box that starts counting down when the unit unloads. If it stays unloaded long enough for the timer to count down the unit will stop until the air pressure drops to the low set point on the pressure switch. It will then start up. If the unit loads before the counter counts down the timer starts from the beginning when it unloads again. This cycle continues until you manually shut it down or you stop using air long enough for the timer to reach Zero and shut down.
Apr 22, 2011 | Ingersoll Rand UP6-25-125 120 Gallon...
As I was using the tool the motor was over heating so I turned it off and now it won't start. Is there a reset for it?
it failed. there is no rhyme or reason. Even a new anything can break at anytime. If it doesnt turn on after it cooled down no use fixing it.
Aug 12, 2010 | Dremel Variable - Speed Multipro Rotary...
Coupler between motor and chuck disintegrated, where can I get a replacement coupler for a craftsman rotary tool model# 572.610011? Thx
As of 5-18-2010
The following is available from http://www.searspartsdirect.com
Flex coupling
Part Number: 2615294309
Category: Hardware and Tools
Weight: 0.18
$2.57 In stock
Sep 09, 2009 | Craftsman Single Speed Rotary Tool
Craftsman rotary tool doesn't lock down on the bits.
the collet is either the wrong size for the shaft on the attachment or is missing alltogether
Jul 04, 2009 | Dremel Variable - Speed Multipro Rotary...
Tools & Hardware - Others Logo
810 people viewed this question
Top Craftsman Tools & Hardware - Others Experts
Mike
John Trevino
Jim London
Jim London
Are you a Craftsman Tool and Hardware - Other Expert? Answer questions, earn points and help others
